Start the washing programme and the light comes on then after a few seconds the light goes straight to the end not even starting the programme.preveiously the washer would start but not spin on the final cycle and was leaking water out under neath.
    President:
  • 2,712 Answers
Please visit this site for all troubleshooting tips relating to your washing machine:
http://www.repairclinic.com/0088_11_1.asp
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. - If you find that the solution/answerI provided led you to, or resulted in a fix, please close the ticket with a FixYa!rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Sep 28, 2008
My Fagor innovation washing machine is currently disabled by the child lock symbol we did not apply this how can it be reversed
STARTING UP AND
6
BLOCK FUNCTION SELECTION
Start/pause button
a To start up the washing machine you
have to press the start/pause button.
The minutes remaining until the end of
washing and drying will appear on the
display at all times.
Block function selection
The lock function ensures that the programme
will not be affected if any buttons are pressed.
It is used when children could press the
buttons, etc.
The block function should be activated after
the wash programme has been selected
together with all its options.
Activating the block function
a The block function is activated by
pressing the start/pause button and
holding it down for at least 3 seconds.
The display will show if it is activated.
Deactivating the block function
b The block function is cancelled when
the wash programme comes to an end.
If you want to deactivate the block
function before the end of the
programme, you have to hold the start
button down again for at least 3 seconds.
After 3 seconds, the block function
indicator will disappear from the display,
and it will go into pause status.
The ON/OFF button does not cancel
the block function
Apr 14, 2015 | Fagor Washing Machines
Hotpoint aquarius washing machine
Try unplug from electrical outlet wait 15 minutes and plug it in. If you are lucky it will reset. If you are not lucky it sounds like the circuit board may be damaged.
Apr 24, 2014 | Washing Machines
WMB 71642 W won't allow programm set
have you held the start button for ten seconds to cancel the program
Feb 03, 2014 | Washing Machines
Washing machine will not start
we had a very similar problem, our machine is only 12 months old and the filter at the bottom front of the machine has a small fan in it the filter was blocked with a coin blocking the fan from turning after reomoving the coin the fan was able to turn and the machine functioned correctly. hope this helps. tony
Jul 19, 2012 | Tricity Bendix AW1000W Front Load Washer
Zanussi 1116
I would call an appliance tech. This definately is an advanced issue required by a tech to diagnose.
May 06, 2012 | Washing Machines
The washer comes up "TEST" instead of the
Hello & Welcome to FixYa
Someone accidentally put it into TEST mode and to get it out of the test mode follow this:-- Unplug the washer for 4 minutes and then plug it back and press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off. Please get back to me if you have any other questions.
Kevin
Feb 15, 2011 | Hotpoint Aquarius WD640 Front Load...
Washing Machine will not wash
Please kindly check whether any wire is disconnected from the main board try to connect it properly.otherwise The problem may be your machine motor will be short circuited or the circuit board will be defective
Jan 05, 2010 | Washing Machines
Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Jun 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
AWM1404/4 whirlpool skips wash programmes
try some wd40 spray around timer shaft.but yot may have to replace the timer hope this helps.
Mar 19, 2008 | Washing Machines
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
