Question about Kenmore Elite 45986 Front Load Washer
Resetting washer after the problem is fixed
I changed the door lock after a l f code appeared but how do I reset the washer, so it will operate
  • 5,911 Answers
Did you unplug the washer at any point while you were repairing it? Normally, to reset some minor glitches with the washer all that is required is to unplug the washer for at least 30 minutes. This will reset the CCU. If you had the power secured, the problem SHOULD have gone away with the installation of the new door latch. Unless...you purchased a defective door latch, or have a faulty wiring harness. What was the error code you originally experienced? The reason I ask, is because if this is a Kenmore Elite Front Loader as the one pictured above, there is no "lf" error code. "Fdl" and "Fdu" error codes are usually the indication of a defective door latch. Could you please post back and clarify this information for me?
Posted on Sep 28, 2008
Washer door open code
Good Afternoon Friend, I am happy to assist you!
From my understanding it appears that door of your Frigidaire washer indicates it is open and your washer will not operate. If this is correct, let's attempt resetting your washer. You can do this by either unplugging it or flipping the household circuit breaker off. It is good to wait roughly ten minutes and then turn on your washer. Select a normal cycle and verify if your washer will start. If you washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it is best to contact a professional to move forward accurately. Hope this helps! - Z
Jun 08, 2014 | Frigidaire Affinity ATF7000E Front Load...
"nd" code on my washer, after I moved residence what would cause that?
Nd = no drain. Either drain pump is clogged or defective. Too many suds can also cause this problem.
Oct 05, 2017 | Amana Washing Machines
Error dL F
That code means Door lock failure. You will need a service tech to diagnose the exact problem.
May 06, 2012 | Kenmore Elite Washing Machines
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 | LG WM1814CW
My washer says that the conroles are locked. How doi fix this?
Put clothes in washer like always and pushed control button to start the cycle. No lights appeared on for any cycle or the digital timer window. The only light that remains on is the "controls locked" in the verticle status row leds on the left side of control panel. The door was closed. I unplugged and re-plugged the machine for possible reset and there is no change.
Feb 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer door is locked. cant open
If the door remains locked and you cannot open it, this could be a momentary program glitch. You can attempt to reset the Central Control Unit (CCU) by unplugging the washer for AT LEAST 30 minutes. If the door still remains locked following a CCU reset, there is a manual release you can use to open the door. The following link explains how to access the release:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
In many cases, operating the manual release will return the door latch to normal operation. If you still experience problems, or have any indications of error codes on the front panel display, please post back and let me know. I hope this helps you.
Jun 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washerhas locked door. Is there a code to unloc it? if so what is the code.
If the door remains locked and will not open, there is a manual release that you can use to open the door. The following link explains how:
Sometimes using the manual release will correct a momentary door jam problem and return the washer to normal operation.
If the door continues to lock and not open, you may also try unplugging the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes problems are experienced as a result of a momentary glitch in the operation program. Resetting the CCU can often correct most minor problems.
If you require further assistance, please post back and let me know. I hope this helps you.
Jun 11, 2010 | Kenmore HE2 Plus Front Load Washer
F dL code message
Hi, this is a failed door lock alert. the FdL code represents this malfunction in the door lock mechanism. the unit will not operate if the door lock cant engage the latch. replace the door lock mechanism asap. this will fix the issue.
Jun 05, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3 - door lock
If sound like a lid switch issue. Open the top of the washer to get an access to the lid switch(located near the doorframe). Look for a loose wire or a broken switch. In case there is no loose wire or broken switch, you should replace the switch. Good luck!
Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
F code appears, can't reset any functions
Adele, there are 13 different F-codes for this model. You will have to be more specific so we would be able to help you. In the meantime, unplug the washer from the wall, remove the bottom toe panel. On the inside of the front panel to the right locate the bottom of the door latch assy. There will be a teardrop shaped tab on it. Pull the tab down about 1/4 inch. The door will release.
Jun 19, 2006 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
387 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
