Question about LG DK 9411P DVD Player
Burnt DVDs I have several films that I have burnt using my LG GSD H22N. They work fine but after some months say 6 or 8, whenever I play some (not all) of these copies I've made, the image suddenly freezes usually at the end of the film. Pressing all the buttoms of my player's remote control is of no avail. After a few minutes, the player simply finishes playing the disc and it stops. When I play again the movie, the problem repeats but not necessarily in the same frame. It might freeze in another place of the disc but usually at the end. Careful cleaning of the DVD is useless. My storing conditions are excellent, low moisture, average temperature. What on earth can be happening? I suppose the player is OK since I use it with other DVDs with no problem. Thanks a lot!!!!
3 Suggested Answers
SOURCE: Stops Playing: screen freezes
My friend suggested I clean the dvd optical reader lens inside the player with a fine brush (like a camera brush with a blower bulb). This seemed to help immensely. I'm not certain if this is just a temporary fix, but it seems to be ok so far.
Posted on Jun 23, 2008
SOURCE: will play discs burned from hdd but not commercial movie type dvd
The solution is simple.I rang LG service (so called - LOL)
Asked for a fix or reset method. (Which can be done but they won't tell novices how)
Got no joy, so now I will bin it,and spend the rest of my days telling people to avoid LG.
After all the posts I have since read about the same problem on various LG models,it is obvious their product sucks,they know it does, but won't accept the responsibility.
If I stop 4 people buying their ****,that's at least $1000 they miss out on.
If the process snowballs,how much then$$ ?
It would cost me $120 just to get it to and pick it up from the repair place.
Plus parts and labour added.
Before buying an LG DVD recorder go online and check out how many dissatisfied customers there are. In short, DO NOT BUY !!
Posted on Jul 18, 2009
Whenever i insert a dual layer disc into my LG gsa-h22n, it shows disc size of only 4.5gb can anyone help?
Hi sadh_priyank
Check this in the following order :
You are using a program set to 4.5 GB or your device is set to 4.5 GB or you are using an unappropriate disc .
Best regards ,
fanaudi .
Jun 30, 2011 | LG GSA-H22N DVD±RW Dual Layer Burner
My dvd player on recognizes original dvds but wont read any burnt dvds...WHY???
most of the laptop dvd drives have slower reading speed(about 2x) and writing speed(about 24x) compare to desktop pc's(about 8x and 52x respectively).
ur problem might have occured if the writing speed by which the cd was burnt might not be compatible with ur dvd player.
try playing dvds which were burnt using laptop dvd writers.
also try changing the modes in which the dvds are burnt.
Jun 19, 2011 | Lenovo 3000 Y410 (59012354) PC Notebook
Just bought an ONN dvd player and will not play burnt dvds. It says it will play DVD-R/RW. Any ideas to why it won't?
Burn your dvds in a proper way. If you burn your dvds as data dvd, it may not work on certain dvd players. Try different software or different PC to burn your dvds. Check the region code of your dvd player & the dvds burnt. They should match. You may find some region-free players.
Jun 19, 2011 | Televison & Video
My (HL-DT -ST dvd ram-GSA-H22N) Dvd burner wont go to this site and download and install this burning program and try it, un install the other burning program first, let me know how it went
Mar 25, 2010 | Computers & Internet
What recordable dvds will play in philips HTS3400??
it might be the programs your using to burn your dvds try using windows dvd maker if you have the operating system vista or convert x to dvd if you have xp that should work
May 30, 2009 | Philips HTS3400/37B System
DVD deterioration
I would blame it on the DVD player. They are fickle when it comes to playing burned discs. Try playing the disc in your computer. If does the same thing there, the disc is garbage. You can also try burning at a slower speed, sometimes this helps. I would also try to avoid using DL (dual-layer) discs.
Apr 09, 2017 | Televison & Video
Home burnt dvd will play on one machine and not the other. An old technika works fine, an expensive philips won't play, another new technika tells me it's the wrong disc
Newer units have protocols built into the firmware that prevent "piracy". Sometimes these new protocols will prevent a home burnt dvd from running. Hold on to the old technika as long as it will run because the newer models will not work on all of your home burnt dvds.
Jul 30, 2008 | Televison & Video
Playing burnt dvds in black and white
Cause: You are trying to play a DVD with NTSC-standard on a PAL-videodevice. Solution: switch your video-device to NTSC-standard or to "AUTO". Explanation: I had this "Black&White" problem after I played a DVD which I downloaded from Internet. My video-device (beamer) was set on PAL and gave black&white pictures, but when I switched it to "NTSC" the problem was solved. Apperently the Sony DAV-DZ100 switches automatically from PAL to NTSC when needed.
Nov 01, 2006 | Sony DAV-DZ100 System
Televison & Video Logo
75 people viewed this question
Computer Repairing
Computer Repairing
