Question about Refrigerators
FAN NOT WORKING
OK ITS ME AGAIN
I SIT A FAN DIRECTLY BEHIND THE COMPRESSOR JUST TO SEE IF MAYBE THE UNIT WILL WORK PROPERLY I AM TRYING TO SEE IF IT IS THE FAN THAT I NEED TO REPLACE. DO YOU THINK THIS WILL ALLOW ME TO SEE IF UNIT WILL WORK RIGHT. THANKS AGAIN THIS IS A PAIN YA KNOW...;
  • Mary Davis Sep 28, 2008
    I WILL ADD YOU TO MY IM AND I AM TRYING TO HIT THE ADD COMENT BUTTON AND IT DOESNT SEEM TO WORK THE WAY I THINK IT SHOULD BUT I WILLL TRY. WELL I SIT A FAN IN FRONT OF THE COMPRESSOR JUST TO SEE IF THE UNIT WOULD DO DO ANYTHING DIFFERENT AND NOW THE UNIT SEEMS TO RUNNING MUCH COLDER SO I GUESS THAT MEANS I NEED TO GET A COMPRESSOR FAN WHAT DO YOU THINK?
  • Mary Davis Sep 29, 2008
    I WILL HAVE TO HAVE SOMEONE COME AND CHECK THE UNIT OUT I HAVE NO WAY OF CHECKING VOLTAGE AND SEEING HOW TO DO IT. THANK YOU FOR ALL THE HELP THAT YOU HAVE GIVEN ME. MARY AND HAVE A GREAT DAY
  • 958 Answers
You can use the same post just click the add a comment and we could continue posting on one thread only...
by the way..can you please rate the last two threads that we had?..just to increase my rate....a fixya would be perfect...lol... do you have yahoo ,messenger?..you can add me then we can chat there... drcool299@yahoo.com
tnx,
drcool
Posted on Sep 28, 2008
  • francis rivero Sep 29, 2008
    if the fan is not running, you have to check it first because it could be the source also and not the fan.
    again, check first the voltage of the fan, it could be a DC fan.
    the fan should run at the same time as the compressor.
    tnx, drcool
  • francis rivero Oct 02, 2008
    hello mary,
    how are you today?...how's your refrigerator?...i hope it is running well now...keep me posted please.
    wish you all the best,
    drcool
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
Carrier ac model 38ckc does not cool properly. Outside unit runs but air coming out of the top is cooler than the other units that we have. Just had a service replacing all the filters and coolant checked...
Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor by using the device called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new compressor
Jun 20, 2011 | Carrier 38CKC036 Air Conditioner
Breaker breaks
This unit may have an internal overload mounted on top of the compressor. You would have to get to the
compressor to find out and it maybe faulty. That may
explain why the compressor comes on later on, this
overload protects the compressor from getting hot.
When you trip the breaker and then reset it again only to see it trip again almost sounds like a direct short or loose wire. It could also mean that your
capacitor needs to be replaced or that you need a hard start kit and the unit needs a good cleaning.
Try just operating the fan and see if it trips the breaker, if it does then either the blower motor is bad
or it is still the capacitor.
Jun 25, 2010 | Dometic Rooftop RV Air Conditioner
Compressor or fan not working
If compressor and all fans not working and unit has power.Check defrost timer maybe bad or sticks turn defrost timer knob if unit starts timer is bad.Timer only turns in one direction.
May 16, 2010 | Freezers
Whirlpool Refrigerator not working -------------------------------------------------------------------------------- Hi all, I have a Whirlpool ED22PC SxS fridge which has stopped cooling on both the...
Hi. Due to the fact that the fans are not operational, this will confirm that the Main PCB has failed. This is the main power control board. It must be replaced, asap. The general location of this affected board will be just behind an access panel, near the compressor unit, or on the backside, mounted in the middle section of the unit.
Once the Main PCB board is replaced, the unit will return to its normal operating status.
Dec 21, 2009 | Whirlpool Refrigerators
Gss22jeta refrigeretor quit working
For a refrigerator to operate properly, it must: 1) have power to it; 2) the compressor (underneath the unit) must run; 3) the compressor fan (close to the compressor) must turn; and 4) the evaporator fan (inside the freezer unit, usually behind an access panel) must turn.
These would be the first things to check.
Oct 18, 2009 | Whirlpool GS6NBEXR Side by Side...
My fedders aircon compressor does not turn on again whenever its thermostat turns it off. what i had to do is unplugged the power cord and turn it on again to work. i already replaced the capacitor. what i...
you have a time delay build in on the pc board of 3 minutes. If it takes longer than 3 minutes check your compressor overload protector, Maybe the compressor is overheating, check your coils for proper air flow. ultimately if the compressor checks ok then it's your board relay. also try testing the temperature sensor ( thermostat)
Oct 03, 2009 | Fedders A6X05F2D Air Conditioner
My new frigidaire refrigerator is open in the back it shows the motor is this the way it should be
no not if it has a fan blowin near the compressor if you have a black coil behind the frig then is ok not to have a cover
Aug 20, 2009 | Frigidaire Refrigerators
Signs of a bad compressor or condenser
plug this unit into a receptacle with a lamp also in the recept. unit will try to start the lamp will dim for a couple seconds and go back bright unit wont start maybe fan but no comp. sit and watch a few minutes later lamp will go dim again then back to bright, this is a classic low tech way of confirming the comp is trying but not working possible bad run capacitor, much cheaper than new unit
Aug 11, 2009 | Fedders A7DH65B2A Dehumidifier
Ac fan not turning on I can ''stick start it'' but which direction?
The condensor fan should be sucking air from the top and blowing it through the coils, probably a counter clockwise direction. The buzzing/humming sound is confusing to me. A humming sound sounds like a motor that can not turn over to start. A starting capacity would be needed. Just because you changed it out last year does not mean it is good. A buzzing sound sounds like a contactor problem. Contactors buzz and after a while, they will fail. In any case, you can "stick start" the condensor fan PROVIDED you are sure the ac compressor is working (this is for a short and temporary use). Also, you may have a high load duty capacitor that assists in the unit running. This will affect your condensor fan operation if it is not good. Unless you know all the components and operations of ac electrical, I would highly recommend calling out a professional.
Jun 26, 2009 | Carrier Heating & Cooling
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
