Question about Gateway MT3705 Notebook
Where is the small cmos battery located in the mt3705 notebk gateway?
  • Anonymous Mar 30, 2014
    Video of cmos battery on gateway laptop
    Location
  • Gateway Master
  • 4,338 Answers
You can purchase the service manual here.:
http://www.9manuals.com/
Posted on Sep 28, 2008
Where is the cmos battery located in a gateway m255-e laptop
open the top key board then under this key board you located the cmoslb_icon1.png battery and jumper settings..good luck
How to change Gateway M255 PC Notebook cmos battery Where is the mos...
May 14, 2014 | Gateway M255-E Notebook
CMOS location in gateway model # 6332
The CMOS battery on the Gateway M-6332 is located either next to or underneath the WiFi card. With the laptop upside down, loosen the three screws along the rear edge of the panel next to the fromt of the laptop. Remove the panel and you'll see the hard drive and the WiFi card. There will be one or two Mini PCI Express slots. I've replaced the mainboard in this one, don't recall if the original only had one slot, the one I installed has two.
That's where the CMOS battery is, held to the board with a piece of double sided tape and connected by a pair of wires to a small plug.
Jan 21, 2012 | Gateway Computers & Internet
What is the correct battery for the BIOS memory for a Gateway model 4025GZ notebook ?
http://cgi.ebay.com/GENUINE-ACER-250-REAL-TIME-CLOCK-RTC-CMOS-BATTERY-/250619795738?pt=Laptop_Batteries&hash=item3a5a1a991a
Method.
When your Gateway computer is switched off, it still keeps track of various system information such as the date and time, thanks to a small battery that never powers off. The size and thickness of a dime, the CMOS battery can run out and need to be replaced. You can swap out a dead CMOS battery with a new one by removing the Gateway computer's side access panel.
Difficulty: Moderate
Instructions Things You'll Need:
  • Phillips-head screwdriver
  • CMOS battery replacement
  1. 1
    Shut down the computer. Remove the power cable from the back of the computer case. Disconnect the cables for the monitor, mouse, keyboard, and printer.
  2. 2
    Set the computer case over on its side. Use the Phillips-head screwdriver to remove the two case screws at the far left end of the case.
  3. 3
    Slide the side access panel to the left and remove it from the computer case. Find the CMOS battery port, which will be located to the lower left of the processor in most Gateway computer models.
  4. 4
    Lift up the plastic clip holding the CMOS battery in place. Slide a fingernail under one side of the battery and lift it off the motherboard port.
  5. 5
    Check the orientation of the new battery and compare it to the CMOS motherboard port. Push the new battery into place in the same direction that the old battery was facing. Push down the plastic clip.
  6. 6
    Set the side access panel back onto the Gateway computer case and reattach the case screws. Plug in the Gateway computer and power it on.
Jan 01, 2011 | Gateway 4025GZ Notebook
Where is the battery located on the gateway computer
hi gilbert
depending on the model of your laptop, then battery can either be found at the bottom clipped or in the laptop itself enclosed like your RAM.
here are some reference you may want to look at.
http://www.laptopbattery.net/gateway/
http://www.gateway.com/battery/
regards
Jun 19, 2009 | Gateway MT3705 Notebook
NO TPM OR TPM HAS PROBLEM
Here how to fix this issue:
1. Disconnect the power adapter.
2. Remove the battery.
3. Unscrew the back cover for the hard drive.
4. Disconnect the CMOS battery for a few minutes. (the battery is located under the the small circuit board.)
May 15, 2009 | Gateway MT3705 Notebook
Unlock my laptop
You have three options.
  1. Disassemble the laptop and remove the cmos battery and put it back in.
  2. Reinstall windows, put your windows CD in the drive and restart your computer. ( all data well be lost)
  3. Take it to a shop, for $20 they reset it for you
Jan 17, 2009 | Gateway MT3705 Notebook
Bios paswerd unlocker
if you have a PC all you have to do is remove and replace the CMOS battery.
Jan 14, 2009 | Gateway MT3705 Notebook
Locating bios battery
you would have to open up your laptop. its located on your motherboard. If you are not familiar with cracking open a laptop, I don't recommend it to you.
Dec 07, 2008 | Gateway MT3705 Notebook
Gateway 450rog cmos battery
The CMOS battery is located on the motherboard, just under the bottom left side of the keyboard, by the letter 'V". It looks like a clock battery, marked 3V (volts). The battery comes out of its "cage/connector" by gently lifting it with a small flat screwdriver. Replacement CMOS batteries are inexpensive and readily available at any computer shop. Hope that helps
Mar 15, 2008 | Gateway 450ROG Notebook
Troubleshoop Laptop
hi, power on laptop with pc???? thats not clear to me... BUT with ur laptop not powering on, try to locate the small lethium battery, and replace it.. that should work.. let me know
Nov 25, 2007 | Gateway MT3705 Notebook
Gateway MT3705 Notebook Logo
179 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
