Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
SHX46B I have a 4 year old Dishwasher that filled up with clean water on it's own and leaked on the floor. There appears to ba a float switch switch on the very bottom of the unit that runs the pump if this happens. It won't stop until I remove the water caught in the plastic base on the very bottom of the unit. Drain is clear and this machine has worked fine until now. I'm thinking it may be a bad or leaky fill valve but how can I check?
  • nagle9180 Oct 06, 2008
    I just bought a house with the same dishwasher and I am having teh same problem. Can't say that it ever worked properly since the dishwasher came with the house. I would rather not have to get a plumber for this, any luck with finding the problem?
catriver
  • 878 Answers
SOURCE: leaky float valve
Teresa, the water fill is usually a timed fill and the float assy. is a safety device to cut power to the fill valve in the event the dishwasher keeps filling. ( In most models). Sounds like your initial fill is just above the float lever actuator and dripping. Check the level of the dishwasher to make sure that the water is not higher toward the front. Catriver..post back.
Posted on Feb 11, 2007
  • 116 Answers
SOURCE: Leaking water on floor during drain cycle
First the source of the leak needs to be identified. pull the machine out from under the counter and remove the left side panel exposing the blue float assembly. Turn the machine on and observe the fill cycle. if water comes out anywhere on the fill mechanism then the inlet valve needs to be replaced. once the machine has filled and begun to cycle cancel the program and drain the unit. observe closly where the leak is happening. a leak during drain usually indicated a leaking drain hose.
Posted on Mar 11, 2007
zeusfaber
  • 247 Answers
SOURCE: No water filling up in the dishwasher when programme set
My instinct would be to replace the water inlet valve without even trying to prove whether that is the real problem. The valve is the plastic unit on the back wall of the cabinet that your cold water hose screws onto. I think your dishwasher takes a Universal 90 degree Single inlet cold water solenoid valve, which you can find unbranded on the net for under £10. Provided you remember to turn the power and water off before you start, there are no hidden surprises in the replacement procedure: Remove the inlet hose, undo the screws attaching the valve to the cabinet, unplug the two wires, unclamp and remove the hose inside the dishwasher, then reverse the process to reassemble. After assembly, check that the hose to valve coupling is watertight. Granted, the problem might conceivably lie elsewhere, but the valve is so much more likely a culprit, so cheap to buy and so easy to fit that you might as well change it on spec. A.
Posted on Mar 20, 2007
BIKER T
  • 909 Answers
SOURCE: Power fine, but no water filling the tub
difficult not seeing the valve firsthand but if you could connect a tester to the solonoid and confirm that there is power on the terminals, then you know there is an issue with the valve. typically, if you have a leak, it to will raise the float and shut off the valve.
Posted on Oct 08, 2007
murdozzz2
  • 75 Answers
SOURCE: model SHU43C06UC
hi there sounds like your dw is in flood protection remove the poliestirene float compleatly and make sure the lever that sits on top of it is in the down position, hope this is of some help.
pat no for new float is 165301
Posted on Dec 08, 2007
I have an older model Bosch dishwasher, model SHX46B, serial 830300124, that is leaking while not in operation. It's a very slow leak, and I think I heard and saw a drip from the upper spray arm. It fills...
Hi.
Sounds like a leaky inlet valve. Sometimes they don't seal off completely or the membrane inside it could be torn. Best to replace the whole valve.
Regards Sam
Sep 30, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
My Viking Dishwasher is about 7 years old and it does not fill with water
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Nov 20, 2010 | Viking DFUD04 Built-in Dishwasher
Dishwasher leaking
Clean the float...
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
May 23, 2010 | Jenn-Air 24 in. JDB1100AW Built-in...
I have a Neff dishwasher approx 8 years old, F light comes on and no water getting in, looked at the aquastop, undone it , checked the filter and re-conected still not working ??
Well first of all you can check the Water-inlet valve,
the water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It is usually located behind the lower access panel on the left or right side. It is the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Then you can check the Float switch, the float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it. Post comments if you need more help or information............
Good Luck!!
Thanks
Jan 07, 2010 | Dishwashers
Water fills in bottom of washer when off
The fill valve has failed. You can get a rebuild kit for the valve.
Also clean the tiny straainer in the valve.
Dec 30, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
No water coming into dishwasher
dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned. ----- There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Nov 03, 2009 | Kenmore Elite 21086
Roper Dishwasher leaks from float or float switch onto floor
you could be usiong way to mauch soap try filling only one of the soap trays or even try doing one wash without any soap at all
this unit tends to do this if you have to much soap in the unit left over from the last load...
beyond that your machine is proibaly tilted to far forward you can lift it, by lowering the front legs begind the toekick
Oct 25, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
No water?
Water-inlet valve
Float switch
Jul 24, 2009 | Dishwashers
GE Natulus will not fill with water
Had the same problem with ours today. That's why I got on here. My dad used a gallon jug to prime it with a gallon of hot tap water. We primed it to get it pumping, and now it is working fine. Just pour the hot water into the dishwasher and start it.
Nov 19, 2008 | GE Nautilus 24" Built-in Dishwasher
Leaking from fill level float riser Maytag MDB6000AWW
I have the same problems. I've noticed that the Electrasol tablets do create a fair amount of suds, so I switched back to powder.
I determined that the suds were rising up under the float and leaking around the shaft. Do not remove the float! I tried and broke the float trying to unscrew the nut. Fortunately, the new float was only a few dollars, but replacing the float did not change anything.
I solved the issue by placing a shallow plastic box under the float. I think it was the top of a box that candy came in. The amount of water that leaks is small enough that it evaporates before leaking out onto the floor.
Nov 14, 2008 | Maytag MDB9600A Jetclean II Built-in...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
101 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
