Question about IBM ThinkPad R52 Notebook
Touchpad problem actually i ve IBMR52 model laptop my touchpad is not working but in bios setup touchpad&track point are seted as autometic but still it is not working then what can i do? plz help me
  • 1 more comment
  • satya121 Sep 29, 2008
    which size of memory
    plz tell me how to cheak
  • Anonymous Oct 04, 2008
    Hi Buddy..............
    I have the same problem please help urgent......................
  • murihwengg Oct 15, 2008
    1860 model
Hi, the first thing I would check is the size of memory if it is less than 384 then you may need an upgrade to say 512. Although you may not have had this problem before as the system gets loaded with stored data this can affect functions such as keyboard and mouse as it puts a strain on a small memory. Hope this helps
Posted on Sep 28, 2008
I can't find a button to disable my touch pad on my laptop. the mouse cursor will jump around all over the page.
Hi dwain_ritchi,
Changing the pointing device settings in your laptop's bios is the easiest way to disable the touchpad. Please follow the steps below for additional information:
1. Turn on your computer. Press F2 when Dell logo comes up. It will open the bios setup program.
2. Now, press Alt-p three times to get to page number 4. Near the middle of the screen you should see an option called Pointing Device. Please change it from touchpad - PS/2 Mouse to just PS/2 Mouse (this also works fine with USB mouse). Press ESC to exit the bios, make sure to save the changes.
Hope it helps.
Thank you for using FixYa.
Mar 29, 2011 | Dell Inspiron 1300 Notebook
I have a compaq 620 and would like to turn OFF the mouse / track pad under the keyboard... please help!
Try these solutions: > 1.. F10 to enter bios setup at boot time
> 2.. Advanced
> 3.. Device Options
> 4.. Dual Pointing Devices
> 5.. Use arrow keys to select the pointing devices you want enabled
> 6.. F10 to save settings
> 7.. File-Save changes and exit
> 8.. F10 to confirm
>If the Synaptic's Touchpad driver is installed
touchpad/point stick can be
>enabled/disabled via the mouse properties in the control
panel applet.
Or:
> 1.. Start
> 2.. Control Panel
> 3.. Mouse
> 4.. Device Settings Tab
> 5.. Select the device and click on the enable or
disable buttons. "
If this helps, please rate. Thank you.
Jan 18, 2011 | Compaq Evo N610C Notebook
How do I disable the touchpad on my Dell Ispiron 1300
Hi jweav66,
The easiest way to disable the touchpad is by changing the pointing device settings in your laptop's bios. Please follow the steps below for additional information:
Hope it helps.
Sep 30, 2010 | Dell Inspiron 1300 Notebook
My cursor on my Dell inspiron 1525 laptop is stuck in the middle of my screen the touch pad isn't working either I was wondering how i could fix this
Try an external mouse. You might have to turn off the touchpad in BIOS (F2 key on boot will get you into setup). Look for Mouse/Touchpad under 'Post Behavior' or perhaps elsewhere (differently displayed in various BIOS setups).
Apr 23, 2010 | Dell Inspiron 1525 Notebook
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
Problem with mouse in my new Dell laptop
Touchpads
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | Dell Inspiron 1420 Laptop
My touchpad has stopped working. Device Manager
Comment back with Make and EXACT model
Mar 24, 2010 | Computers & Internet
Satellite P505 Model S8980 - unable to get TouchPad to work now where it did work before. The TouchPad ON/OFF button nor the Fn+F9 approach are no help. A USB-connected mouse worked fine, tho. Just no...
----- control panel - mouse - see if touch pad disabled there ----- have a look in the bios/setup and see if the touch pad is disabled there, as the PC boots - you should see which key to use to enter the bios/setup F2, F10, DEL KEY are often used ----- On some machines a combination of FN and F key can disable/enable the touch pad - F7 or F9 ----- If you point the mouse to the top of the screen you may get a menu dropdown, which will also tell which key to use to disable/enable the touchpad ----- control panel>system>{vista}lefthand side device manger or {XP}hardware>Device Manager>Mouse and other pointing devices>Touchpad>highlight touchpad and right click, Properties, may be an option here to Disable/enable,
Feb 18, 2010 | Toshiba Satellite P505-S8950 Notebook
Hi.my touchpad don't work at all!!I can't do anthting with my touchpad.
The pad may be defective buy a cheep wireless usb mouse for it and use it to work without the pad. the pads do wear out and the replacement would be over a 100 Bucks.
Jan 15, 2010 | Acer Aspire 5100 Notebook
Touch pad possessed.
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
For extra USB ports, purchase a USB hub($15 -$20). That way you can add at least 4 USB ports to your laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 19, 2008 | Toshiba Satellite A135-S4527 Notebook
IBM ThinkPad R52 Notebook Logo
363 people viewed this question
Top IBM Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
