Question about Panasonic DP-1810P Laser Printer
Tel. P/M : error
On Panasonic DP 1810P, got the tel. for P/M code. Looks like at 85K, needs the full P/M and won't function without it. Can I do this myself? How much should it cost if service tech does it?
  • 284 Answers
You need a service tech to perform this task because it need stuff to be takin apart. if you live in canada i can recomend a dealer
Posted on Nov 03, 2008
saqib131 Nov 02, 2012
Press the Function Button then press Original Button and press 3 you enter the Service Mode Press 5 then press start key again press 70 then press start key again press start key enter 0 and press start key machine on off your problem is solve
Aug 01, 2012 | Panasonic DP-8020E Black and White Copier
Hi , I have a panasonic dp 8020e at the moment it has a message saying "TEL. FOR P/M" And the little wrnech symbol is red. what does this mean?
it means call for preventive maintenance .u have to call the service people or press "function" " original size""3" in tandem. u will enter service mode.goto unit maintenance by scroll keys .then press set/green button to go to ram initialize and then press option flash memory clear.
thats it
Sep 24, 2011 | Panasonic DP-8016P Copier
How to fix our copier panasonic 8016 which indicates on the display TEL: FOR P / M
"TEL FOR P/M" means to call for preventive maintenance. A technician needs to come and perform preventive maintenance for the copier and reset that setting.
Panasonic does not publish a way for end users to do their own preventive maintenance or reset that counter. There is a hidden service mode to reset the counter, but if you do that without perfroming the required maintenance, you could end up with trouble down the line.
Mar 18, 2011 | Panasonic DP-8016P Copier
Message : TEL FOR P/M
how to remove tel p/m in panasonic copier dp8016p
Dec 01, 2010 | Panasonic DP-8016P Copier
Printer says tel. for P/M
yep! it means your machine reached its counter for maintenance probably it reached 120k.
you may call your service technician to perform maintenance/cleaning.
Mar 24, 2010 | Panasonic WORKiO DP-1520P All-In-One Laser...
DP-1810P USB
sir/mam, there is no usb port on all 1810p and also the usb to parallel cable is not working with these machines.
what you can do as an option is to find a parallel print server, or you may connet the copier to the router with a builtin parallel print server
May 19, 2008 | Panasonic DP-1810P Laser Printer
Panasonic DP-1810P Laser - J41 error code
i think the fuser sensor lever on your machine is damaged.
its the lever that you usually see when you open the cover the fuser unit.
Apr 02, 2008 | Panasonic DP-1810P Laser Printer
Panasonic DP-1810P Laser Copier
The copier has an "eye" that detects when the waste toner bottle is full. If you dump it and reuse it, the residue can build up and cause the machine to "think" the bottle is still full. I experienced the same problem. If you re-use an old bottle, after emptying, rinse our any remaining residue and dry the bottle out. Your copier should then notice the bottle being empty.
Mar 14, 2008 | Panasonic DP-1810P Laser Printer
Hi B.
My geographic knowledge of Oz is not great.
So click this link it will give you the main panasonic dealers in Oz.
If one of them is close they will asssist, or thye will put you in touch with a closer dealer.
Let me know if this is useful.
Jan 11, 2008 | Panasonic DP-1810P Laser Printer
Panasonic workio dp-1810p
pls check out the sensor lever below the drum if it is freely moving.
because that is the sensor concerned for j33
Sep 01, 2007 | Panasonic DP-1810P Laser Printer
Panasonic DP-1810P Laser Printer Logo
785 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
