Question about Whirlpool Refrigerators
Refridgerator is hot, freezer is ice cold...what do i do to fix
  • 943 Answers
Hi thanks for the question would check the fan motor in freezer and also pull fridge from wall and clean the coils please accept the appliance doc
Posted on Sep 28, 2008
Refridgerator freezer is making noises
Hello, your refridgerator in most likely in defrost cycle. the noise your hearing is the water dripping on the hot heater and ice dropping off the evaporator. should only last 15 minutes and then your all set. Mike
Sep 15, 2009 | Freezers
The unit is dripping water from the opening in the ceiling of refridgerator
The drain at the bottom of the freezer under the coils is clogged. Remove Icemaker if you have one, remove bottom floor of freezer, remove back panel of freezer. Use hairdryer to melt ice. ALL ICE MUST BE REMOVED. Use hot water and a turkey baster to get ice out of drain hole located about middle under coils. Be patient, do not chip ice with sharp tool. After ice is removed pour hot water down drain hole. Water must come out in drain pan under refrigerator(you may have to take front grille off to get to pan)
If Ice returns after a few weeks, you need to look at defrost thermostat which is usually clipped on cold coil at back of freezer. This part or the defrost timer could be defective.
Sep 14, 2009 | Whirlpool Refrigerators
GE regrigerator not cooling or freezing
first defrost it by turning it off for 1\2 to 1 full day,put towels on the floor to catch the water,when a refridgerator gets frosted up it cant circulate the cold air,and if its one with the freezer on top then the cold air cant blow down into the refridgerator,check inside the refridgerator at the top where the thermostat cover is there will be a vent hole,it could have ice built up so much that its totally blocking the air flow.This usually happens when hot food is put in the refridgerator and causes steam,or the refridgerator runs too much caused by bad door seals,or the cooling fins on the back or bottom underneath plugged with dust and the freon gets too hot causing condensation inside the freezer which causes it to frost up,a plugged drain hole will back up water and freeze,the fan in the freezer may have stopped working,which is about a $60.00 part,and finally a bad defrost element (about a $40.00 part)which is a glass tube inside the freezer with a coiled up wire inside it that heats up at certain times to defrost any ice build up,(which is the last thing to check)
May 09, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer in nice and cold but refridgerator is not
due to lots of moisture in the air or high humidity it creates extra frost in the freezing unit this creates blockage in the air flow once the ice crystals build up. the freezer is what keeps the fridge at the normal temperature if the air flow between the two are blocked in the ducting then the fridge temperature will rise the best way to solve this is to open the freezer take out the 4 screws in the back panel tilt the panel forward and blow it with a blow dryer till the ice chunk has melted its a good idea to use a towel and on the top self of the fridge to obsorb excess water this can be kinda messy. or you can unplug your fridge for about 6 or so hours. good luck hope i helped. :)
Mar 25, 2009 | KitchenAid KTRS22EM Top Freezer...
Refridgerator
Does freezer back wall have ice build up ? if so a defective heater is the most likely problem
Oct 15, 2008 | GE GSS25JEMWW Side by Side
Freezer staying cold but fridge is getting hot
More likely than not there is a blockage of ice bettween the freezer and the refridgerator. most fridges work to get the freezer cold as a priority.Then the cold freezer air is circulated throughout the rest of the unit to keep the fridge cold. Thats why you may hear a fan running in the fridge unit while the compressor is not on. Unplug and open the doors to warm the inside. Look at the plastic piece bettween the two units and remove. See if there is ice build up and use a hair dryer to melt, dry area out and restart the unit by plugging back in or turning temp dial. Hope this helps.
Aug 06, 2008 | Refrigerators
Refrigerators Logo
41 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
