Question about Canon PIXMA MP600 all-In-One InkJet Printer
White lines through the page
When I print something off the computer, the printed page has white lines going horizontally through it. When copying on the printer some lines are just lightly faded. I deep cleaned the printer and it was gone for a couple of days. Now it shows up again even though I have it set on high quality printing (it shows up on normal, too). Even if my ink takes were low in the past, this never happened before.
Hope this doesn't mean the end of my printer - only had it for 2 years or so.
Thanks for any help you can give me.
Gisela Dunn
    Scholar:
  • 116 Answers
There are two reasons for this problem you r facing.
1)the cartridges are getting over so replace it the printer will print perfect.
2)the printhead in which the carteidges are fitted is blocked internally and is not able to supply the appropriate ink for printing which requires to print.
for this you have to remove the printhead from the printer which is very easy you just have to lift the lock on the head and it can be removed.after removing clean the base of the head with tissue and isoprophyll and then reinsert the head again.it should print again after 2-3 cleanings and deep cleanings.
Posted on Oct 05, 2008
I just changed my laser cartridge and with the new one in my printed pages have two or three horizontal lines on them
does these lines occures when you print something out or just when you copy something?
If it occures when you print out also check the new toner crg. drum ( green roller ) and if the lines are on its surface change the crg. because that means that the cleaning blade is faulty.
If there isnt lines on drum, and printed image is OK, clean the copy glass ( both platten and adf glass ).
Worst case scenarion is faulty fixing film.
Hope that helped!
Aug 13, 2010 | Canon imageCLASS MF5550 All-In-One Laser...
Hello - my Brother DCP 330C printer is printing horizontal faded lines on both color and Black and white copies. I have changed the toner in all areas but still no change. Could the problem be with the...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 28, 2010 | Brother DCP-330C All-In-One InkJet Printer
Gray Lines print onto copies
more than likely its your drum unit could be upper fuser film but prob the drum
Oct 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Printer won't print
Printing on stand alone has a big difference when printing from pc.... try using the kodak website for this issue www.kodak.com/go/itg and use "image quality and blank page" for subclass
Oct 22, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Line on paper after page prints
This seems to be a common theme. I just posted a response to someone here with a similar problem. HP.com has a web page that can help you go through a series of diagnostic tasks designed to track down this problem:
Streaks or Lines in the Printed Page
There's also a help page that talks about lines on pages when you use the Copy feature. Not quite your problem, but it may help:
White Lines Through Copies
Hope some of this helps. Good luck.
Oct 09, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
UX-B700 fax/printer
Sounds like you may need to clean the optics. Open up the area where you insert the original to copy, there you will find a small long glass that needs to be cleaned, I would suspect there is white out on this causing you lines or it may just be dirty.
Hope this helps...
Lbcoaster
Jul 07, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Color print lines
try to replace with colour catridge bye
Sep 24, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
189 people viewed this question
old marine
old marine
