Question about Dell 926 All-In-One InkJet Printer
How to install hp 21 cartridge into dell 926 printer
I was told that the hp21 ink cartridge works with the dell 926 all in one printer .. bought the 21 and the 22 but i cant install them into the printer ..
is there something that im missing..
thanks.
apprecitat it.
    President:
  • 2,712 Answers
Use only genuine cartridges with your printer. Printers these days have a built in sensor that can sense non compatible/generic/refilled cartridges and wont install them. It will only cause you more problems in the long run if you use a generic cartridges.
Best bet is to buy genuine inks..
Posted on Sep 28, 2008
Blank prints / No print
Hi mohamed,
If it is a WiFi one, re set up the printer.
In Case You Still Having Problem Then Follow Us For On :
HP Printer Support
Jan 05, 2013 | HP 1 21 Xl Black 20ml Ink Cartridge...
Will HP 60 ink cartridge work with HP Deskjet 2460? Tnx.
This is all HP recommends for the HP Deskjet 2460, so I wouldn't suggest buying anything else. First of all it might not fit and second, even if it fits, other issues may come with using those. If you can't see the list here it is:
HP 21 Black HP 21 Black Twinpack HP 21/22 Black/Color Combo HP 21/22 Quad Pack HP 22 Tri-color Twinpack HP 22 Tricolor HP 58 Photo
Jun 23, 2011 | Office Equipment & Supplies
My Dell 926 AIO Printer will not print after installing new ink cartridge. Ink level on computer still says empty.
you must cleaned cartridge before you plug on printer, for level ink detection you must waiting for moment for ink spread on cartridge.
Mar 09, 2011 | Dell 926 All-In-One InkJet Printer
My Dad bought new ink cartridges ( black and color) and installed them in the printer and it is not registering that they are installed. What are some things I should check for and how can I fix this????
After installing new ink cartridges in your Dell all-in-one 926 printer, you may receive an error message telling you the print does not recognize the new cartridges. Refilled or third-party cartridges, which Dell does not recommend using with the 926, often trigger the error message. You may also receive this error after you have been using the same ink cartridges for some time. Whether the cartridges are new or not, the error can be caused by a number of sources. Following the steps below should clear up print cartridge problem.
  • 1
    Open the Dell 926's front cover with the power on and wait for the cartridge carriage to come to a stop. Remove the ink cartridges by pressing on the tabs at the top of each cartridge. Check the cartridges to make sure you have removed all of the blue protective plastic film. Look for the "Dell" logo stamped into the cartridges' lids to ensure they are genuine cartridges.
  • 2
    Clean the shiny metal portions of the ink cartridges with a damp microfiber cloth. Allow each cartridge to dry completely.
  • 3
    Clean out any paper, staples or other debris that you may be able to see, then reinsert the cartridges into their appropriate slots. Put the black ink cartridge into the left slot and the color cartridge into the right slot. Make sure both click back into place.
  • 4
    Close the Dell 926's front cover and turn off the printer. Unplug the power cord and USB cable from the printer for five seconds, then reconnect them.
  • If your Dell 926 fails to recognize the print cartridges after following the above instructions,
    take it to a repair shop for servicing.
    Good Luck and Happy Printing
    Jan 26, 2011 | Dell 926 All-In-One InkJet Printer
    DELL PHOTO 926- ALL IN ONE- ERROR CODE- "UNSUPPORTED INK CARTRIDGE" HOW TO FIX THIS?
    Follow the below instructions
    1. Lift the printer unit up. Position the scanner support beam between the tabs to hold the printer unit lid open. The ink cartridge carrier moves to the loading position in the center of the printer.
    2. Press down on the lever in front of the right and left ink cartridges lid. The lid opens and raises up.
    3. Remove the color and black ink cartridges from the carrier. Inspect the cartridges to ensure that it is compatible with the Dell 926 printer. The proper cartridge is called Dell 926 Standard Capacity Color Ink and Dell Standard Capacity Black Ink.
    4. Examine the cartridges for any tape over the ink nozzle. New cartridges have a strip of tape covering the bottom of the cartridge that must be removed before installing into the printer.
    5. Insert the cartridges into the carrier so the label is on top with the color logo side going in first. Press the lid down to snap it into place.
    6. Push the scanner support bar back to release it. Lower the printer unit until it is closed.
    7. Turn the printer off. Restart the computer. Turn the printer on. If the error message appears again, the cartridges may be defective and needs to be replaced.
    I hope this clears up your problem.
    Good Luck and Have a Nice Day!!
    Jan 25, 2011 | Dell 926 All-In-One InkJet Printer
    Hello,after refilling ink cartridges HP21 and
    Since HP’s ink technology is different from other manufacturers, they do not recommend to use refilled or remanufactured ink cartridges. Though the cost of genuine HP cartridges are bit expensive than the other cartridges, HP cartridges are manufactured in keeping mind the important factors print quality and customer satisfaction. Using the refilled cartridges may degrade the print quality and may damage the printer’s internal hardware.
    I request you to use genuine HP Inkjet cartridges and verify the result.
    :) Dr Tony
    May 10, 2010 | Office Equipment & Supplies
    Hello,after refilling ink cartridges HP21 and HP22,I instaled them to my HP Deskjet F4180 printer.When there is only HP22-color cartridge in printer,everything works.But after installing HP 21-black...
    Most times during a refill if you leave the cartridge out for any length of time the ink dries on the printhead or nozzels and wont allow the cartridge to print.
    You can clean it manually with rubbing alcohol or try to use the printhead/cleaning feature built into the maintenance software installed on your computer.
    Most times you will have to replace the ink cartridge.
    Regards
    Apr 08, 2010 | Office Equipment & Supplies
    Nukote Black Ink Jet Replaces HP21
    clean the brown dotted circuit of both printer and cartridge with moist tissue and then try.
    Aug 03, 2008 | Nukote Nu-kote Canon BJC 600 Multi Pack...
    Ink cartridges
    i advice you to use the compatible cartridges, else maybe can outhers cartridges make a damage to your printer.
    if you want more copies find anouther printer
    Nov 04, 2007 | HP DeskJet F380 All-In-One Printer
    Dell 926 All-In-One InkJet Printer Logo
    339 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
