Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wd865
Hi, I turned the washing machine on and I think the bulb has gone on the display as it doesn't light up. can anyone tell me how to change the bulb and where I can get one?
Thanks.
Nige
  • DaveW74 Oct 05, 2008
    Blinking display light for a few months, now going completely.
  • tpbuildit Nov 18, 2008
    I have the sane problem. Display light flashing for some time, and now has goine completely and I am guessing what cycle I am using.
    Help.......
  • 4 Answers
Its lcd,,,,not a bulb....new board time ,,i think?1//  but hope not.,lol
Posted on Dec 21, 2008
Call hotpoint and get cover for a fiver a month. I do cause mine breaks down regularly - only 2 years old and had engineer out for this prob amongst many others
Posted on Dec 15, 2008
Hotpoint Ultima WT965 is giving me an F12 error on the display. When I switchoff and on at the plug the display doesn't come on properly, with random lighting of the digital display element. Any...
'F12' for Hotpoint (and other names made by Indesit!) decodes as 'communications error' which sounds major BUT is not uncommon in these machines and is often caused by poor contact between plugs/ cables and the control PC hence the intermittancy- just needing re-seating- by an engineer ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 14, 2011 | Hotpoint Washing Machines
The bulb has gone on my display window
a known problem in these models.
unfortunatly its not just a bulb, it's a full console you need,
part num. 1604666.
can be quite pricey but will def sort your problem.
Jul 14, 2011 | Hotpoint Ultima WF860 Front Load Washer
I want to know how to fit a new belt to a hotpoint washer/dryer wd865
Remove the rear panel of washer, and tilt washer forward away from you with someone to hold it steady.
Fit the belt round the motor pulley first and slowly feed it round the drum pulley turning the drum pulley at the same time,
It will be very tight, so watch your fingers.
It may seem to be too small, but persist with it, and it will go on.
Nov 12, 2010 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint Ultima WD865. Showing Error Code F-18. Please advise.
hi, i turned on my wd865 machine and it starts fine and sounds the same but its displayinf f 18. but it doesnt continue the wash in the usual way . what does f18 mean ? please help :)
Mar 21, 2010 | Hotpoint Washing Machines
Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
Apr 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
WD865 Hotpoint - F-05 error
F05 means that the pressure switch is jammed on full.
You need to check the pump is pumping out o/k, and if there is a filter, check and clean.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washer dryer wont stop running
unplug the machine for 3 mins and plaug back in if it still happens you might have a problem with the heating element or somthing.hope this helps.
Jan 02, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Washer Dryer WD865 - Dryer Problems
thermister blown or thermal fuse which is a black plug in the top of the dryer box or yellow sleeved wire, if it was noisy maybe the fan has come loose from it's motor. you will need to remove the dryer box on top of the drum to see if the fan is binding. you can push it back to where its not binding and tighten the nut-ANTICLOCKWISE, LEFT HAND THREAD.
usually the machine runs through a check before starting a cycle and will see an f13 and not start even a wash., so you will need to replace the blown parts.
Oct 25, 2008 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint ultima wt741
f11 keeps flashing door won't open
Sep 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint ultima plus washing machine door wont open after wash
Hi,I have a 2nd hand Hotpoint Ultima digital washing machine & cant seem to use it as when i turn it on on display screen the childlock icon flashes & beeps,even when door is open/closed,when i select a programme the icon still flashes & beeps therefore i cannot use machine.hope you can help me with my question Thanks.GILLI37
Apr 14, 2008 | Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
425 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
