Question about Whirlpool Refrigerators
We have ice in feezer and water dripping into refrigerator section. I think the drainage tube is cloged. How do I access and fix problem?
  • 943 Answers
Hi thanks for the question yes the drain tube is clogged . turn power off pull fridge from wall clean all coils locate drain tube in the drain tray let fridge thaw with doors open once thawed clean drain tube thanks the appliance doc
Posted on Sep 28, 2008
Water is draiNung in the refridgerator
drain tube for freezer defrost plugged, you will have to remove of the inside trim but an easy fix
Sep 02, 2012 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping in refrigerator from ice forming in top rear of refrigerator. Ice has formed below what we think is the automatic defroster and is dripping water into the the main part of the refrigerator....
You have a drain clogged at the bottom of the evaporator inside freezer compartment. You'll need to remove all contents put towel inside, turn off, pull out to access back of fridge, pull drain line off or check at bottom in pan where it normally drains, you can melt ice at top of tube with hot water,hence the towells. this is a messy job usually takes about a good hour to get it right, just perservere. I will fix it, when you get it cleared. I have employed a coat hanger to speed things along as a tech it is the call I dread because of the mess.
Good Luck,Masta tech
Aug 21, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking out of hose on a fujitysu split system ast24rga
Normally, an Air Conditioner removes water from the air and that water condenses on the coils of the inside section that does the cooling. The water condenses on the cooling coils just like moisture condenses on the outside of a glass of ice water.
This excess water drains out of the cooling section through a "drip tube" and is supposed to drain outside of the house, or a drainage system. Your "drip tube" has either not been installed (if it is a brand new installation), has separated and water is now dripping into the house instead of outside of it. Or it is clogged. This happens when algae builds up inside the "drip pan". If that is the case, you can purchase "algaecide" tablets which kill the algae that is clogging the drip pan and preventing water from draining out through the drip tube. These tablets can be found in many hardware stores, refrigeration supply companies, or even Walmart. You can put a tablet inside the pan. (You will have to remove the cover of the unit). You can often use a little bit of Bleach and that will act as an algaecide. Hope this helps,
Best, Mark
Dec 26, 2010 | Fujitsu Heating & Cooling
Leaking water on floor, even without water hooked up. Seems to be coming from under the fridge
Your freezer defrost drainage tube may not be routed to the evaporator tray under the refrigerator. If this is the case, humidity condensed from the freezer, then drained down the tube will be dripped onto the floor.
The second theory is that the drainage tube could be blocked. Humidity in the freezer is removed from the air sent to a drainage tray, at the rear of the freezer, which has a drainage tube which carries the water to an evaporation tray at the bottom of the refrigerator unit, on my GE. if the drainage tube is blocked, the water will find another route. Check the drainage tube after you find it. First try inspection. if there is standing water in tray in the freezer, use a flexible wire to clear the tube.
Oct 04, 2010 | GE Profile TPX24PBDCC Side by Side...
Hi, I have a 20.9 cf (#ET1CHK/ET1CHM). Water
I HAD THE SAME ISSUE EVERY FEW MONTHS. REMOVE THE BACK COVER IN THE FREEZER, YOU WILL SEE A SILVER TRY WITH MOST LIKELY ICE IN IT. THAW THAT ICE AND THERE IS A DRAIN HOLE IN IT. USING A HAIR DRIER GET THE TUBE TO THAW ALSO. ONCE WATER IS FLOWING TAKE A PIECE OF 12 GAUGE BARE COPPER WIRE AND SLIP IT ABOUT 18" INTO THE HOLE. WRAP THE OTHER SIDE OF THE WIRE AROUND THE WIRE COIL YOU SEE WHICH IS THE DEFROSTER. WHEN IT WARMS IT WILL HEAT THE WIRE ALSO AND KEEP THE DRAIN CLEAR
Dec 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
General Elec. refrig. about 12 yrs. old. water in bottom of frig., cleaned up, found water a second time.
drain is cloged. at some point the ref section was set too cold. the defrost water from freezer drains through the ref back wall. becaust it was set too cold the drain froze. two ways to fix .... empty unit and unplug for 24 hrs. OR remove back panel, defrost drainrail, remove bottom panel ,remove ice, insert 1/4 inch tube down drain, and squirt very hot water down drain till it is clear of ice..... when defrosted set ref on "3"
Aug 26, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
My Sub-Zero drain ices up too!
There is a drain tube heater and a floor pan heater kit for this model from Subzero
This is Not for a DIY project
Affordable Appliance Repair
Lake Forest, CA.92630
Aug 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
Water dripping inside refrigerator
the defoost drain is cloged the drain inlet is located in the freezer behind the back wall under the coils. to clear the drain remove the back wall in the freezer and clear the ice underneth the coils then use hot water to clear the drain inlet, I use a garden sprayer to spray hot water.
Dec 24, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Whirlpool fridge getting water from upper freezer compartment
well if you hat the freezer on top normaly air leaks inside freezer through the drain tube, that air turns into condensation and creates a ice and cloges your drain. now water can drain down to pan everytime ref goes into defrost , and water leaks to bottom section to air ducts and air returns. there are several ways to solve this problem the cheapeste way is to unplug refrigerator for 2 days then plug back up and it should go back to normal another way is to install a heat probe on your drain attached to your defrost heater , and add a grommet on drain tube that will let water drain but it will keep air out and that will solve your problem.
Oct 12, 2008 | Whirlpool Refrigerators
Refrigerators Logo
215 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
