2002 rca d52130 tv has convergence problem
Had a man look at it and test the board,he says the model is different from others ,it doesnt have the 2 convergence chips,it has 12 resistores and a silver rectangiular box abour 4 x6 inches,hes says that box is gone and he could not find one anywhere,he says theres chips inside that.do u know where i could find this as rca will only sell the whole board he says for 500 dollars,let me know what u think or if theres anywhere i can buy rca parts online
  • 8,617 Answers
Leave a email at this site with the full model number and your symptoms. They will be able to get the parts that you require if anyone can. Heres the link
http://servicemanuals.vstore.ca/
Posted on Sep 30, 2008
TV turns self off during watching, also has darkened picture.
Do a hard reset to the unit, unplug the unit for at least 2 hrs and then turn it back on it should work fine.
Aug 27, 2008 | RCA D52130 52" Rear Projection Television
How to install a convergence kit in R61WH76 chassis no. itc222a
That model doesnt have the normal convergence components that nost other sets have. There are no convergence ICs the convergence is actually affected by three boards within that chassis it can be deflection board related, Convergence power board or the convergence amp board. Based on your TVs setup menu diagnosis will determine wether a component needs replacement or wether a circuit board will need replacement.
Aug 06, 2011 | RCA R61WH76 61" HDTV
Colors will not converge on my RCA SRS Focus, model D52130. When I make an attempt to automatically converge, it says to reduce the light in the room. We even covered up the screen with a blanket at...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 10, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Out of convergence - getting error that sensor is not getting any signal during auto-converge - is there a way to manually converge - or replace anything??
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 15, 2011 | RCA D52130 52" Rear Projection Television
Need of a Convergence Board for an RCA PROSCAN Model 80690WW1
You can order a replacement Convergence Board or Convergence Amplifier Board for this model (PS8069) from a major RCA parts distributor at the link below:
RCA PS80690 Replacement Part Convergence Board
RCA PS80690 Replacement Part Convergence Amplifier Board (2F27039-502)
Please note, these boards are no longer available from the original manufacturer (RCA) and only appear to be available from PTS.
Apr 08, 2009 | RCA Televison & Video
I have an RCA HD52w59 with a convergence problem. I've been told different things on this site. First I was told to change FL231, CL230, and DL231. I've also been told to replace both IC's (STK392-110)...
Your set doesnt have STK ICs. If the convergence adjustment option has disappeared from the on screen menu, then replace FL231, DL231 and CL230 If the adjustment option hasnt disappeared from the menu then you need to check the resistors on the convergence power supply board some of those will be open. The actual convergence Board will usually not develope problems just the Convergence power supply if the convergence adjustment option is still in the on screen menu.
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
Rca d52130 herd pop tv went dead
dear friend your tv has a defective fly-back transformer 99 times out of 100 that is your problem.
get the model number and call your local electronics parts distribuitor to see if they have it, if not call tritronics 1800-638-3328 they probably have it and is not too expensive.less than $25.00.now when you get here is the million dollar question can you do it yourself? if you can't call the repairman and by having the fly-back that will decrese the cost of the repair, is just the labor.
good luck
caypianan@yahoo.com
Sep 02, 2008 | RCA D52130 52" Rear Projection Television
Rca d52w26
You have to have your tubes re-alined, they sometimes do that if the tv has been bumped or jared.
Oct 17, 2007 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
132 people viewed this question
Top Televison & Video Experts
Electro Med Services...
