Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Washing machine wont turn on
I had an issue with the door which I fixed by draining the water out. Having then opened the door, the washing machine now will not turn on. I have changed fuses in the plug etc but still no joy. Is it dead??
Thanks
  • 3brandon Oct 04, 2008
    Hotpoint Aquaris Extra WD63
    Wont turn on - checked fusr - water pipes etc.
Sounds llike the door interlock mechanism which will stop the poer coming on look up washing machine lock on ebay
steve
Posted on Oct 15, 2008
Hello, I have the LG Washing Machine Model WM1832CW and I'm having drain issues. The machine itself wont drain the water out. The water remained in the machine. Please advised on what I need to do in...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 26, 2011 | LG WM-1832C Front Load Washer
We have a load in....it is full of water....it wont drain and spin...the cancel button doesnt work and door wont open....I checked for kinks in drain hose...none. I took off top panel and front lower...
heatman101
Nov 12, 2010 | Kenmore Washing Machines
My Westinghouse LT 9555 washing machine won't spin how to fix problem??????
heatman101
Nov 06, 2010 | Westinghouse Washing Machines
Washing machine wont drain the water
heatman101
Oct 10, 2010 | Haier Washing Machines
Won't drain and spin. Cycle completes and all the lights on far right flash. Door won't open. Bottom of washer is filled with water. Tried putting it on drain and spin cycle. Still won't drain. Beeps...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 08, 2010 | Frigidaire Washing Machines
My washer wont drain and when i try to start it over nothing happens. last time i was able to drain the water but when i put in another load, the washer filled with water and wouldnt drain again. Help what...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 19, 2010 | Fisher Paykel EcoSmart GWL15
Washing machine initially wont run any programe / only drains, fills with water but does not turn drum. Have checked door switch is faulty, now wont run at all.
Kindly replace the door lock and check it everything will be fine before that kindly check whether the belt of the machine is properly fixed
May 17, 2010 | Washing Machines
Hoover Nextra HNF2127 washing machine. Lights flashing at finish
Hi
Thanks for using FixYa. The start and pre-wash usually flash due to a clogged drain hose or the water pump. You’ll need to drain the water out of the base and also check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 18, 2010 | Hoover Nextra HNF 2137 Front Load Washer
Washing machine door wont open - hotpoint
Never reach inside the washing machine with it connected to the mains. The door interlock is always live.
There are several reasons why a Hotpoint door could be jammed shut.
•A broken door catch or door frame where the door catch screws in (they are rubbish on many Hotpoints - always breaking) you can sometimes get the door open if you push the door firmly in as you open it
•If there is water still inside the washing machine, then the door wont open either on these Hotpoint washing machines (not on some others though) If this is the case, when you try to open the door the ****** won't try to move down at all. You can open the door usually if you drain the machine. (only applicable with door interlocks that have a rubber pressure hose attached to them)
•A faulty door interlock
•The pressure chamber can be blocked on some earlier Hotpoint washing machines which gives the same effect as having water in the machine. Basically the washer "thinks" there is water in when there isn't. This would require the washing machine being stripped down to remove and clean the pressure chamber bottle. This cause is only applicable to washing machines where a small rubber hose is connected to the door interlock. This hose allows the door mechanism to be locked and unlocked by air pressure activated by water rising inside the pressure chamber bottle attached at the other end on the tub. Gunge can block the very small aperture where the pressure hose fits to the pressure chamber bottle.
Thanks for contacting fixya.com
Nov 07, 2009 | Hotpoint First Edition FEW12 Front Load...
Hi im having a real problem with my washer, at first it would not drain, now it wont complete a cycle and i cant get the door to open help gem
Machine can t go on if water is not pumped out And as long as there is water innside you cant open the door(Built in safety)Check that pump is clean and runs.Regards jan.
Feb 01, 2009 | Washing Machines
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
149 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
