Question about Jetway V2DP Motherboard
V2DP Video Stopped Working
How do I physically disable the on-board video on the V2DP (I can't see anything on a screen , obviously), and want to add a new PCI video board.
    Scholar:
  • 155 Answers
It is not possible to disable the onboard video but, if you install an AGP 4X video card (Brown slot) the BIOS will automatically give priority to your new card.
Remember to remove the power cord before installing any card because the motherboard is still powered even if the computer if off.
Posted on Oct 01, 2008
Due to power variation my display suddenly goes blank, then i powered off my system. again restarting there is no display on monitor only monitor light blinks.cpu is working properly ,hard disk, ram ,heat...
if it is an on board video sound like it got damaged by power failure,try adding on a video board and disable on board video in bios,make sure you have an avalible slot to add board
Feb 02, 2011 | Intel Motherboard
How do you disable the onboard graphics on an emachines C2825? I am attempting to install a Sapphire Radeon HD 4650 AGP video card, but my computer will not boot when i plug in the new video card. I have...
First of all that motherboard is too weak to fully use that video card, you could get the same framerate in games using a video card 2 generations older.
Proper way of installing a new card:
1. uninstall the driver of the old one and reboot in BIOS - in there put all settings to auto;
2. shutdown the pc and install the new card; connect the monitor to it;
3. boot into BIOS, disable the onboard video card and reboot;
4. boot normally and install the driver.
Jul 24, 2010 | Intel D845GVSR Motherboard
I have 192mb onboad video memory how do i up grade to at least 256mb on board video memory
On board video memory cannot be upgraded, since it is on board. However, you can upgrade your video by buying a 256mb video card and have it installed. When buying, ask your supplier for the software driver installer CD, In this manner, you can immediately install this driver to your PC and get it working immediately. But, remember this, you have to disable the on board video through the Device Manager, under the Systems at the Control Panel. To activate your new video card, Use the Add Hardware at the Control Panel.
Nov 21, 2009 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
My PC just stopped showing anything on the screen but looked to be working so I replaced the Video card still no good I have replaced the Motherboard, CPU, Power box, and now it just starts to boot then...
You've replaced quite a bit. I'm figuring that your monitor was OK when you replaced the video card. If your PC has on-board video, it needs to be disabled in the BIOS before inserting a video card..
Then, reinstall the old 450W power supply to see if there is any change.
If still a problem, I would suggest testing the memory. Test one module at a time to see which is faulty.
Hope this helps.
Aug 11, 2009 | Computers & Internet
What is venom?
hi im josh in cebu phils . Venom literally means a poisonous substance in animals and plants but in PC it is only a code brand which means tough strong or powerful The V2DP is our newest addition to the Venom motherboard line. Mach Speed has taken one of our best selling motherboard, the V4MDMP, and made a low cost solution with a 333 Front Side BUS and 4x AGP slot producing an awesome all-in-one, low cost motherboard. The Venom V2DP is a very versatile motherboard on todays market. This feature enriched motherboard supports AMDs Athlon XP 333FSB processors, DDR 333 memory, and has a 4x AGP slot for High Performance systems or take advantage of the Integrated Video, Sound, and 10/100 LAN for a cost effective solution. The integrated UniCrome 64mg Video is ready for crystal clear DVD playback and high-resolution gaming. On Board 3D 6 Channel Sound will take full advantage of your high fidelity sound system and onboard 10/100 LAN is ready for broadband internet or a high speed network thats all hope i helped you.
Feb 26, 2009 | Mach Speed VENOM V2DP Motherboard
Onboard video has failed..how do I change in bios to video card ?
first install the video card in the pci slot first so that you have access to your monitors screen for you to disable the on board video chip or video card, go to the CMOS setup by pressing del key. once there you can browse through the CMOS setup to disable the on board video chip.
Dec 22, 2008 | Gateway GM5088 PC Desktop
Video controller
use unidentified device drivers (download) it searches for all drivers needed on motherboard locate video driver info note name and number do a search for them download install.
the above program has helped me alot to find unknown drivers
Jul 01, 2008 | Mach Speed VENOM V2DP Motherboard
Ds lite not starting
either your battery is out of use or damaged or circuit board has obtained physical damage
Mar 16, 2008 | Nintendo DS Lite Console
IBM Flat Panel Monitor problem - light colored shifting lines (like Bar Codes)
It sounds like it's a problem with the video card, as opposed to a problem with the monitor. If you have another machine, or a laptop, or a friend with a laptop you can find out - just plug it into the other machine, and if the problem goes away, it's the video card. If not, it's the monitor.
While the card may be bad (if it has a dead fan, and has overheated) you will probably need to replace it. But if may just be loose, assuming it is a and on video card and not an onboard one. If it is an onboard video, you can usually disable it and put in an add on video card, which would resolve the issue as well.
Feb 16, 2008 | Computers & Internet
Onboard video not working
If you have configured it to be the secondary video adapter in the bios, then it will not work as it has to be set as the primary graphics. the bios will still be looking for your AGP graphics card as the primary and bypass your on board graphics. If you need to use on board graphics, right click the graphics card in properties>hardware>device manager and select dissable or uninstall.
Feb 13, 2007 | Mach Speed VENOM V2DP Motherboard
Jetway V2DP Motherboard Logo
143 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
