Question about Pioneer CDJ-800 Turntable
CDJ 800 Has no power
Cdj 800 - no power - does unit have a fuse that could have blown? or is the transformer bad. thks in advance
  • 1 more comment
  • terracolson Nov 20, 2008
    Yes same problem here what helped you?
  • djnew001 Feb 17, 2009
    i also have no power, but im sure it flashed ''ad'' before it went off. the fuse inside hasn't gone, so im thinkin its the psu....
  • Road2xl_com Feb 23, 2009
    I have the same problem it happen over the weekend and its not working .
    could some one help me? if you have a solution .
    i checked the fuse . but it seens is not burned .
This guy don't know what he is talking about,the cdj800 does have a fuse,if you open the unit up just make sure it's unpluged,if the fuse is blown replace it with one of the same rating,it's right next to the switch inside the unit,it's very easy to take apart just 5 screws,I have one that won't power on also but it's not the fuse,but yours could be,just check it out and don't be afraid just be careful when handling electronics so that you don't send static charges into the chips.
Posted on Feb 05, 2009
The player does have a fuse but its not recommended to try and fix the player yourself as
it may not be the fuse at fault and is dangerous.
thanks.
email: info@audiovisualservices.info for all dj equipment repairs enquirys.
Thanks.
Posted on Oct 02, 2008
Cdj 800 not reading disc until warmed up
Downtown Radio was one of my Authorized Service Centers when I worked for Pioneer. They are no longer in business. The issue that Nathan is having, is quite different than a loss of power or ground, caused by an bad IC Protector, which is merely a complicated fuse. Unfortunately, I think you damaged the Optical Pickup(laser) when you installed it. This part, as well as most parts in this unit, are ESD sensitive and without taking the precautions, that pickup may be useless now. For more information, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
Mar 04, 2014 | Pioneer CDJ-800 Turntable
Power problem, CDJ wont turn on propperly as it is from the US and i live in Birmingham UK
The step down adapter should work fine as long it supplies the voltage and any other ratings shown on the turntable power supply indication pannel. However the problem might already have happened. If the fuses were before the power entered the mains transformer of the unit, then if they were set to blow above the USA voltage then things could be OK. However if the the fuses were in the secondary output from the transformer then the mains will have caused possible damage to the transformer. Maybe even elsewhere.
Jan 15, 2013 | Pioneer CDJ-800 Turntable
I want to purchase a pair of pioneer CDJ 850 players, however in my country the power supplied is 110 volts at 50hz. I have had problems using electronic devices that only specify 60hz. The CDJ 800's...
The 850's should work fine on 50Hz. They are spec'ed at 120/60. with your lower voltage the transformer in the power supply should NOT have a problem. There is nothing syncronized to line frequency so it should work fine.
Jun 01, 2011 | Pioneer CDJ-850 CD PLAYER
CDJ 200 meant for US mains supply plugged directly into UK mains supply, now don't work. Replaced external fuse but still don't work..anything else i can try before i bin it?
Dont bin it!!!
If you are really lucky it may have just blown an internal fuse or if your not so lucky it may have killed the mains transformer which is still worth repairing.
If the transformer is faulty and was replaced with one sourced from Pioneer GB then no external 240V to 110V transformer would be needed - you would be able to plug it straight into a UK mains supply.
Jul 20, 2010 | Pioneer CDJ-200 CD Player
Pioneer CDJ-800 screens went bank/dead, still played discs. Now it does neither.
when removeing top cover you will see the power supply on top right side faceing you.there are fuses on that board. Some of the fuses will look like transistors, however will only have two legs,check all. chances are you may have one or more bad.
Apr 16, 2010 | Pioneer CDJ-800MK2 Turntable
Fried unit, european plug
Pls check fuse of ur Cdj's
djajay
Apr 13, 2010 | Pioneer CDJ-800 Turntable
Cdj 200s bought from america not working. they have american plugs on at 120v. i have tried an america to uk travel plug and 240v to 120v stepdown transformer but this has not resolved issue....... would...
Yes, fuse may be blown, first check out the fuse of CDJ,
if it does not work. Install a physical 120v American transformer
also change the switch of 240v to 120v from back of CDJ
thx,
djajay
Feb 07, 2010 | Pioneer CDJ-200 CD Player
Blown fuse cdj200
It is hopefully just the fuse. To get at the fust you have to remove the casing (there are screws on the under side). Once removed you will find a little glass tube fuse located where the power comes into the unit. The fuse just pops out and you can get a replacement from any electronics shop.
Sep 22, 2008 | Pioneer CDJ-200 CD Player
Power
You need to check internally, Transformer/rectifier could be bad, disconnected wire, blown internal fuse. Can you rub the needle with your finger and get sound? Is it just the table not turning or is the needle not getting "power" either?
Dec 04, 2007 | Pioneer CDJ-800 Turntable
No power
You probably have a bad transformer. This is not an easy fix. You will need to contact a service professional for assistance.
DJPROAUDIO
TWEAK AV LAB
Pioneer CDJ-800 Turntable Logo
555 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
