Question about Husqvarna Chain Saw 20" Bar
Chainsaw bar studs
Need to know how to replace bar studs
  • Anonymous Mar 19, 2014
    Replace guide bar bolt
Empty out oil tank . you have to tap old stud out through oil tank.replace same way can be tricky but you should be able to get back in
Posted on Oct 22, 2008
  • 181 Answers
I'm guessing by the picture it's a husvarna,does it have a plastic or metal oil tank??????the differance is plastic,studs are molded together,metal they screw in.
Posted on Jan 09, 2009
2 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: Need replacement crankcase for Echo CS-750EVL chainsaw
There are 2 complete CS-750EVL saws on my local Craigslist.
Try here for Echo IPL:
http://www.echo-usa.com/pdf/documentation/CS750EVL_010185.pdf
If not your saw:
EchoUSA
http://www.echo-usa.com/documentation.asp
Type your model number into the search window.
Good Luck
Lou
http://seattle.craigslist.org/see/tls/1571477399.html
http://seattle.craigslist.org/tac/tls/1571683044.html
Posted on Jan 27, 2010
Need to remove broken bar stud efco mt8200
Broken bar stud ?
Is it the bar sprocket at the end ?
The Bar itself is easier to replace than to try and replace a sprocket, especially if you don't have proper tools.
On the other hand is it the sprocket connected to motor ?
That would be part of the clutch system.
Hope this helps.
Nov 30, 2013 | Husqvarna Chain Saw 20" Bar
I am unable to get the bar and chain off of my Poulan Pro 260 42cc chainsaw because the stud for the clutch brake housing has broken loose inside the housing. When turning the clutch brake nut the clutch...
I ran into the same problem and I "cheated" my way through this. First of all, the thread is metric on the stud. Take an imperial nut and start to thread it on the stud. Don't force it, it will stop after half a turn. Now you hold the imperial nut with a socket or a wrench, and use a flat wrench to undo the other nut(the one that is stuck). It took me 2 minutes to remove it and no damage done at all.
Hope it helps
Mike
Jun 25, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do i replace stud bolts that tighten the bar
if this is the plastic crankcase machine, the bar bolts are pressed into the case, start by removing the muffler, use a punch and drive the broken stud back through the case, it will have a square head on the rear, re fit the new stud, use a spscer and the bar nut to pull the new bolt fully back through.
Feb 11, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a craftsman chainsaw that I have snapped off 1 of the studs that hold the chain bar no.Problem is I cant work out how to remove the snapped stud. Are they screwed in or pressed in? how do I get them...
Go to: www.Searspartsdirect.com and enter the complete model number minus the decimal point. This will take you to a series of replacement part drawings. Check the drawing for the stud and see if it has a square head which would imply that it is replaceable from behind the bar bracket. Hope this helps!
Jun 18, 2010 | Garden
Threaded stud that holds chain bar broke off, how do I get it off.
If it is broken off at the saw, you need to get an ez out to remove it - follow the instructions with it. pretty unusual for both studs to break off at the same time. Hope this helps you, Rick
Apr 18, 2009 | Garden
Stihl 180 chainsaw,lack of oil to chain and bar
hi there i had this problem check bar studs make sure there tight bar must be flush on chainsaw body not on stud flange if bar is on stud flange there is a gap so oil leaks out near sprocket and not in bar oil channel
Apr 14, 2009 | Garden
Bar stud removal
only had one 20 years ago they were right hand nut side an left hand into block//used the two lock nuts tightened together to pull studs//like over tightening the lock nuts clockwise breaks stud threads loose ..install new same
Mar 16, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Stripped bar stud
Many Sthil chainsaws have replaceable bar studs. The stud threads into the case. Go here: http://www.baileysonline.com/itemdetail.asp?item=QA+0000+953+6605&catID=407
look for part by model number, usually no more than a few dollars. Enjoy
Dec 20, 2008 | Garden
Husqvarna Chain Saw 20" Bar Logo
970 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
