Question about Sony Playstation 3 (PS3) Console
Connecting ps3 to cinema system
I have 1 hdmi connection on cinema system and 1 digital input. i would like to play ps3 through cinema system but 1 hdmi connection is full with the tv one, do you get the same quality by connecting ps3 to cinema system with digital in cable.
  • Anonymous Dec 11, 2008
    I have done the same as the op, but when connectiong optical cable from PS3 to surround system I get no sound. Any suggestions?
    Scholar:
  • 124 Answers
There is no substitute for HDMI. However, the 'digital in' cable connection that you want to use is still digital and will sound almost exactly the same. The differences are barely noticeable to the human ear. Here is a list for you to see the pecking order of each type of connection.
Audio connections from best to least go in this order:
1. HDMI (digital)
2. Fiber optic (digital)
3. Coax - Digital (digital) <--- The one you want to use.
4. Component (analog)
5. RCA/AV (analog)
Video connections from best to least go in this order:
1. HDMI (full HD digital)
2. Component (Blue, green, red, white, red - HD analog)
3. S-Video
4. RCA/AV (Yellow, white, red)
Good luck!!
Posted on Sep 30, 2008
I want to connect my Philips HTS3357 Home Cinema System to my Panasonic PT-AE900E LCD Projector, How do I go about putting it altogether so it works with my xbox360/PS3
Generally speaking, if your Home Cinema system is able to pass-thru video as well as audio, you'll want to take the HDMI cable from the XBOX video out, into the Home Cinema system's input (any HDMI input should be fine), and then run the HDMI video out to your projector. Any other devices you want to be able to project as well (DVD/BluRay, PC, Cable, Satellite, etc.) would also be plugged into the Home Cinema system as "in" devices, like the XBOX.
When you want to display one of those devices, you would select that "in" port's input name in the Home Cinema system (for example, if the XBOX is connected to the HDMI in that is labeled "aux", you will switch the cinema system to Aux Input, and the projector should immediately begin getting the signal from the theatre system. To switch to another device, you simply change the Input channel on the Home Cinema.
The audio also, providing the device (the XBOX) can carry it on the HDMI cable, will also be delivered to the Home Cinema. Some devices cannot carry sound on HDMI (though many can). For those, you will need to run an HDMI cable for the video, and also an optical cable or other type of audio-only cable, for its audio. You do not need to run an audio cable to the projector though, as the projector is only for video. The Home Cinema will take care of the sound itself.
Mar 28, 2014 | Philips HTS3357/05 Theater System
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
NO OPTICAL SOUND I connected HDMI from reciever to TV, HDMI from PS3 to TV, Optical from PS3 to Receiver (PS3 Sound settings switched to Optical, with Dolby Digital 5.1CH, and Dolby DTS 5.1 selected) ...
I think your problem might be at the digital audio setup at the receiver. To fix this, go into the setup under digital audio and make sure that the input that your connected to is set to optical, not analog or coaxial. Example if your plugged into video 1, make sure that the audio setting corresponds to the optical input where your connected. Video 1-optical-1.
Good Luck
Jan 07, 2011 | Samsung HTC5500 Theater System
How do i connect my non hdmi xbox 360 to my panasonic scbt205ebk home cinema and panasonic 42v10 plasma so that the sound comes from the home cinema system. i also have sky hd
If you use a component system (1 yellow video wire, 1 red audio wire and 1 white audio wire)
You will have to connect the audio wires to your cinema system and the video directly to your set.
The unfortunate part of this is that when you want to use your system, you will have to change the input of the TV AND the Cinema system.
The same would be true if you wanted to use the DVD connectors (YBPBR). You would connect the video to the TV and the audio to the Panasonic unit.
The system you have is meant more for just playing DVD's and not a total cinema system. This is why there are limited (extremely limited) video inputs. The system is mostly for output of sound and of a the built in DVD video.
Aug 05, 2009 | Panasonic Televison & Video
Connecting ps3 to home cinema
For sound use the Digital Coax in, if the PS3 has digital out. Most HiFi home cinema systems have HDMI with all channels audio through HDMI. Check cinema settings to configure input for hdmi audio, also check PS3 audio output setting options to include all supported audio type by your receiver. It's not just a plug and play. Both systems need to gor through a user setup process to make sure they sync and play well with each other.
Jul 24, 2009 | Audio Players & Recorders
Help with connecting home cinema to xbox
if your tv supports this. go to ebay type in "hdmi" buy one for around $10.00 plug into xbox. set your tv to which port you have ,(if you have more then one). bingo,bango ,your done.
"no hdmi"? and you have com. on your tv. plug corrosponding color plugs for component ,L&R audio plugs .
change tv to comp.( not video) your done
Jan 30, 2009 | Audio Players & Recorders
Sharp television and panasonic cinema system with hdmi connection
Ok, here's the deal. You can have sound being putout from hdmi coming from one of those sharp units, but it just depends on how you are connected. If you are using a digital audio output, from the tv, it wont push out the sound the way that it should. You will have to downgrade to using audio composite cables to connect to your external speaker system from the audio ouputs, not the digital audio outputs. Its not designed to push out sound from an hdmi cable. The BEST way to have this setup is to run your sound directly from the cinema to the external audio source(leaving the hdmi cable in the tv).
Nov 17, 2008 | Sharp Aquos LC-32D40U Television
Set up help!!
Firstly connect your home theatre outpu HDMI to HDMI input1 on the TV. Then connect the PS£ HDMI to the other HDMI input on the TV. Now connected the optical cable from the PS3 to the optical input of the home cinema system. Your should now have surround sound from the PS3 and DVD.
Sep 11, 2007 | Samsung HTP-1200 System
Sony Playstation 3 (PS3) Console Logo
165 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
