Question about Philips 26PF5320 26 in. LCD Television
PHILIPS 32PF7331/12 LCD TV
REMOTE LOST ALL I NEED TO DO IS GET TO THE HD CHANNEL AS MY SKY REMOTE OR TV BUTTONS DO THE REST IS THER A MANUAL WAY TO GET HD CHANNEL WITOUT REMOTE PLEASE
  • Anonymous Mar 12, 2014
    samsung flatscreen tv
  • Anonymous Mar 21, 2014
    I need answer on my question,if you can help me please
    My Philips TV at once change channel what is that?
    I dont now is the tv or controler?
    Thx a lot
Press tv on sky remote then press help ,channel list appears . goto tv set use onset channel change button to scroll to hd channel .press volume up button onset to select.
Posted on Sep 29, 2008
Digital tv channel stuck on Setup blue screen
Just contininue to try that it if not then you'll have to do a hard reset.
Feb 01, 2014 | Philips Televison & Video
I have an LCD HDTV BLA. I have Freeview and
Hi.
If you are using an external freeview box you need an HD box (See available products).
If you have an LCD TV with built-in HD tuner (TV will say HD Ready and will have internal tuner), then you can use the TV internal tuner.
The best way to get HD is via satellite. Althought HD Freeview is theoretically available since end 2009 I have not been able to receive any HD channel using Freeview tuner, and I live in a London area where HD FV is supposed to be available since 2010.
Even with Free Sat the choice is poor. You get steadily only BBC HD, where at most you can watch some documentary or drama series (it is a kind of sample channel). ITV HD, BBC1 HD and the rest frequencies on Astra change Sat quite often. I am a TV technician and the sat tuning job is not difficult to me but retuning every month was still an awful waste of time.At the end I gave up and I only watch HD through Sky.
At the end of the day the only efficient way to receive HD TV is still through Virgin or Sky.
Regards.
Ginko
Sep 01, 2011 | Samsung Televison & Video
My philips hd tv does not have a picture . only
Do the channel controls work? If not, then try going into the TV's menu and find the factory default reset function. If that solves the issue, you may have to do that every time you turn your TV on.
Just as with almost every other issue, I suggest you get in touch with the manufacturer for proper assistance.
Jun 03, 2010 | Philips 32PFL7332D 32 in. LCD HDTV
I need to change the source on my tv to HDMI without my remote
Not sure if yours is the same but Philips codes work with Skyworth and if you hit the TV/AV button on the side of the TV and the table of options should come up. And then with the channel +or- go up and down till you are on HDM1 or where ever you want and then touch the TV/AV again when you are there.
Mar 27, 2010 | Philips 32PF5531D 32 in. LCD Television
I am running a Sky + HD box through my television Hitachi 26LD6600 using a HD lead. I have balanced the sky remote to the tv, but whenever we turn to Sky/digital tv we have to manually change the tv...
Hi, without a manual to hand, i don't know, but my Panasonic had the same problem, but I found somewhere in the settings, I could change it, it has something to do with AV and Digital TV and hdmi setup, give it a check.
I hope this helps to some degree, but give us a shout if you require more help.
Regards - Anthony
Feb 06, 2010 | Hitachi 26LD6600 26 in. HD-Ready LCD...
The tv does not respond to some buttons on the remote but does to others. The ones not working are Power and Channel but Volume and Mute work. New batteries make no difference.It is a Phillips tv with...
There is a way that you can check the remote buttons are working.
Get a mobile phone with a camera on it.
Set the phone to camera mode.
Whilest looking through the mobile. point the the Tv remote at the camera phone and press each button individually. what you will see on your mobile is a light coming from the remote for the buttons that are working. If certain button are not working you will see no light through the camera phone. If this is the case you may need to get a replacement remote.
If you do need to replace the remote this can be quite expensive to buy from the manufactor. So what I would surgest is getting a sky remote off a friend or family member. or even Tesco. argos. It does not matter what the remote is ie Standard, Sky+ or HD remote. (which ever you can get cheaper) The reason behind this is Sky remote have a default code in them to work PHILIPS tv's. When you get this remote if it does not work your telly straight away. What I would then do is remove the battery's from the remote for a minimum of 10 minutes that way it loses the code someone has set it up for and defaults back to Philips Code.
All of the above will sort your Problem out.
Thanks Little Dish Fitter
You owe me a Pint. : )
Sep 24, 2009 | Philips 19PS50S 19" TV
Philips LCD TV wont change aspect ratio
In your philips menu there is an option to turn of your auto aspec ratio to OFF then using your sky remote go to services, 4 then picture and ensure that this is set to 16:9
Job done
Cheers
Little Dish Fitter
Dec 24, 2008 | Philips 32PF7321 32 in. HDTV-Ready LCD...
Logik L22LID18 22" hd ready digital lcd tv with ipod dock 7 dvd
Logik TV Sky codes; 1065 0908 1245 0726 0399 0039 0221.
Dec 08, 2008 | Directed 434MHZ Remote Control
Television
you can press both volume buttons on the set to bring up the televisions menu. From there you can use channel and volume buttons to navigate the menu.
Sep 15, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
Philips 26PF5320 26 in. LCD Television Logo
635 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
