Question about Tomtom GPS
Won't stay turned off. Locked into one location, will not locate itself. Nothing's right shows 34mph when sitting still.
Hello Fixya, I did nothing to repair the problem. The battery ran down and the TomTom could do nothing but turn off. The next morning I took it out doors and it started receiving the signal and found its location. Has worked correctly all day today, We'll see. Thanks for your concern, it just seemed to correct itself. Hope so. Cyssie
Posted on Sep 30, 2008
Brush won`t spin on brand new vacuum
Hi! Many of our vacuums include a brushroll shut-off feature that needs to be activated in order for the brushes to spin. The brushroll shut-off pedal is usually located on the right side of the cleaner on the hood. Your instruction manual will show you exactly where your brushroll shut off pedal/button is located if your vacuum has this feature. Also, on many models the brushes will not spin when locked in the upright position. The handle must be reclined for the brushes to spin. Hope this helps!
Jun 13, 2014 | Hoover Vacuums
Turn signal light right flash
flasher/blinker is busted. this is located under your dash board. remove steering column cover, turn on LEFT turn signal (yes, the one that is working), then you will hear a clicking sound. locate the relay that causes the sound. there you can see 2 relays (one for LEFT, other one for RIGHT turn),replace busted one.
Jun 11, 2013 | 2002 Toyota Tundra
Turn signals right side won"t work.
check fuses and relays first..... if all good, try replacing the flasher itself.
google images will help you locate.
Jan 29, 2013 | Cars & Trucks
My filter located in the ball does not stay locked in
I'm sorry to hear you're having difficulties with your DC25. If the filter won't stay locked in place during use, it's probably best if you get in touch with us directly so we can resolve this as quickly as possible for you. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
JackDyson Online Customer Support
Sep 22, 2011 | Dyson DC25 All Floors Bagless Upright...
2001 aurora won't start at all. Hook batery up horn horn sounds and doesn't stop head lights stay on but nothing happens when the key is inthe ingition. No clicking or anything at all. alarm on...
The security system does not disable the starter, it only disables fuel to the engine. In the fuse block under the hood, locate the STARTER relay. Place your hand on this relay and see if it clicks while someone else turns the key to start...if the relay is ok then the starter itself is faulty. Good luck, i hope this helps.
Jul 11, 2011 | 2001 Oldsmobile Aurora
I have a 1999 gmc sierra with (as of 30 days ago cat. converter, fuel pump and filter, cap and rotor) changed in garage. regular oil changes, tune ups as of 8 mths. it has lots of cranking power, but...
If i understand you right the truck has been sitting for two years.If it has been sitting that long without running or moving the gas has turned to varnish...I suggest that you drain and refill the fuel tank,and replace the fuel filter located on/in the frame rail on drivers side.
Jun 18, 2011 | 1999 GMC Sierra
Show map does not show current location
im going to assume the satellites are not locked on.
look up at the top right corner of the map screen, and there should be atleast 4 green bars..if not, the satellites have not locked on to your position yet and wil show the last location you were at when i lost the satellites.
take the unit out side in clear view of the open sky and turn it on, then hold the power button for ten seconds. after it turns off, hold the power button till it starts. let it sit outside for up to 30 minutes to aquire the satellites.
if that fails, go HERE and download and install the latest update. just follow the install direction and it should fix it.
Sep 30, 2009 | Magellan Maestro 4040 GPS Receiver
5 blinks, Sony KP-65WS500 stays up only with one CRT gun at a time....
5 times blinks shows White Balance error in tv. You need to adjust Screen Volts (G2) and problem will resolve. Screen volts controls located at Focus Block as shown in below picture.
d90a778.jpg Need further help, please let me know.
Sep 09, 2008 | Sony KP-65WS500 65" Rear Projection...
TV won't turn on.
It sounds like you have problem with the switch on the tv itself. try opening the front panel where switch is located and check wiring or maybe change the switch which you can get it online.
May 31, 2007 | Zenith IQB36B42W TV
GPS Logo
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
