Question about Fujitsu LifeBook C1320D Notebook
Display Resolution Hello, my name is Mihai and I have a problem with my FSC 1320D. I cannot set a higher resolution than 1024x768 for display resolution. On tech specifications it says that has 1280x800 resolution.
We currently have over 50 of these laptops at the site i work at and as far as i know their max resoultion has always been 1024x768. The screen cannot go any higher. It is an old 15.4" screen after all, nothing like what you can get these days.
Posted on Dec 03, 2008
    Novelist:
  • 169 Answers
Make sure you have the correct driver loaded from the Fujitsu website. Additionally, try removing the Display Adapter from device manager and reboot. This will allow Windows to identify the "new" hardware and attempt to install. If asked, point Windows to the driver files from Fujitsu and that should fix you up :)
Hope this helps!
Posted on Sep 29, 2008
How to center my display in acer travelmate 5720
If your display is not centered try adjusting your screen resolution. Click Start/Control Panel and look for Display or Appearance and Personalization. Open them to open the display properties and click the settings tab for screen resolution. Set your resolution up higher. The higher the resolution, the smaller the icons, thus the more fits on the screen. Normal resolution is about 1024x768.
May 29, 2012 | Acer TravelMate 5730-6204 Notebook
How do i change the screen resolution using the fingerpad on my acer aspire 5349 laptop?
Click Start/Control Panel and look for Display or Appearance and Personalization. Open the display and click Settings and you can change the screen resolution by sliding the bar over. The higher the resolution, the smaller the icons. Normal resolution is about 1024x768.
Depending on your operating system you might see link for Screen Resolution without actually opening the display.
May 27, 2012 | Acer Aspire 9300-5349 Notebook
When i switched on my computer,my desktop will no fit onto my screen i have to scroll from side to side with the mouse or up and down to view the complete screen.
This can happen if your display resolution settings in windows are set higher then your monitor can support. The display is meant to be set at 1024x768. You can set this by going into the control panel, select display. You will find the option to set the resolution in there,
Regards, Chris
May 19, 2011 | Packard Bell FT500 15" LCD Monitor
My Mac will not install the Digital camera Solution Disk says my screen resolution is insufficient...
This must be because you have a widescreen monitor or because you have set a screen resolution that's too low for anything.
Most programs ask for a screen resolution higher than 1024x768 (which they rarely actually need) to install.
So you can change yours to that value (or higher) for the installation and if it distorts your display, set it back to the original value later.
To see how to change your resolution, go to this site; http://www.ehow.com/how_2064940_change-display-resolution-mac-osxchange-display-resolution-mac-osx.html
After setting the resolution to 1024x768 or higher, run the installation and it should proceed with no problems.
May 04, 2011 | Canon A3300 IS Digital Camera
Hi, i own compaq presario CQ42 369TU laptop, how do i increase my screen resolution from 1024x768 to 1280x1024 or higher ?
For Windows XP...
1.
Open Display in Control Panel.
2.
On the Settings tab, under Screen resolution, drag the slider, and then click Apply.
3.
When prompted to apply the settings, click OK. Your screen will turn black for a moment.
4.
Once your screen resolution changes, you have 15 seconds to confirm the change. Click Yes to confirm the change; click No or do nothing to revert to your previous setting.
If you cannot set it any higher than 1024x768 and you have already installed the video drivers, that is as high as it can go for your hardware.
May 04, 2011 | Compaq Presario Notebook
How to set the display settings
Make sure the video driver has been installed.
Go to Start - Control Panel - Display - click on Settings tab and change the Screen Resolution, Start with a resolution 1024X768 with 32 bit color. Increase the Screen resolution higher if required to suit your needs.
Jun 14, 2010 | ViewSonic VA1930WM LCD Monitor
What should I set my computer settings to when trying to connect to my Lg 42lg30 TV
check the screen resolution from your manual, your computer display resolution must match your tv spec.
Mar 18, 2009 | LG 42LG30 42 in. LCD HDTV
I need to set my display settings to 1024x768 pixels or higher, i dont know how.
Start>Control Panel>Display>Settings
In this window you will see the screen resolution on the left, just move the slider across till it gets to 1024X768 and click OK
Aug 30, 2008 | Computers & Internet
Screen size
Most Likely: Your screen resolution needs to be 1024x768.
Less Likely: You have an Appearance scheme such as Large Contrast.
Solution: Access Control Panel, select Display, then Settings tab and then move the slider to the above or higher resolution.
In the Theme or Appearance tab (depending on OS) choose a generic Theme or Color Scheme.
Regards,
Worldvet
May 21, 2008 | Computers & Internet
Anyone know a way to increase the resolution past 1024 x 768?
First, you might want to check what the maximum supported resolution of your monitor is. You can do this by looking it up on the internet or referring to the owners manual. If you cant find that information, in your graphics properties in Windows XP, click the advanced button beneath the color settings and click the monitor tab. Make sure the model listed under 'Monitor Type' matches the monitor you have. If it does, see if the 'Hide modes that this monitor cant display' box is checked. If so, the maximum resolution is limited by your monitor and you may have to upgrade the monitor to go any higher. If the model does not match, you can try the following: click Properties->Driver Tab-> Update Driver and either load the correct ones from the manufacturers web site or use one of the Standard Monitor types provided by the windows Driver library. Be warned though: If you select a standard type with resolution higher than your monitor supports, it will not display correctly at settings higher than 1024x768, and you may have to wait for windows to change the resolution back. Another thing you can try is unchecking the 'Hide modes that this monitor cant display' box, clicking ok, and setting the resolution to something higher than 1024x768, but the same warning applies! If it does not display correctly than you know for sure that the monitor is the limiting factor.
Nov 09, 2007 | Sharp LC 28HM2 28 in. Flat Panel LCD...
Fujitsu LifeBook C1320D Notebook Logo
171 people viewed this question
Top Fujitsu Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant  Sharma
Prashant Sharma
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
