Question about Krups GVX2-12 Electric Burr Grinder
Cannot get my krups burr grinder gvx 2 to turn on or do anything. there are no instructions in the box.
The GVX2 has two micro switches. one on the top hopper (in the groove on right hand side) and the other in the space the coffee holder (collector) fits into.
The coffee collector micro switch is activated by the lid of the collector.
You have to listen for a small "click" as you place the hopper on and again as you insert the coffee collector.
Philip Williams
Posted on Oct 07, 2008
Krups gx6000 grinder advertises removable burr grinders and there are no instructions, but is that the best way to clean them?
the Krups instruction manual is useless in this matter but if you do have some mechanical insight this is not very hard. You will need some tools, e.g. an Allen wrench to remove the housing lid.
Anyway, you should not have to clean the grinders very often, perhaps once a year is enough. It depends on the quality of the coffee beans you use; the more 'oily' beans the more frequent cleaning is required.
I would not use water to clean it, rather a small stiff brush (e.g. an old tooth brush), but if that is not enough, water will have to be used.
If so, be sure to assemble the grinder only after the burr is completely dry.
Check the link to Home Barista where a very similar grinder is shown, that should give you an idea about what to expect during the cleaning process.
Good luck;
Home Barista com
Jan 19, 2015 | Krups Gx600050 Conical Burr Grinder Black
Motor shorting out?
check ur switch better replace the switch
Jun 17, 2008 | Krups Burr Coffee Grinder
Krups burr coffee grinder - When I push the power button it flashes on briefly and then stops. It has briefly ground some beans so it working to some extent. Any ideas what is causing the grinder to...
Empty the grinder and see if it will run with no coffee bean in it. Some times debris will get caught in the grinder because it got mixed with the beans from the factory. If it runs your good to go. If not then the mother connection are not solid and it will run off and on at will.
Oct 14, 2013 | Krups Burr Coffee Grinder
My KRUPS GVX 2 Burr grinder won't turn on!! Is there something I should know before starting to use it??
some grinders had gotten lodged in the smaller crack between the grinder cover and the case, preventing it from settling in . cleaned with small knife, wallah!
Oct 26, 2010 | Krups GVX2-12 Electric Burr Grinder
GVX2-12 Electric Burr Grinder: blue power light not coming on...
Check all connections and plug then after that it is a short behind the switch and will need to be sent back to the manufacturer.
May 17, 2010 | Krups GVX2-12 Electric Burr Grinder
Missing user manual
just shearch your cas manual though google and it should come up straight away and you can download the manual for free i done it for my cars manual hope this helps
Apr 14, 2009 | Krups GVX2-14 Burr Coffee Grinder
Fill out water
The Krups Burr Grinder GVX2 featured in the picture is not a coffee maker, per se, it only grind coffee beans to use in other coffee makers. It is a lousy machine, and I would recommend returning it or not buying it.
DO NOT PUT WATER INTO THIS MACHINE. It will cause electric shock.
Aug 24, 2008 | Krups GVX2-12 Electric Burr Grinder
I bought a Krups GVX2 coffee grinder and am not able to get it to work. I have followed the instructions "to the letter" but once it's plugged in and switched on, the "on" switch on...
I know that this machine is sensitive with the lids needing to be securely fastened (both the top and the plastic catch bottom container) maybe that is it.
Jul 14, 2008 | Krups GVX2-12 Electric Burr Grinder
Krups GVX2-12 Electric Burr... Problem:
First, unlock and unscrew the upper burr carrier. Clean and check the upper burr by gently running your finger over the teeth in the cutting direction. It shoild feel moderately sharp. If it feels very blunt, look at the teeth under a good light. If you see a substantial "flat spot" at the top of the teeth, probably the burr set will need replacement.
For the bottom burr, clean carefully its teeth, and the entire area in which it is housed. Include the outlet orofice as well. You may find a lot of oily deposits within here, so just clean them off as best as possible.
When all is clean, insert the top burr holder back in place. Screw it down until both burrs touch, then back it off (say) 1/4 turn, and lock.
Put some beans in the top, and switch on. Adjust the top burr until the desired grind is obtained.
The ground coffee should feel like a coarse sand when close to the desired grind size.
Mar 13, 2008 | Krups GVX2-12 Electric Burr Grinder
Krups GVX2-12 Electric Burr Grinder Logo
1,001 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
