Question about Compaq Computers & Internet
Doesnt switch on
When switching on ,no light,computer wont start,power light is lit,also makes buzzing sound
  • gjohn47 Sep 29, 2008
    trytodoit
    thanks for reply
    it is not beeps,but a buzzing sound
    hi trytodoit
    took pc to repair shop,it was dust in black box in back of power supply,fixed ,new black box fitted
    many thanks for trying to help
    gjohn47
    Scholar:
  • 76 Answers
You said buzzing sound is this more like a beep? Beeping sound are indicative of any number of diagnosable issues, depending on the actual number of beeps and the type of motherboard.
Posted on Sep 28, 2008
  • J. May Sep 29, 2008
    It is hard to say what is going on. I have heard cooling fans buzz when they are going out. If the computer is not working I would look toward the power supply possibly having gone out. I am not sure if you are comfortable in replacing it, but if you had an extra one (or could borrow one) than I would suggest that you change it out to test. You can hook up the bare minimum components (motherboard, hard drive, case fan) to the test power supply just to check the system out without actually installing the power supply. I have actually placed two computers side by side and hooked one power supply up to the other computer to test, without actually installing any parts.
    Also, there are power supply testers on the market where you just plug them into the power supply, but I have never used one so I am not sure about these. You could simply use a multimeter to do the same thing.
    I did some additional research and there are reports that on Compaq laptops the AC adapter can go out and making a buzzing sound. I am not sure if this applies to your situation.
My r6 doesnt turn fully on disengage the headlight assembly everything turns on like normal.but then it wont turn over. I just get this buzzing sound from high and low beam relays. wiring looks fine
Hi, Sappo and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Main fuse or circuit breaker may be blown or faulty.
10. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.r6-forum.com/forums/46-general-discussions/6691-2000-r6-wont-start-wut-could-problem.html
http://www.r6messagenet.com/forums/welcome-center/161248-please-help-bike-wont-start-turn-over.html
2001 Yamaha R6 won start in Sportbikes Page 1
http://martin.lipinsky.cz/r6/files/LIT-11616-21-61.pdf
Apr 28, 2016 | Motorcycles
I have a Maytag dryer model no mde9316ayw It buzzes only
How about the door switch attached to the door latch assembly. If it does not close the device will not get power
Sep 21, 2017 | Dryers
MAY MAYTAG DRYER WONT START I HAVE POWER WHEN I PRESS THE START BUTTON IT SOUND LIKE IT SHORTED OUT
HI
Need to know what the unit does, Buzz, nothing? Because if it buzzes it could be a clogged blower or bad motor, its important to know this information.
Please get back to me
Sep 08, 2011 | Maytag PYE2300AY Electric Dryer
Kenmore 600 series dryer.model # 110.67622600. wont start. light goes on & off when i push and release the door switch. when i push the starter switch it make a clicking buzzing sound. more noise when...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Kenmore 67632 Electric Dryer
heatman101
Jun 27, 2011 | Dryers
1999 pontiac grand am - loud buzzing sound when I turn on the turn signal. Turn signal lights are lit (on) but steady, they do not flash. If its the turn signal switch - where is it located?
ON THIS YEAR 2 THINGS ARE USUALLY THE PROBLEM. THE TURN SIGNAL SWITCH OR THE HAZARD SWITCH. IT DOESNT HAVE A FLASHER. THE FLASHER IS INTEGRATED IN THE HAZARD SWITCH. ITS ABOUT 20 BUCKS FROM THE DEALER. THE TURN SIGNAL SWITCH HAS TO BE REPLACED AS AN ASSEMBLY. THE COLUMN COVERS HAVE TO COME OFF AND THE WHOLE ASSEMBLY NEEDS TO BE REPLACED
Aug 15, 2010 | 1999 Pontiac Grand Am GT
05 R1 battery fully charged wont start. make a click buzz sound then resets itself no trouble codes. all lights and equipment works. can be push started
Faulty start solenoid? Check the starter sice of this electric switch with the power on and the start switch depressed. If you have no voltage at this point, the solenoid is suspect. If you have power and no start ... jump power directly to the starter to see if it will run.
Mar 08, 2010 | 2005 Yamaha YZF-R1
1995 nissan pu wont start... everything turns on
check for power to the starter at the starter's connectors while you have someone turn the key. If there is power, change the starter. If not check your ignition switch, (manual trans)clutch pedal switch, and starter fuses/relays. Hopefully this helps
Jul 19, 2009 | 1995 Nissan Pickup
HP Pavillion zt1231s computer
you may be virus infected...or the harddrive has problem....
Aug 27, 2008 | Computers & Internet
Wont start
open the side casing of your cpu then try to switch-on, if you notice that the fan of your cpu rotates, the hdd led is lightng, the power-on led also lit then you heard a beep (one) sound there is no problem but your video card connection just loose
Jan 10, 2008 | Computers & Internet
Computers & Internet Logo
120 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
