Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
OSD Message Panasonic PT-50LC14 Air Filter Needs Cleaning
I have a Panasonic PT-50LC14 TV and is displaying a message ..." Air Filter Cleaning is recommended, the unit will automatically turn off in one minute ", call your service center.
How to I find the Filter and how do I reset the alarm. ???
  • cooter4 Oct 18, 2008
    I have same problem its a pain in the ---- I took in in once when the warrenty was sitll in effect, and ended up having to get the light engine replaced, now after 1 year i,m having same problem, we sometimes turn our TV off and on 15 times to get it to stay on!
I had the same problem and the stupid tv would shut off after 1 minute. We opened the silver front panel , took the bulb out cleaned it, took the cover off the grey box to the right and very carefully vaccumed the filter and wiped it off with a microfiber cloth. It works great now!!! Make sure you unplug your tv before messing with it.
Posted on Nov 04, 2008
  • d_vanness Jul 26, 2011
    I just had the same message come up. If you are a handy person you should be able to do this yourself. It does require the removal of a few dozen screws so take your time and be careful. The filter on this model is located in the back of the TV, dead center. You have to move the silver box with all the wires coming out of it, you should be able to move it out of the way without removing any of the wires. The filter housing is directly behind in the very middle of the TV. It has 2 larger screws on the top and 2 smaller screws on each side of it. Once these have been removed it should pull right off exposing the filter. The filter is held on by 4 of its own screws. Carefully remove the filter and wash it, once dry replace and reassemble. FYI on this model there is no filter located anywhere near the bulb.
  • chickenlooper Sep 05, 2012
    This worked perfectly! Thank you for the descriptive description... Helped me A LOT! escpecially when my husband said I was going to mess it all up..It works YAHOO!
I need the service manual for the Panasonic PT-50LC14. Can u help. We have to change the Blue Filter and I cannot find my service manual. Thanks
It's $38.95 at Partstore at this link
http://www.partstore.com/Part/Matsushita/Panasonic/PT50LC14/Matsushita/Panasonic/SMPT50LC14/New.aspx
Sep 28, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Lamp reset on a panasonic model pt-50lc14-k
This works for mos Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Nov 12, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic rear projection tv air filter
heres what you do remove front panel "little black door below the screen" get some software cleaner "air" clean all in that box that you just removed the cover from also you might try cue tips and alcohol let dry thoroughly put cover back on and turn on tv it should work if the message comes on again turn the power on and off about 6-10 times and turn back on it should turn on and be fine .if that happens again just open the cover and blow with sopftware clean.sound wierd but after alot of experimenting i fixed my tv that i bought as a salvage because of that error message bhope it works
Feb 19, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Temp light flashing and air filter message
there are 2 cooling fans one or both of them may need replaced,
Jan 20, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT-60LCX64 Air Filter Cleaning
Cleaning filter for the Panansonic PT-501LCX64.
I just had a T.V. tech do this. The filters are located on the two removable filters on the back side of the T.V. They look like the speaker units. He removed those two units, unplugged them & set them on the floor. He took some type of electronic cleaner with a cloth & wiped them down. The filters themselves are plastic. He explained that air flows through some tube connected to these plastic filters for cooling down below. He admitted they didn't look dirty--put everything back together & it is working fine now.
I imagine that dirty or not the timer is automatically set for every 400 hrs. of use to give you the prompt that the filter needs cleaning & will shut off in one minute so you can call a T.V. tech?
So to reset the timer--follow the other detailed prompts listed on this board & or use your owners manual & follow the prompts for replacing the bulb. That should take you somewhere to reset the timer--so you have another 400 hours of operation.
I believe it's with the T.V. turned off--hold down the down volume on your tv itself while holding the swap button on the remote control for 5-7 seconds---then follow the prompts. You should see a prompt for replacing a bulb & then one for filter cleaning. Then just reset the timer.
Hopefully this will help?
Nov 04, 2008 | Panasonic PT-60LCX64 Television
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Grennish/yellow spots pt-50lc14
I received a new blue polarizer unit from Panasonic. I installed it and it fixed my problem!!!
Duane
Apr 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
2,388 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
