Question about Craftsman 25cc Gas Line Trimmer
Thottle return spring
How to you install the spring cant figure it out?
Took to shop
Posted on Oct 05, 2008
My clutch pedal stay close to the floor in my Acura CL. Doesnt return fully like it used too. Cant figure it out and I've replaced everythin
Bobbie, If your sure the system is bled properly,did you get the clutch fork back in correct position, was it the correct bearing etc., you may have to adjust the clutch pedal and / or if it has a mechanical return spring, change the spring, it could be weak.
Check the attached links,instruction and guides for clutch pedal adjustment., bleeding,etc.Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Clutch Kit Installation Acura CL 2 2L 2 3L
Apr 02, 2016 | Cars & Trucks
How dose the line return spring install can't really tell how to install it please jelp
nstallation of Wolff trigger return spring??? - The Firing Line ...
https://thefiringline.com/forums/showthread.php?t=132371
Sep 28, 2002 - 10 posts - ‎4 authors
I know how to install the main spring. How do you install the trigger return springthough? I'm asking cause I just ordered the Wolff GP 100 ... GP100 - Hammer/Trigger Spring Questions
Aug 8, 2012
Changing Springs in SP101
Apr 8, 2011
Wolff replacement main spring for S&W?
Apr 6, 2011
Show of hands...CZ trigger return spring
Feb 19, 2007
More results from thefiringline.com
Nov 02, 2015 | Cars & Trucks
I have the PIxma 922 and have a paper jam! cant figure out where its at?
this can be frustrating. the paper path has three sensors that detect paper first is the pick up, then the second is registration and then exit . what i ussually find is that a spring has popped off one of the arms that are used . they call them flags. the way they work are that when paper hits them it moves them out of the sensor then the spring returns them to a normal state. if the spring comes off it will not return to its normal state. thus it thinks there is paper at that position now you have to determine which one it is. a common issue if the paper jam was pulled out backwards it will pull the spring off. or a small piece of paper is stuck and will not let the flag return and jam will not clear. keep it simple it ussually is .
Oct 06, 2015 | Canon PIXMA Office Equipment & Supplies
Springs on carb how do they go.
govenor spring goes on in side hole thottle spring goes on outside hole
Aug 15, 2014 | Garden
HAVING A 13.20.00 ERROR CODE ON A HP 43OO. PLEASE HELP!!
JAM IN TOP COVER AREA
A jam exists in the top-cover area.
A 13.20.00 error message indicates that the printer power was turned on or that the printer attempted to initialize while the pre-feed sensor (PS102), the top of page sensor (PS102) and/or the fuser delivery sensor (PS108) was detecting media.
When the paper feed assembly is installed, the sensor-flag spring must be correctly positioned
for the flag to operate. If a paper-jam error message (13.20.00 JAM) appears on the control-panel
display after you replace the paper feed assembly, verify that this sensor-flag spring is installed
correctly.
Hook the spring over the flag tab (see 1 in Figure). Fasten the paper feed assembly to the
chassis with the flag spring positioned in the hole in the transfer assembly. Release the spring
from the tab on the flag (see 2 in Figure). See figure below.
Verify that the flag is held in the upright position, can freely move, and always returns to the upright
position. If the flag does not move freely, or return to the upright position, an error
message (13.20.00 JAM) will appear on the control-panel display when the printer power is turned
on.
Aug 10, 2011 | Office Equipment & Supplies
The brake pedal of my 79 firebird is so loose that the brake lights stay on, draining the battery, and I cant figure out where the problem is, I dont know if something has broken, and fallen out, or if...
If by loose, you mean it also has lots of side to side play, there may be a worn plastic bushing at the hinge. If it's just the up and down movement you are referring to, the acutating pushrod may have an adjustment to take up the slack or you could install/replace a return spring. Hope this helps.
Jun 24, 2011 | 1979 Pontiac Firebird
How to change rear barke shoes
Brake Drums & Brake Shoes Removal & Installation To Remove:
  1. Raise and safely support rear of vehicle.
  2. Release parking brake.
  3. Remove rear wheel assemblies. NOTE: If brake drum is stuck, install two 8 mm bolts into threaded holes and tighten evenly.
  4. Remove top return spring, front and rear shoe spring clips and hold-down pins.
  5. Remove anti-rattle spring and adjuster spring. NOTE: Note position of operating lever prior to removal.
  6. Remove bottom return spring.
  7. Remove clip and washer and detach parking brake cable from rear shoe.
  8. Remove brake shoes.
To Install:
  1. Lubricate all brake shoe contact points with appropriate grease.
  2. Place operating level into position on hub.
  3. Install rear brake shoe and connect parking brake cable to rear shoe with washer and clip.
  4. Install front brake shoe and install bottom return spring.
  5. Install hold-down pins and spring clips.
  6. Position operating lever and install top return spring.
  7. Install anti-rattle spring and adjuster spring.
  8. Install brake drum and screws.
  9. Adjust brakes and install rear wheel assemblies.
Jan 21, 2011 | 2003 Kia Spectra
Install door latch cable
Technical Instructions
See picture below
1. Remove door trim panel and water shield per
NOTE: Place a strip of masking tape along the edge of door before removing trim panel to prevent scratching the door with the trim panel removal tool.
2. Snap cable housing end from slot on inside door handle assembly and disconnect cable.
NOTE: Use care to prevent bending of cable housing retainer bracket.
3. Remove rear window channel retaining bolt to allow access to door latch.
4. Position a block (screwdriver handle) between the latch and the door inner panel and snap the cable housing end out of slot (towards inner panel) on door latch assembly and disconnect cable at latch.
NOTE: Use care when removing cable housing to avoid bending of the latch. Discard cable.
5. Hook up new cable at latch and snap cable housing end into slot.
NOTE: Make sure the cable housing is fully seated in the slot.
6. Apply a light film of Teflon grease to the barrel end of the cable. See Figure A.
7. Install return spring. See Figure A.
NOTE: Ensure that the push button rod is located between the spring and the door inner panel.
8. Install foam block at latch. See Figure A.
9. Position water shield over the return spring and install push pin to retain upper portion of water shield. See Figure B.
NOTE: Push pin goes in the same hole as the return spring.
10. Clean hands of grease before performing step 11.
11. Remove protective backing along the lower edges only of the water shield. See Figure A.
12. Install latch water shield at door latch. Pinch the exposed adhesive surfaces together to secure the water shield. Check to insure water shield is not showing through the door shut-face latch access hole. See Figure B.
13. Attach cable to inside door handle assembly and snap cable housing into slot.
NOTE: Make sure the cable housing is fully seated.
14. Check the gap as shown in remote control using a 3/16 drill bit shank end. The drill bit shank should fit in the gap without any clearance and a tight fit is preferred. See Figure C.
15. If the drill bit is too loose or does not fit, adjust by bending the cable bracket as required.
16. Place plastic wedge on remote bracket as shown. Wedge must fit with at least a light press fit for retention. See Figure D.
17. After installation, Apply a dab of special Teflon grease, supplied with the service cable to cable housing openings at inside handle end. The grease should surround and contact the cable all the way around, to seal the opening between the cable and the cable housing.
18. Check all latch functions to insure correct assembly of latch system. If the inside handle does not release properly, replace the inside handle remote release mechanism.
19. Reposition and install trim panel using new push pins if required.
Dec 07, 2010 | 1993 Ford F250
The pull string coil came loose cant figure out how to get the piece that connects to the shaft off on the ryobi ss30 weedeater
There is a cover that you loosen you pull back the handle then youll see a clamp I think its 5/16 loosen it will move but there is a thottle cable you have to loose off the thottle on thr carberator then it will slide off ,if it is a clutch ,the clutch has to be removed by the way of the the arrow then you can get to the rewind
Nov 04, 2009 | Ryobi Garden
Craftsman 25cc Gas Line Trimmer Logo
47 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
