Question about Motorola Mobility ROKR E6 Smartphone
Touchscreen not working properly
I have Motorola A1200 .The right most portion of the screen is not working properly..For example when i click on 3 ,2 gets clicked n when click on 2,1 gets clicked.When tok to a mobile store at one store they said need to replace touchscreen and at other store they said software needs to update..so can you please help me know whats wrong and what needs to be done..
  • Anonymous Sep 30, 2008
    i am having the same problem with my roker ever since i installed dosbox on to it is it bothering or some other issue is with it i don't know
  • crazypuff18 Oct 08, 2008
    Touchscreen of motorokr E6 is not working properly i am not able to get menu on screen ssreen celebration dose not work.
Posted on Sep 29, 2008
You can try to 'reset' your A1200 by tapping and holding the center of the screen of your phone
Posted on Oct 09, 2008
I cannot connect net with motorola cellphone
first contact with your service provider for example if airtel then talk in airtel care and ask them to provide the internet settings
Dec 25, 2008 | Motorola Mobility A1200
Motorola Ming A1200
well, let me explain,when dealing with a pda device you have two lay of screen first , the lcd, and then on top the touch screen, if the touchscreen is damage,of course, money wise it better than the lcd,bleeding,etc.. try to see first if you can do a hard reset,data will be lose, then alinged the screen,if not you can buy the part of ebay , there are not that hard to work with just take your time and be careful,using the seller can help you with instructions,if not you maybe want to see if you take it in for repair or finally resale it on ebay, at least you will get some money back.
Mar 15, 2008 | Motorola Mobility MING A1200
Motorola 1200
Have you tried calibration? (All menu>setup>screen calibration)
Do you use screen guard? If it is dirty then touch screen may not work.
Sometimes a simple restart may also solve the problem.
Feb 09, 2008 | Motorola Mobility A1200
Screen problem
my a1200 screen doesnt respond anymore wat a waste
Nov 16, 2007 | Motorola Mobility MING A1200
Motorola A1200
while pressing a number in dialing dont press it continuosly for more than 3 to 4 seconds otherwise it takes number as turbo dialing number.
In setup(in the dialing menu where numbers are displayed) there is facility of turbo dialing i.e. speed up dialing such that you provide phone numbers numbers between 1 to 9 for example in 1st number you provide number of your dad then when you press 1 continuously then your dad's number gets called. So, as you have not set your turbo dialing this message has appeared.
Nov 03, 2007 | Motorola Mobility A1200
Usb port
Hey!
First u hv to install software that came with as CD. It's easy to install , jst select the location & recommand yes option. But remember while installation USB cable should be unplugged. At th last stage it required connectivity betwn ur pc & mobl. & check in ur mobile there is USB Mode options in ur setup menu. 1. USB Modem
2. Mass storage
click on USB Modem & save it.
After instaln of softwr a new screen will appear. Pl. click on internet button it will connect through ur GPRS automatically.
Oct 15, 2007 | Motorola Mobility MING A1200
Motorola a1200 screen calibration
If the screen calibration is way off then it seems that you can't even click on the crosshair during screen calibration. However, tapping on the crosshair does seem to adjust the calibration a little in the right direction each time, it's just not obvious that anything happened. So the trick is just to keep trying - gently and repeatedly tap the same spot on the crosshair for several seconds - eventually the screen will calibrate.
Oct 06, 2007 | Motorola Mobility A1200
Screen not sensitive to touch
That\'s unfortunate because the phone is mostly touch-controlled.
Do you have a screen protector installed? Some people have said that the MING is one of the few touchscreen devices that doesn\'t work well w/ screen protectors. Try taking yours off if you\'re using one.
Aug 25, 2007 | Motorola Mobility MING A1200
Motorola Mobility ROKR E6 Smartphone Logo
190 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
