Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Refrigirator not cooling up
My refrigerator is not cooling up and no ice maker
  • bkargo Oct 02, 2008
    My refrigerator stopped cooling. This has happened 3 times before and I simply unplugged and thawed the unit for 2d (although a pain in the *** moving everything to a temporary cooler). After replugging it in, it worked previously. But this time, it is not working. Refrigerator lights are on, but it is not 'kicking on' and cooling. What up?
  • larrydarks Jan 27, 2009
    All of a sudden, my refrigirator & freezer are not putting out like they should.( I first noticed the ice cream soft). I have cleaned all the cooling grates, bot no change yet. It seems to be running all the time..(probably trying to keep up)
I have had the same problem with my fridge. I have a Whirlpool that is about four years old and it started to make a clonking noise a few weeks prior to it stopping cooling. I spoke with a few people and they said that it is usually the start device relay. I purchased a new one and it took off and worked great for almost two weeks. Well last night we found our food in the freezer thawing again. We had heavy rain storm and the electricity flickered a few times. I was told that it could have damaged the new relay I just put in. I purchased another one today and it is now running fine again. I also had the capacator checked to be sure that it was functioning fine. At $60 dollars a crack I hope that this is not going to happen again any time soon. This relay assembly is located on the compressor (big black roundish tank looking thing). Be sure to unplug your fridge then remove the cardboard cover from the back of the fridge and it should be in plan site. hope this helps.
Chris
Posted on Oct 03, 2008
Refrigerator drips with water
Is the ice maker overflowing? Have you checked the waterfilter to see if it is leaking. These are the things you should rule out before going any further.
Jul 28, 2014 | Frigidaire Refrigerators
I own a Frigidaire refrigirator model PLRS267ZA and the ice maker gets stuck / frozen mid ice making then starts to click because the gears can no longer turn. is there any way to fix this or do i have to...
It is best just to replace the ice maker. there are many small parts in the ice maker. You may be able to purchase just the gears but they are usually a factory order.
Jul 14, 2014 | Frigidaire PLHS267ZA Side by Side...
My Frigidaire side-by-side refrigirator is not making ice
Here is a simple tip that may help you decide what is causing this problem. If the ice maker has no ice cubes in the slots fill with tap water and allow water to freeze. If the ice maker cycles and drops the ice into the ice bin and then does not refill with water the problem is the 241734302 Water Inlet Valve (providing that the model number above your post is correct) If the ice maker only sits there with ice in the slots and does nothing the ice maker is the problem 5303918277 Ice Maker Assembly Testing the water control valve is as follows. I will be here to answer any questions you may have, Thanks Sea Breeze
Apr 26, 2013 | Frigidaire FRS26H5AS Side by Side...
Samsung Refrigirator RS2545SH: Installing my ice maker when I heard several clicking sounds, I realize I forgot to unplug my refrigerator before installing my new ice maker. After plugging back my Ref I...
First lets check the wiring plug under the top left hinge cover to insure the connection is firm and then check connections at the motherboard. Let me know what happens, Thanks Sea Breeze
Samsung Refrigerator Familiarization
Dec 13, 2012 | Samsung Refrigerators
I get ice build up in lower shelf of freezer and water leaking into top shelf of refrigirator What should I o?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 02, 2011 | Whirlpool Refrigerators
My refrigirator Frigidaie FRS26H7CSBO started by not making any ice,, then made ice but put to much water that the water came from the ice maker into the door and now the freezer and fresh food side...
I would suggest you unplug it for maybe 15 minutes before restarting. If the condenser is caked with ice maybe a couple of hours would get it defrosted.
Jul 04, 2017 | Frigidaire FRS26H7CS Side by Side...
Refrigirator is not cooling. Freezer is cooling
if you have a bottom freezer, you need to defrost the unit the cool air from the freeezer is what cools the top part, but the channels are iced up
unplug the unit and let it thaw out overnight
Sep 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
The evaporator is full of ice and refrigirator is not cooling
most likely a faulty defrost heater. problem is creating blocked air flow.
Jul 26, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
It stopped working
hard to say could be a defrost problem, starting components to compressor or compressor, if its not very old i would get a tech to look at it.
Apr 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
94 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
