Question about NetGear WGR614 54Mbps Wireless Router (obwgr614_1)
MY LAPTOP DOSNT RECONISE MY ROUTER NEED TO CHANGE IP ADDRESS
  • NetGear Master
  • 787 Answers
Assuming the laptop is running XP -
Open Control Panel
Open Network Connections
Right click on the network adapter and select Properties
Click on TCP/IP and then Properties
You can change the IP address here but it will probably work best if you have it obtain an IP address automatically.
Posted on Oct 02, 2008
How do i connect my WG302 to my laptop using a console cable?
if Windows
go to dosprompt on p.c or start run cmd <press the enter key>
type in ipconfig <press the enter key>
was the ip address of the laptop 192.168.0.210 with a subnet of 255.255.255.0 ?
note the ip address of the laptop and the subnet mask
If the ip address is not 192.168.0.210 then go into the network settings and set the laptop up with 192.168.0.210 and then make it a static ip address.
was the ip address of the laptop 192.168.0.210 with a subnet of 255.255.255.0 ? (if not restart the laptop ) and check again
Next question how did you connect the wg302 directly to the laptop was it directly connected or was it through a network switch or network hub. Most likely the Cable router or DSL router has a DCHP server assigning different ip address lease range. You can either change the ip address of the access point device to one in the original current router lease range and assign it as static for the wireless access point device in the dchp lease table or assign the wireless access point with the second ip address as an example 10.0.0.2 and make sure the router dchp server allocates above 10.0.0.20 then temporarily connect router to laptop and temporily set laptop with 192.168.0.210 and then log into access point and change ip address to 10.0.0.2 for wireless access point device and turn off its dchp server. Then change laptop to use dhcp while connected into network hub or network switch with original router and restart laptop wired back into original normal network.
Dec 04, 2014 | NetGear WG302 802.11g ProSafe Wireless...
Laptop cant find router to set or change password
You will need to connect directly to the router with a Ethernet cable to configure the wireless portion of the router. Once you have done that, then you should be able to do the configuration in the future using the wireless. If you do not have the manual, you can download it from the Linksys website.
Thanks, Jim
Feb 21, 2011 | Linksys Wireless-G Broadband Router
Someone has changed my IP address hacked into in my router
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jul 06, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't connect http://www.192.168.1.1 to get Voip phone connection
first your address should be http://192.168.1.1
with out www ok
if this dosnt work try this
MAKE sure you computer ip address is manuall configured to
ip address 192.168.1.2 or 192.168.1.3 subnetmask 255.255.255.0
note
if you get a ip address conflict keep change the last decimal in ip addres from 4 -223 ex192.168.1.x (value of x)
Apr 11, 2010 | D-Link DI 514 Wireless Router (DI-514)
I got a wireless router for a new laptop its hooked up but wont let me get online with laptop
check for the default ip setting of wireless router. If it is 192.168.1.1 then you need to change it to 192.168.0.1
to check the ipaddress of the router connect it with wire to laptop. at command prompt type ip config. look for gateway setting.. it will be 192.168.1.1
now go to internet explorer and type the gateway address 192.168.1.1
it will ask you for user name and password
enter admin as username and admin as password
now look for router ip address and change it to 192.168.0.1. save setting and restart the router....do reply back if it works
Nov 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Need to change IP address for Actiontec router for verizon fios
definately you will need to change the IP address.
But you can also change the IP address of the wireless extender.
so instead of changing the IP address of the router, you can change the IP address of the extender.
For that you will need to connect the computer to the Extender.
assign a static IP to the computer 192.168.0.10 and Default gateway 192.168.0.30. that will open the set up page of the extender.
change the IP addres of the extender to 192.168.1.30.
that will help you.
For more info about networking click Here
Oct 21, 2009 | Actiontec Electronics (GT724WGR) Retail...
2 Pc's with same IP
AT either desktop or laptop:
[Start]
[Run]
[cmd]
A dark "DOS" windows will appear
At the prompt, type: ipconfig
press [ENTER]
Note the "IP Address" (probably 192.168.1.2)
type: ipconfig /renew
press [ENTER]
Note the IP Address
If it has changed, then you are ok. Type: exit and press [ENTER]
If it did not change, then try this on the other computer.
If that didn't change either, the go to the Control Panel
[Network Settings]
Find the wireless or wired network adapter and Right-Click
Choose "Prpoerties"
In the Properties window, double-click "IP Address"
See the IP Address assigned? change the last digit by one number.
Example: if the IP Address is 192.168.1.2 then change to 192.168.1.3
[OK] [OK][OK]
It should work now...
Let us know!
Sep 17, 2009 | Linksys Wireless-G WRT54G Router
MY LAPTOP DOSNT RECONISE MY ROUTER NEED TO CHANGE IP ADDRESS won't connect to laptop or wii
first things first we need to establish that the router actually connected to the internet... connect the laptop to the router via ethernet cord. if you can get online thats good if not you need to power cycle your model and the router (unplug it wait a 1-2 minutes plug it back in) let me know what happens ...
Feb 05, 2009 | NetGear WGR614 Wireless Router
Laptops do not recieve IP address from the router
Carlos
I think the problem lies within the dhcp of your router. Make sure dhcp is on and change the lease time to 1440 minutes or higher that way once you have the ip address it will stay with your laptop longer. alternatively allocate the ip address on your laptop manually.
good luck
smeags
Jan 03, 2008 | Trendware TEW-452BRP Wireless Router...
Setting up a wireless router
first you have to check the ip address of the dsl modem you used and see to it that it is not the same ip address of the router to avoid conflict. the default ip address of dlink router is 192.168.0.1.if in case your dsl modem has the same ip address with the router, you have to change firs the ip address of the router before connecting the router to your dsl modem.
next you need to know your internet connection whether it is DYNAMIC or PPPOE, depending on how your internet provider configured your modem. for PPPOE connection, you have to know the USERNAME and PASSWORD that your provider provides you.
good luck.
carlmali007@yahoo.com
Nov 30, 2007 | D-Link DI-624M Router (DI624MRE)
NetGear WGR614 54Mbps Wireless Router (obwgr614_1) Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
