Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
60PP920217F Where can i find the Board# Pn1F16971 or LCHDR LSB for this T.V. ? Thanks for any help.
  • 10,594 Answers
I hope you can find required board here.
Posted on Sep 28, 2008
Philips 60pp9200d/37 no video or sound. Power light flashes error 61. There is a spark gap component on the LSB board which arcs when the set is first plugged in, before the error is flashed. Picture...
I do recommend checking the power coming out of the power supply to make sure it is not to high. It is common for these units to have faulty internal capacitors in the power supply. It may be shorting out other components. You can buy a capacitor tester or use an ohmmeter.
Oct 08, 2009 | Televison & Video
Magnavox Philips 60" 9p6031 c103
deflection problem very common on that model. You can get a new LSB board at the following link, leave them a email and they will respond quickly with a price quote for the LSB if they dont have it listed already, they are cheaper than anywhere else for replacement boards for phillips, RCA and GE. Heres the link.
http://servicemanuals.vstore.ca/
Jan 24, 2009 | Philips Magnavox 9P6034C 60" Rear...
First color alignment problems then no pix or sound, just chirpin
If the unit is chirping your convergence amps are out again,or you have a shorted Horzontal output transistor. Not likley for horz output to go out after convergence repair. If he did not replace the 6.8 ohm resistors along with the convergence amps the convergence amps would overheat and short out again.This would explain why the corner would not adjust out. Not a very good buisness practice on his part.Here today gone tomorrow?
Jan 15, 2009 | Philips 60PP9202 60" Rear Projection...
Philips Proyection-60P8341 from the PTV915 series
those models are famous for the LSB boards going bad and they are hard to track down the cause if the LED isnt blinking. You can get a repalcement LSB for your model at the following link. Leave them a email and they may make you a good deal on one. Heres the link.
Sep 30, 2008 | Philips 60P8341 60" Rear Projection...
Broken Screen Phillips 60PP920217F
go to phillips.com/parts they should have them there
Aug 31, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 50P8341 50 in
Board location 7550 on the LSB ( Large board on the right) Its a TDA4861 its not like the convergence IC its mounted to a black aluminum heat sink with a metal spring clip
Aug 21, 2008 | Philips 50P8341 50" Rear Projection...
Tv fix
that is usually related to the LSB large signal board will eventually need replacement. Most repair shops will not troubleshoot the LSB at component level, they will opt for replacing the entire circuit board. If you need more info or help to locate a LSB board. please let me know.
Jul 14, 2008 | Philips 60P8341 60" Rear Projection...
60IN PHILIPS
Time to fix it !!. Replace two Ic's Stk 392-110, and get in service menu settings , and adjust point by point. After replaced stk IC's, check if any resistor look brown or born, if yes, replaced it with 6.8 Ohms.SOme time SSB is defective ( small signal board, replaced it ) If you have questions? noetvs@embarqmail.com . Good Luck !!
Jul 13, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 60PP920217F big screen TV
does anyone know why the picture does not come on .Is there any fuses that might of gone bad?If you know respond to this ?thanks
May 15, 2008 | Televison & Video
Philips 60pp920217f Blinking Power Light
Call a technician. If fixed it is worth it for ~$200.
Jun 14, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
