Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Water filter replacement
I have a whirlpool conquest refrigerator and the water filter needs replacing. The refrigerator isn't producing ice and the light on the inside of the refirgerator isn't working. I've replace the bulb
  • 1 more comment
  • missbeverlyt Oct 02, 2008
    My fridge is doing the same thing. It has the infra red light on and water is coming out of the water dispenser, but no water is going to the ice maker. Do I need to change the water filter and eliminate this problem all together?
  • Anonymous Nov 01, 2008
    jklljl
    I have the same problem. Why don't they give you some troubleshooting suggestions? Owner's manual is not worth throwing into a fire for warmth!!!!
I have the same problem. I did change the filter located on the bottom front panel of the refrigerator, but the red light is still on and NO ice. I can't figure it out and I know if I call a tech, its a 300.00 bill. Frustrated.
Posted on Oct 25, 2008
Did you hold the reset button down for 30 secs? Mine you have to hold the button down for about that amount of time before it resets.
Posted on Nov 11, 2008
Not making ice
My whirlpool side by side refrigerator stop making ice , we replaced the water filter some how water is not reaching the ice maker. what can I do to fits this
Sep 17, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker stopped working? Put new filter in and will not produce any ice now?
Make sure you have replaced everything correctly and make sure they are fitted in the correct order. there may be an electrical connection not making.
Apr 17, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
I just replaced my whirlpool ice maker and it isn't working. How long should it take before it makes ice.
At the very most it should produce ice within one hour. Make sure your water feed is correctly installed and open, and that the machine is perfectly level.
Nov 06, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water Filter
most whirlpools have the filter located in the bottom kickplate, right below the freezer door. turn counter-clockwise and toward you to remove. if it has never been removed before, they are hard to get out the first time.
Jul 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Removing the water filter and not replacing
Not with out re plumbing the unit underneath, it would be much easier to leave it in place.
Jan 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker Stopped producing ice
What is sounds like is somehow either the water delievery system is clogged or frozen. If your getting water out of the door, then it is probably frozen. If you are able to turn off the freezer for a bit, that would be an easy way to see if that is the problem without having to deal with Whirlpool or a handyman.
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
1,248 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
