Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
Water spilling out on kitchen floor
I've had my frigidaire dishwasher for 1 year and 8 days. This morning, after 25 minutes of washing, I saw water all over my kitchen floor with soap bubbles and all. I tried to get the water drained in the bottom and restarted the entire cycle. Again, it filled up so high that about 20 minutes, it started overflowing all over my floor. Help!
  • 3 Answers
Sounds like a clogged drain line
Posted on Oct 29, 2008
Noisy Hoover hed6612 dishwasher
Con you check to see if the insulation over the top and sides of the dishwasher was touching the floor and wicked up enough water to get wet? That would reduce the sound dampening characteristics. It is also possible that the hose being shaken off was caused by an issued with something jamming the pump; check the drain grates to see if there is anything you can pull out.
Jan 27, 2014 | Frigidaire 24 in. FDB635RF Built-in...
Pump running continuously, Yes there was a drain pack, have emptied water, float switch clicks when moved with screw driver. Only one red light shows ( last cycle - pots ) what else can I do... James
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
Aug 21, 2011 | Asko Dishwashers
Lots of Dishwasher Issues- I have a Bosch dishwasher that is approximately 1 year old. For the first 6-9 months it cleaned perfect. It would wash everything off the dishes and leave them sparkling clean...
Do you have hard water? Many states have passed laws that outlawed phosphate as an ingredient in dishwasher detergent. If you have hard water, the detergents don't work very well anymore. The residue is probably hard water deposits (calcium and magnesium). Not harmful but it looks awful on your dishes. There are some new products that were designed to solve this exact problem. They are inexpensive and effective. Can't say the name or I'll get banned (again). Internet search will uncover it.
May 07, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a Frigidaire dishwasher that's just over 1 year old and I use it a couple times a week. I turned it on last night and went in another room. appox 30 minutes later my daughter came in and noticed the...
Someone squirted dish soap in there instead of regular dishwasher detergent...
You will need to manually rinse out the soap and use the right soap...
heatman101
Sep 18, 2010 | Dishwashers
New Whirlpool Dishwasher filler overflows.
New Whirlpool Dishwashers will NOT accept the same "volume" of water that was desired by the same products of 25 years ago. Therefore the old 3/8" ID copper supply is too large and will overflow the tub filler/aireator (out the air vent holes). I just installed a new dishwasher supply kit consisting of a new 3/8" OD stainless braded hose with an ID of about 1/4". This delivers less volume than that recommended (in the installation manual) and therfore does restrict the flow a bit. However, the flowrate is adequate and the new dishwasher now works perfectly with no water overflow on the floor . . .
Dec 26, 2009 | Dishwashers
My Kitchen Aid dishwasher runs for about 2 hours. Is this normal
It depends on your water pressure. Mine runs a cycle in about 25 minutes, with 92 psi water pressure. Before changing all the pipes in my house, I had about 30 psi and it took about 45 minutes. The longer it takes to fill, the longer it takes to do a wash.
Apr 06, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
How can I shut off the water supply to the dishwasher? It fills slowly with water from the top (while not running), and then water spills out over the kitchen floor. By pressing the 'Drain' button, the...
Most water supply lines are attached to the hot water supply under the kitchen sink. If not it may be accessible from the basement somewhere under where the dishwasher is located.
Regarding the issue with the dishwasher, the inlet water valve is no longer closing because of the limescale that has built up inside. That is why it fills on it's own even when it's off. Instead of replacing the dishwasher you could just replace the inlet water valve if you want to get a few more years out of it.
Feb 27, 2009 | Sears 24 in. 14181 Built-in Dishwasher
New installation - clicks on wash cycle but no wash
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Call Frigidaire and explain that you never used it till today because it was in storage from day one. that you had to ship out to Iraq! now your home and it came out of the box dead!!!!!!
this way the supervisor will fix it for free!!!
For this problem you will need to use factory service!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire Dishwasher Problem
by the sounds of it.i think the water inlet valve that lets water into the machine has gone faulty leaving water slowly seep into the machine, you could either replace this valve..or a cheaper solution if you can access the rear of the machine most water supplies would have a small value installed on the incomming supply,you could simply turn off the water till the next time u need to use it.
Jun 28, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
454 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
