Question about Stoves Premier 720GRa Gas Double Oven
Stove 720g Grill
please can someone tell me why my Grill goes off after 5 mins and then turns back on when it had cooled down a bit. Its seem to work for 5 mins or so, what could be wrong??
Thanks
  • 2 more comments
  • xzafar Sep 28, 2008
    Hi Mohamed,
    Thanks for your reply, the whole reason for me posting it on this forum is so i can fix it myself. Please can you advise where safety thermostat is located so i can change it myself?
    Thanks
    Thanks Mohamed,
    i already have the applinace out of cabinet, now i can open the back panel and look for the component. By the way when you say advice from the repair man, how can i get that and is that free on this site?
    Thanks again...
  • xzafar Sep 29, 2008
    Hi mohamed,
    i have opened the back panel and i dont see any thermostat, however, i opened the top panel and i see a small black component called "thermil cutout" according to the diagram which has 2 connections and each has 2 wires each red and brown.
    is this what you meant and is this what i need to bridge together?? just need to be sure.
    Thanks for your help!!
  • xzafar Sep 30, 2008
    where can i get this part from mohamed?
  • 126 Answers
HI YOU MIGHT HAVE A SAFETY THERMOSTAT THAT COULD BE FAULTY.BEST YOU HAVE A TECH TO HAVE A LOOK AND REPAIR.
GOOD LUCK.PLEASE RATE THE SERVICE.
MOHAMED
Posted on Sep 28, 2008
  • 2 more comments
  • MOHAMED UZAIL ESSACK
    MOHAMED UZAIL ESSACK Sep 28, 2008
    SINCE YOU DONT WANT THE ASSISTANCE OF A TECH I WILL ADVISE YOU IN THE BEST POSSIBLE WAY.
    YOU NEED TO REMOVE THE APPLIANCE FROM THE CUPBOARD ITS INSTALLED IN.REMOVE THE BACK COVER OF THE APPLIANCE AND LOOK FOR A SMALL ROUND AND MOST COMONLY BLACK COLORED COMPONENT THAT SHOULD BE SCREWED ONTO THE BACK OF THE APPLIANCE.BRIDGE THE TWO WIRES THAT ARE ATTACHED TO THE SENSOR AND TEST THE APPLIANCE.
    IF THE APPLIANCE WORKS FINE THAT IS THE COMPONENT THAT NEEDS TO BE REPLACED.
    GOOD LUCK AND LET ME NO IF YOU REQUIR FURTHER ASSISTANCE.
    MOHAMED
    ALSO NOTE THAT NOT ALL PROBLEMS CAN BE FIXED BY THE CONSUMER THEM SELF.SOME TIMES WHEN ITS MORE COMPLICATED THE ADVICE OF A REPAIR MAN IS REQUIRED
    MOHAMED UZAIL ESSACK Sep 29, 2008
    AS MUCH AS WE TRY TO PROVIDE A FREE SERVICE TO YOU THE CUSTOMER NOT ALL THE TIME THE PROBLEM CAN BE FIXED BY YOURSELF.THATS WHEN WE ADVISE YOU TO CALL THE SERVICE OF THE TECHNICIAN IN YOUR AREA.MOST OF THE ADVICE ON FIXYA IS A FREE SERVICE UNLESS YOU REQUEST THE PREMIUM SERVICE WERE YOU DO PAY A SMALL FEE.
    GOOD LUCK.
    MOHAMED
    MOHAMED UZAIL ESSACK Sep 30, 2008
    HI
    THAT IS THE PART YOU NEED TO BRIDGE AND TEST THE OVEN IF IT WORKS NORMAL THEN YOU NEED TO REPLACE THAT PART.
    GOOD LUCK.
    MOHAMED
Westinghouse oven model WFE946SA, purchased only 4 mnths ago. No lights display
main control board,take it back,its expensive,1 year warranty
Jul 26, 2015 | Ovens
During cooking the oven goes off. There is often a lot of water/steam present. Sometimes after a while it comes back on?
It could be that the overheat thermostat is kicking in, albeit earlier than it should do. Have you checked to see that the oven thermostat is working correctly and is not heating the oven up too much ( does the neon go off and on) and is the oven cooling fan running ok in the background. If these two appear to be ok, then you may need to replace the overheat thermostat.
(The oven cooling fan should remain on for about 5 to 10 mins after either oven or grill has been used. If this isn't happening or it is not running correctly then that is why the overheat device is shutting the oven off). As a thought, are the top oven and grill working ok? if they are, then it narrows it down to either the oven thermostat or the overheat sensor.
Nov 19, 2010 | Stoves 720EF Electric Double Oven
Please could someone tell me how to use the grill?
First things first, the grill only works with the door down. Directly you shut it, a microswitch operates and shuts the elements off. ( Of course the top oven operates with the door shut).
There are two options for the grill. Turning the control switch to the left operates the inner element only. Turning it to the right operates both the inner and outer elements together.
With either option, setting 5 (the max) has that option on full, whereas settings 1 to 4 switch on and off.
Nov 10, 2010 | Stoves 720EF Electric Double Oven
Lost manual
Hi,you can download the manual for your unit for free at;www.manualsonline.com or www.manualnguide.com.
Thanks and take care
Apr 19, 2010 | Stoves Premier 720DCa Dual Double Oven
F2E1 on stove after cooking on temps of 425-450 for 20mins stove shuts off and can not restart even if power is turned off and then started. must wait for stove to cool down and then press cancel and stove...
Is the background cooling fan running? Also, look under the oven and if possible take off the kick panel and clean all the rubbish out to ensure the cooling fan can circulate air round. As a check, when you turn any part of the oven on ( Main/top/grill) the cooling fan will run and you will feel a cool draft of air coming out of the gap just above the top of the main oven door. If the fan is not running, this will cause the unit to overheat and the overheat thermostats to kick in, turning the oven off.
If the fan is not running, you will have to take the whole unit out to gain access to the back panel.
Nov 28, 2009 | Stoves 720EF Electric Double Oven
Baumatic B180ss Electric oven problem
It sounds like the overheat safety stat is cutting the oven off.
This is prevent the oven overheating and catching fire.
They can go faulty and operate prematurely, causing the prob u are experiencing.
If it is built in , make sure it has adequate ventilation, as this can cause the prob.
Also check to see if it has an external cooling fan fitted, these can fail, and again cause the prob.
They are usually fitted under the top cover of the oven, and designed to keep the oven cool.
It should come on shortly after turning the oven on
These things are the most likely cause of the prob.
plz rate my solution.
Thanks.
Dec 31, 2008 | Baumatic B180SS And B60SS (Bundle)...
ELECTROLUX EOD5310
there are two fans and one is out of sight and is to cool the casing. normal for the casing fan to run for up to 20mins after switching off. after 4 years, maybe getting a bit worn and hence noisy. nothing to worry about
Jun 23, 2008 | Electrolux EOB5665G Ultrafan Electric...
Shut down after 10 minutes
it is reaching the correct temperature and then switches back on when cools a bit?
Jan 11, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Stoves Premier 720GRa Gas Double Oven Logo
574 people viewed this question
Top Stoves Ovens Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Stoves Oven Expert? Answer questions, earn points and help others
