Question about Belkin (F5D5231-4) Router
Wireless Router use with Wildblue Satelite Modem
I have Satelite Wildblue internet connection, I have been trying to use my Belkin Wireless Router to connect 3 computers to the wildblue modem.
Belkin router I have is N Wireless Router Model # F5D8233-4.
Wild blue does not support Routers but told me they will work with their systems.
I have tried connecting using the wireless feature and hard wire feature but my connection is very slow and most of the time goes limited and I end up fighting with it. any suggestions?
  • Anonymous Feb 08, 2009
    I TRIED CONNECTING MYBELKIN ROUTER TO THE WILDBLUE ROUTER WITH NO SUCCESS.! CAN YOU HELP?
You should be aware of a class action lawsuit that Belkin and the complaintent settled recently. The lawsuit was filed complaining that certain Belkin routers did not obtain optimal speeds as advertised.
Belkin has agreed to provide affected customers a discount program to purchase a new router. You will need to search elsewheres for the details.
Posted on Oct 11, 2008
My belkin basic router is not working
well you can fix such kind of problems via contacting to belkin tech support. for more help you may visit: Belkin Tech Support Helpline
Sep 10, 2010 | Belkin (F5D5231-4) Router
I am trying to find the connection for wildblue so that I can hook up a belkin router?
Are you trying to install the router ?
Your internet service provider is wildblue.
First make sure that your computer is able to go online when connected directly to the modem.
If not then you will need to contact ISP and get internet working on modem.
If yes then you can set up the router manually.
Click Here for more info about router set up
Nov 28, 2009 | Belkin (F5D8231-4) Wireless Router...
I am trying to upgrade from Linksys wireless B router, to a Linksys wrt160n v2 router. I have wildblue.net satellite link, works great with wireless b, but wireless n installed it says modem is missing....
you will need to check the settings of the router.
Your internet service provider id wildblue.
If you connect the computer directly to the modem , without any router , does it work ?
Click Here for step by step solution
Oct 30, 2009 | Linksys WRT160N Wireless Router
Belkin wireless router disconnects from wildblue every 2 min
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the Belkin wireless router away from walls and if possible move the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. changes the default password, setup encryption use WAP2 or WAP, change the default SSID, turn off SSID broadcast, and for added protection, enable MAC address filtering which allows the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 23, 2009 | Belkin (F5D5231-4) Router
Router disconects from modem-Belkin router/Wildblue modem
hi,
try to chk out the firmware of the router. in most of the cases firmware are the major problem for the disconnection of the connection if the device has been purchased a while ago. visit ur belkin website and look for the firmware for your router model no.
if the device is new then try to decrease the mtu size and temporarily disable the firewall of the router
gud luck
thanx and regards
sukhiii
Aug 19, 2009 | Belkin (F5D5231-4) Router
Set up my belkin g router
You may have to configure the belkin router depending on the type of ISP that you have.
Basically, you can do these to configure your router:
1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
2. turn off the modem, router and the computer for 30 seconds
3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
Lost Wireless Connection to Laptops
the internet port on the router needs to be connected to the Wildblue modem.
everything else connects to the OTHER ports on the router, never to the internet port.
you may need to power cycle both your wildblue modem and your router at this point.
Mar 29, 2008 | Computers & Internet
Belkin (F5D5231-4) Router Logo
650 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
