Question about Acer Aspire 4315 Notebook
REPAIR i dont have the reinstall disk and it when i turn it on it says windows error report, then it ask it i want to run it normally or in safe mode. doesnt matter what i choose the screen goes black and it will not take me to the login page it just sits there and does nothing please let me know what direction i need to go with this issue kim
  • tammyiam Nov 04, 2008
    Seems to be the same problem on my mom's laptop. I am trying the suggested repair so far it seems to be working. Thanks so much, Tammy
    Novelist:
  • 169 Answers
When you boot up, and see the Acer logo, hit ALT+F10 to begin the recovery process. The files you need are stored on a hidden partition on your hard drive. Once the process starts, just follow the prompts, but make sure that you have your files backed up first.
If not, have a PC tech remove the drive and backup your files using an external drive reader before you wipe it and start over.
Posted on Sep 29, 2008
Configuring updates screen
Try booting up in Safe Mode and see what happens.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. If it boots up ok, then do a restart into your normal windows mode.
Try running the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 08, 2012 | Computers & Internet
When the computer boots, it display bluescreen
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If after running the Check Disk Utility you still have problems you will probably need to reinstall windows. Look into doing a Repair Install so that you don't lose your data.
Apr 24, 2012 | HEWLETT-PACKARD 630 Notebook
Igxprd32 error
Apr 13, 2012 | Computers & Internet
An unexpected i/o error has occurred
Boot into Safe Mode and see if it will allow you to run a System Restore.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.If the check disk utility can't fix the problem you'll need to reinstall windows.
Apr 07, 2012 | Computers & Internet
My dell inspiron 2200 wont start up..Well it starts up but then it sais "Windows start up has failed." and it gives me options to start up in safe mode with command promt and safe mode with networking...
Boot your PC with the windows OS disk and choose to repair your computer when asked. Run the chkdsk program in DOS on the recover mode to correct disk errors.
On completion, restart your computer normally and check it it works.
If it does not work, you may need to format your pc & reinstall windows again.
Aug 02, 2010 | Dell Inspiron 2200 Notebook
Lap top computer
Sounds to me like a windows problem or maybe a driver error. if it boots up in safe mode and it dont boot up in regular mode, one of the drivers that dont have to load in safe mode keeps crashing it. check all startup programs and disable as many as you can
Oct 18, 2009 | Computers & Internet
Unable to get into safe mode
hi there !
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
cheers!
Sep 28, 2009 | Dell Vostro 1700 Notebook
When i start up laptop page says physical memory dumped pc wont start up keeps going back to star t up windows normally
This is not a printer problem but a computer problem.
You should try start up in safe mode by using the F8 key during boot up.
Once you are in safe mode you can try a "shut down and restart"
That alone just might solve your problem but from the error you are getting it could be a little more complex than that.
You may have to start in safe mode and run your antivirus and any other clean up / anti spyware programs that will run from safe mode and try again
It could even be the first signs of dying memory or hard drive but only a diagnostic check would show that as the case.
http://www.memtest86.com/
for memory or the one below for hard drives.
http://pcsupport.about.com/od/toolsofthetrade/tp/tophddiag.htm
If you have recently installed any new applications then while in safe mode uninstall them and try that too.
There are many other things you could try but these are the more common causes.
Aug 09, 2009 | Office Equipment & Supplies
Lenovo reboots
Do you have the restore disk? I recommend formatting and completely reinstalling windows. This should help you. If you need further instructions, feel free to ask.
Jan 12, 2009 | Lenovo 3000 Y410 Laptop
Boot problem
Have you tried putting in the windows disk that you have,
turn ur computer on
put windows disk in right away
your computer will boot off the disk
try repairing your windows installation,
DO NOT REFORMAT OR REINSTALL WINDOWS
hah i dont want you makin that mistake.
just repair your windows follow the directions on screen
Anything else im here to help. just ask!
Feb 08, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Acer Aspire 4315 Notebook Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
