Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
My Kitchen Aid KUDI02IRBS does not start but the lights on the panel go on for a second and then shut off
The dishwasher panel lights will come on but the cycle never starts then the lights go out.
  • erikandmeg Oct 05, 2008
    Our dishwasher will not start the cleaning cycle. I have pressed all of the cycle buttons and the options buttons, and get lights on all of them. The door closes solidly, and strangely, if I press the "cancel" button the dishwasher will start to hum, but will eventually stop, and the light goes out, and no water will have entered the washer, nor will it have cycled. The spinning arm in the bottom rotates freely, there is (obviously) power to the unit. Any ideas?
  • 2,712 Answers
If your dishwasher doesn't work at all, check these:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
  • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
  • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
Thank you for using FIXYA!
Posted on Sep 28, 2008
What is the reset sequence of a kitchen aid kudi01fl my dishwasher wont start the control lock button is on
Press and hold the heated dry button for 5 seconds to unlock the controls. If that doesn't work go to the link below and it will tell you how to reset the control board.
Good luck
Mar 01, 2011 | Dishwashers
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
KUDP02CRBL0 Pump/motor housing removal
yea its a bit of a pip....
but it comes strasight up from the bottom
and then dropped in
watch your seals
Oct 11, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
KUDI02IRBS Kitchenaid dishwasher won't start cycle
Perhaps the child lock is on. Push and hold the heat/dry button for 5 seconds and hopefully the keypad will be unlocked. Hopefully that will work for you.
Mar 19, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
"Normal" light flashes
You need a new control bd. #W10084141. If the diagnostic mode will not work then the board will have to be replaced.
Mar 06, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Oct 19, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Dish washer repair
hi there,
you'll have to manually take the water out.
do you have any error messages on the display?
if yes, please advise the exact error message.
if not, please check the drain pump for any thing stuck in it.
Sep 23, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchenaid Dishwasher Control Panel lights - some don't light up
control panel light all of a sudden do not come on and my unit wont start model kud101fl
Jan 13, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
209 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
