LAPTOP NOT TURNS ON
ADAPTERS LED SHOWS INCATOR BUT LAPTOP DOES NOT TURN ON . IT WENT TO HIBERNATE AND SHUT DOWN .
    Master:
  • 726 Answers
You pressed hibernate well eagle338 ansew is very good even if u shut it down normal it might never turned back on but take out the batter for half a hour to see if the hibernation stops
Posted on Sep 29, 2008
  • 4,889 Answers
This is probably due to a bad battery or damaged powerjack. Does the laptop work when connected to a plug point?
Posted on Sep 28, 2008
I've had my acer laptop for about 2 months. It will not turn on or power up??? Any suggestions on why this is happening?
Sounds like the computer went into hibernation and locked up. Remove the battery, push the power button for 15 seconds. Attach the AC adapter and leave the battery out. Power the computer on and allow it to boot. Once it boots, go to the control panel and go to power options. Once there go to the hibernation tab and disable. Shut down the computer, reinstall the battery and reboot.
Jun 15, 2010 | Acer Aspire One PC Notebook
My laptop has went into hibernation and shows a small moon and that the battery is in use. I took out the battery and it still shows it in use. It won't come out of hibernation and won't go back to...
The moon means Sleep or standby mode, if the laptop attempted to enter hibernation and sleep mode at the same time it could just be stuck in a hibernation loop and unable to load.
To test this, remove the battery and AC adapter, then hold your power button down for thirty seconds. Once you've done this replace the battery and power cord then try turning it on.
Let me know how you make out and if it doesn't work provide any other details you can including anything that comes on the screen and any beep codes you hear as it fires up.
Thanks and good luck,
Chris
Aug 10, 2009 | IBM ThinkPad T20 2647 Notebook
My acer mininotebooks goes on hibernating
check to see if your power cable is bad. if it went bad your computer would go to hibernate to save energy, then shut down all together. see if when you plug in your power cable if your computer shows that its charging. if it does maybe its a bad battery.
Jul 13, 2009 | Acer Aspire 5100-5022 Notebook
Acer Aspire 2920 won't turn on, although plugged in with battery
First of all, what I'm about to tell you are general troubleshooting techniques - I make no claim that they will fix what you describe, but they may help lead you to a solution.
  1. Unplug the AC adapter and remove the battery
  2. Plug in the AC adapter and attempt to power on the laptop
  3. If it doesn't power on, see #6 below. If it does power on, but doesn't boot the OS, restart - pressing [SPACE] as the first Windows splash screen appears. When prompted, choose to delete the hibernation file and start a system boot.
  4. Shut the system down, disconnect the AC adapter, reinsert the battery, and attempt to power the laptop. If it doesn't start we know, at the very least, there's a battery problem.
  5. Plug in the AC adapter. If it shuts down immediately, or won't power back on after a shutdown. . .
  6. . . .there's a problem with the system board, probably the ciruitry associated with charging the battery.
I hope you 'see the light'. Good Luck!
Jun 15, 2009 | Acer LXA3706003 Notebook
Want turn on after it went into hibernation
your toshiba laptop adapter may go wrong, testing by insert it into an other toshiba laptop, if the toshiba laptop battery is not charged,the adapter is the issue, or if you have a multimeter, you can connect the two electroprobe with the input and output port of the adapter,if the pointer does not move, unfortunately,u should change a new adapter
May 18, 2008 | Toshiba Satellite M45-S169 Notebook
Laptop stuck in sleep / hibernate mode??
Try holding the power button down for at least 10 seconds, that should turn off the laptop completely. Then press the power button again to turn it on. Hopefully it will boot up.
May 14, 2008 | Toshiba Satellite A135-S4527 Notebook
V5000 won't turn on now from hibernation mode
you might need to check your ac adapter and power outlet first before blaming your motherboard.
you go to hibernate mode because the battery is low. the battery is low because you ac adapter isnot supplying power to battery.
May 04, 2008 | Computers & Internet
Laptop will not turn on
I would need more details but you could try there is a hole on the back of some laptops that resets the LCD stick the tip of a pen in there hold it and press the power buttom
Jan 26, 2008 | Computers & Internet
Computer doesn't start.
I would try this:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00372748&lc=en&cc=us&dlc=en&product=500508&rule=45203&lang=en
You also might want to go into your local Staples to find a 3rd party power adapter to see if your power adapter is bad (Staples has no return policy, thus you can try it out and return if needed).
Nov 11, 2007 | HP Compaq Presario V2000 Notebook
Can't get it out of Hibernation...
my toshiba laptop went into sleep hibernation mode,& all i could get was the cursor on screen but nothing else, omg could not get it out of this mode for about 5-10 minutes,so i held the on/off button down for 10 seconds until it definately switched off,then was able to be reboot the laptop,but took some time doing this......
Oct 30, 2007 | Toshiba Tecra 8100 Notebook
Computers & Internet Logo
142 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
