Question about Olympus FE-140 Digital Camera
Broken battery compartment door switch
Hello, My daughter's Olympus FE-140 camera gives a card cover open error. It appears that the switch operated by the battery compartment door has broken/fallen off and is missing. Is there any way to repair this switch... bypass the switch with a copper wire? It is difficult to tell how the switch worked because it is missing.
Thanks,
Bill
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
Posted on Oct 07, 2008
My Olympus Stylus 9000 camera fell. Now the battery/card compartent door will not close allowing the camera to turn on.... I think I may need to place the door? I am not sure why it will not close.... Possibly something broke off????
Posted on Sep 27, 2009
I had exactly the same problem, the tiny little plastic tag on the battery cover which operates the switch fell off, (its very flimsy) but fortunately I managed to find it and put it back in place.
Instead of soldering copper into your camera, you could try to wedge a bit of plastic into where that plastic tag would normally fit. That may work.
Posted on Oct 16, 2008
How do i find the serial number for olympus master digital camera
Located on the camera body, inside voice recorder battery compartment or memory card compartment.
Dec 17, 2012 | Olympus FE-140 Digital Camera
Olympus FE-46 shows Card-cover open error. Cover is closed.
Hi, I have solved this problem in a Olympus Fe-20 camera. First of all, I will explain the facts of the problem. When closing the cover, inside the camera, there is a switch that get closed. This switch is like a door that opens or closes a electric contact. So when this switch is broken it does not join the contacts, so the camera thnks that the card cover is still open. Taking out some screws of the plastic tap of the touch screen, you will see, the touch screen fixed with a special conector. With a small screw driver take the black part up, and then you will manage to take out te touch screen. Then you have to take out the the board where the touch screen was fixed, taken out some screws , and disconneting the card from a similar conector than the one of the touch screen. So you can take out this board, and see that you have reach the main board of the camera. If you close the card cover, you can see in the main board the switch that opens/closes a contact due to the position of the cover. The switch has 4 welding points. You will have to take it out, by a tin solder. Then put a tin in the left down welding point and fix with a wire to the rigth up welding point. Fix the boarding card with its conector, fix the touch screen with its conector, and try to switch the camera on. If OK, fix everything up. If not, have a look at the contacts welded, that the problem is there. Hope to be helpfull.
Oct 26, 2010 | Olympus FE-46 Digital Camera
Fe 5020 digital camera plastic tab that holds battery in broke off and now receive an error message that the card cover is open
The base is working as a complete circuit when it is closed completely. Now as the plastic tab which holds battery is broken so the circuit is not getting completed and the software of your camera is not getting message that all parts are functioning accurately. You need that plastic tab or similar tab to fix this problem. Please show your camera in a repair shop and they will get it fixed at very low prize as they normally have such parts with them.
May 29, 2010 | Olympus FE-140 Digital Camera
FE-140 Battery compartment door broken
battery cover has small and minute parts so it breaks easily. getting a spare is difficult. only easy solution will be to take it to service center and fix it
Jul 29, 2009 | Olympus FE-140 Digital Camera
Olympus FE-5010 Card cover open error. Card cover is closed. Tried a new battery and new card. It didn't help.
i hv olympus fe 5010 nd problem is "write protect" error sawing .....so how i cn solve it
Jun 27, 2009 | Olympus FE-190 Digital Camera
Card cover wil not close
Unfortunately this is a repair issue with the camera. There is a sensor on that card cover door that may now be missing and needs to be replaced. You may want to call Olympus Customer Service to discuss their repair policies and procedures. Their telephone number is 800-622-6372 option 2 and then option 3
Jan 05, 2009 | Olympus FE-140 Digital Camera
you could try and put all the info about your camera in to google search..or the same on ebay.
Oct 27, 2017 | Olympus FE-140 Digital Camera
Olympus FE-140
Yes I had the same problem, however, where is says "push to eject," it means to push the the memory card down and it will eject. You pushed down the latch for the plastic door cover. Try pushing something into the hole so the camera thinks the door is closed. I am still having trouble with mine. Hope this helps alittle.
Sep 16, 2007 | Olympus FE-140 Digital Camera
Card cover open
The problem is a broken micro switch. If you are familiar with soldering on micro circuits you can get the part from Olympus it is called a card cover switch. Otherwise, send it into an authorized Olympus shop.
Oct 10, 2006 | Olympus FE-140 Digital Camera
Olympus FE-140 Digital Camera Logo
840 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
