Cartridges won't eject from cd player
I have a pioneer multi-disc cd player, model # pd-tm1. the cartridges won't eject & it willno longer play the cd's. any idea how to fix it? yes, i know it's OLD...but i like it!!!! help!!!
  • 5 more comments
  • maggiecolusa Dec 01, 2008
    we have had the cd player disconnected. we have even replaced the laser reader/ pick-up assembly, but it still doesn't work.
  • maggiecolusa Dec 02, 2008
    we have opened it up & were able to remove the cd's, but, i want to know how to fix the player. thanks.
    we tried to use a cd lens cleaner, but, it won't read that either.
    it will neither read the cd, nor eject the cd cartridge
    that's why i want to know how to fix it. yes, it is old, but, it is an 18 disk player, which i like. i don't want a 5 or 6 disk, nor do i want a jukebox type player. i want ideas on how to fix this one. thanks.
    yes, it is called a magazine. we did get it out of the player, but, i want to know how to fix the player. thanks.
  • maggiecolusa Dec 03, 2008
    i appreciate your resonse
    Genius:
  • 1,239 Answers
If you are good at opening the player then just follow this steps...
1.take of the screws
2.remove the cover
3.take off the rubber belt connecting the dc motor
4. now you can take the door out by sliding one white coloured clip
5.now clean the obstacles in the door way and every where
use dry clothes..
6.clean the lens also by using the white petrol or spirit....
then reassemble just put the cd and play...
90% it will work
if you are not good at opening then contact the technician........
Posted on Dec 07, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 07, 2008
    i've had cdj-100s for a while and i am familiar with cd loading issues... flip the turntable, on the underside there's a sort of key, it's ur CD eject pin, u take that and poke it in the hole in the front... that should take care of the stcuk cd, now the problem i'm having is, IMO, a derailement in the ejection system.... basically what's happening to us is that the 100s is in CD in mode... I've tried the key method, i think mine is totally all over the place, i've pressed eject and kinda pushed the cd in, i got it to run, play music (so lazer's not broke) and it would eject fine but then automatically go back to CD in mode and lock the drive.
    President:
  • 1,257 Answers
If its not ejecting the tray then there are 2 reasons for that
1. Gear that is used to eject has gone bad 2. The belt which is also used when ejecting the tray..
Try to put some Lubricating Grease on the gear and it should work fine.
  • 6,487 Answers
I think all the possible troubleshooting and and replacement of some parts are already done and it will only lead to a conclusion that you need to get a replacement player already for this old machine and let it already rest its been more than 10 years already...
  • 586 Answers
    Actueally ther are two problems found in you cd player.
1- The lens of the player need replacement.
2- The mechanical of the player cd portion mechanically unstable.
For first problem you need to replace the lens.
And for secod problem the mechanical adjustment is required which could be done by any expert.
Therefore contact anyexpert nearby, Because this mechanical adjustment would not be done by yourself it a technical method.
Thanks for using fixya.
Posted on Dec 02, 2008
  • 4,806 Answers
I have looked everywhere for a user manual or service manual for this pioneer model without having to pay for them. Because its an old machine there is not much information on this unit all i though i wouldn't be much help until i found this manual translated from german!!
here you go!!! if you can print web pages is suggest you do!
http://translate.google.co.uk/translate?hl=en&sl=de&u=http://www.aswo.nl/downloads/pioneer20abgleichanleitung20lasereinheiten2005.pdf&sa=X&oi=translate&resnum=6&ct=result&prev=/search%3Fq%3Dpioneer%2Bpd-tm1%2Boperators%2Bmanual%26start%3D20%26hl%3Den%26sa%3DN
regards
  • 1,512 Answers
Hi there
If the cartridge does not eject, then the loading mechanism may be damaged. The fact that it does not read discs also may point to this as well. The load mecha has a sprung assembly driven by a cam. With the lid off can you see if the discs are fully loaded, or just partially. If you have replaced the laser, did you also remove the protection short(a blob of solder) that protects the laser diode from damage associated with static discharge. Laser assemblies are very sensitive to this, and all pioneers have this protection short. Another common failure in Pioneer players is a lazy spindle motor causing the CD to not spin to speed, and or not start at all. perished rubber suspension boots that the laser transport sits on will also cause the disc not to spin up. If you hear a high pitched scratchy screechy noise, then this often points to the CD not spinning correctly, or a motor problems.
Having been a Pioneer Service agent for many years, I have fixed hundreds of Pioneer CD players, and am sure that I can assist you. Perhaps if you can get back to me regarding the symptoms a little more, We can get to the bottom of your problem and get the unit playing again.
regards
robotek
  • 2 more comments
  • Graeme Ross
    Graeme Ross Dec 02, 2008
    Another thing to check with the magazine jamming is to look at the point where grey vanes hinge out from the magazine. If you see the plastic dimpled near the hinge point, then the magazine may have had all the vane3s opened at once, this damages the locking mechanism producing the dimpling, and eventually result in jamming of the vanes in the mechanism. If there is a faulty magazine, then this may have also damaged the load mechanics. I weill wait to hear from you as to what you see happening with the load cycle.
    regards
    robotek
  • Graeme Ross
    I am trying to recall the model of laser used in this unit. If it has a detacheable strip, that too should be replaced. If it does not have a detacheable strip, then the defraction grating and offset adjustments will need to be swet. The grating in particular. This can only be done with a test standard disc, and oscillascope from test mode with a low pass filter in place.
  • Graeme Ross
    If the load lever is not pushing the disc vanes of the cartridge fully in, the lever is in 2 parts and lock together with a ball bearing. If the hole the bearing sits in becomes worn, it may pop out preventing the arm from travelling the full distance required. You will need to remove the transport and replace the load arm to resolve this. Do you have a service manual there to assist you?
  • Graeme Ross
    Graeme Ross Dec 03, 2008
    Hi again, the link in the solution you have awarded the FixYa to is just alignment details only for the optics. Because of the series of laser (PEA1285) fitted, alignment procedures are minimal. Only the tangental adjustment needs to be set. This will not help you to resolve the mechanical load problems you have. Was it you intention to award the FixYa to Leecom.
  • 2,794 Answers
Is that the multi disk CD player that loads the CDs into a cartridge looking thing called a magazine?
If so. Look for a small little hole around the magazine. Take a paper clip and insert it into the hole. The magazine should release itself from the unit.
That is a manual eject feature on the player.
    Sergeant:
  • 217 Answers
For removing the stuck up cartridges u can open the device and remove it but.as u said its old but now its the time to get new 1 because there is no garantee that after u remove the cassette by opening the device and when you play next time it will open,.tap the device from all the sides and try it gets opened many a times.
    Sergeant:
    Champion:
  • 347 Answers
Hello Maggie,
When you say the cartidge wont open, do you mean the disc tray?
If so let me know for further assiatnce Dahaka
Posted on Dec 01, 2008
    Master:
  • 763 Answers
Sir if you manage to open or eject your cd from your player then i would suggest that you use a cd lens cleaner. maybe the problem is the cd lens thats why its not reading anymore.
thank you for using fixya
CHARCOIS
    President:
  • 2,110 Answers
You have to open the screw to open back side of player there u can try to remove the CD's those were stucked inside..
  • Sibananda Jena
    Sibananda Jena Dec 07, 2008
    You have to open all the screw to un pack the back cover...then u can only take out the CD that stucked inside...
    Genius:
  • 3,422 Answers
HI,
Please unplug all the cords of your player,even the power cord for 1 hour.After 1 hour plug them back in and turn on the player.It should eject the disc.
Let me know the result.
Pioneer PD-M306 cd changer will not eject
That is why they don,t manufactur them any more, There has been nothing but (Problems) With them doing that. It is out of (Alighnment) Just look for a good used one, You can buy a used one for $10to $ 50, To get it (Repaired) Your looking at $50 to $120,
Oct 22, 2012 | Pioneer Audio Players & Recorders
Pioneer PD-M501 6-CD Player manual and what magazine cartridge
CDs go in the Upside Down position. Your PD M501 will accept PRW 1139, PRW 1141 and 163.
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM
May 15, 2010 | Pioneer PD-M603 6-Disc CD Changer
My Pioneer PD-TM1 18 Disc player reads through all three disc magazines searching on each individual CD disc one at a time, and then will not play any one of the disc?
Seen alot of these "drop" the laser lens inside the unit! Have had some luck glueing the lens back on using radio/tv cement. Don't try super glue or it will ruin the lens! No luck replace the laser!
Apr 12, 2010 | Audio Players & Recorders
The standard cartridge for the Pioneer PD-M501 is the Pioneer JD-M300 6-disc magazine, and you can find them at Amazon.com for $25 new. The JD-M300 fits a lot of different brands of CD players, not just this particular brand and model. And here's a link to a copy of the owner's manual: http://www.scribd.com/doc/22613342/Pioneer-PD-M601-M551-M501
Mar 26, 2010 | Pioneer PD-M603 6-Disc CD Changer
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Many Magnavox, Denon, JVC,
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
Pioneer PD-F805 can`t read discs.
Few things either cd,s are not compatible
laser has died or laser ribbon cable is broken
Jan 07, 2009 | Pioneer PD-F805 CD Player
210 people viewed this question
 Grubhead
Grubhead
