Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Agitator The agitator doesn't agitate and makes a screaming noise. On low agitation the noise was a lower pitch
  • chris geary Sep 28, 2008
    Thansk very much. I've jsut taken it apart and put it back together and it seems ok again - possibly something had got unbalanced and so stopped workign - but yoiu really helped with how to take it apart!
    Thanks
  • Anonymous Feb 07, 2009
    agitation stopped, loud noise started
  • 943 Answers
Hi thanks for the question . i think the problem is with themotor coupling that is on the motor and transmission you have to remove the cabinet 2 screws on the console . remove .lift console . remove 2 brass clips on top disconnect lid switch pull cabinet towards you. remove the water pump 2 spring clips . remove the clips on the motor disconnect the power to the motor remove the motor . replace drive coupling thanks the appliance doc
Posted on Sep 28, 2008
Agitator only moves a little bit and making noise
Most likely agitator dogs / gears are stripped out inside agitator. If it's a double action agitator where the top turns independently from the bottom, the top should turn one way and not the other. If top of agitator turns freely in either direction, then replace those dogs. If it's a single action agitator, then grooves that slide onto transmission shaft in agitator itself could be stripped out. If that's the case, replace agitator
Oct 27, 2017 | Kenmore Series 70 Washer Motor 387780
I have an kenmore elite top loader washer model 110 27087602. During the spin it makes loud clunking noise. I seen the other post about the agittor nut sometimes loose but I do not see this nut under the...
The most probable thing that is making that noise is a broken motor coupler if it drains but the tub doesn't move or even if the agitator doesn't move (espically the lower section) on the wash cycle the coupler is the problem. I have included a youtube video that will show you step by step how to replace the coupler http://youtu.be/9K1KHEogf3c
If it does agitate let me know and ill tell you how to completly remove the agitator to check that drive block you refer to as nut under softner dispenser
Hope this helps and if it does please give me 4 thumbs up
Gene
Jul 28, 2011 | Washing Machines
Wash is not agitating properly. Top portion of agitator does not spin and the clothes do not roll over well. Does seem to have a lower unit noise when agitating. Any ideas? thank you, Jeff
inside the agitator there is a set of 4 gears that make the top part of the agitator go back and forth pull off the top and remove the nut inside pull on the very bottom of the complete part then take the top part of the agitator apart from the bottom the install the new new gears by replacing the old ones reassemble and it will work properly
Aug 18, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Performa PAVT920AWW washer makes a squealing sound
i am sorry but i had this problem happen before with my customer maytag performa, what i found out is that the brakes become crystallized, causeing a squeaking noise, remember in agitation, the brakes stops the the drum from spinning, what i advise you to do is change out the breaks or take the brake pads and rub them with sand paper
thanks
Aug 23, 2009 | Washing Machines
Kenmore Series 80 Washer, Model 20852 - Agitator not turning well, making noise
Hi, If the washer spins properly but the agitator does not work, it could be the dog kit needs replaced. If the washer does not agitate or spin, it is probably the coupler.
Put the washer in wash cycle with no laundry in it and see if the lower prt of the agitator moves. If the agitator moves, try and hold the upper half of the agitator and see if it will only move one direction.The agitaor dog kit is designed to only let the top part of the agiator to grab one way. When they go bad, they can make some noise.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 17, 2009 | Washing Machines
The machine will not agitate, before it stopped it made a high pitch noise off and on and cannot turn the tub
Is this a top loader? Something jamming the under side of the agitator? Remove it to check. If the shaft that drives the agitator is frozen--may be bad bearings (and the source of the noise). If a front loader, the tub main bearing is probably frozen, again the probable source of the noise or maybe the drive belt was slipping.
Jul 14, 2009 | Washing Machines
MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
May 12, 2009 | Maytag PAV2300 Top Load Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Roper RAX4232KQ - Top part of agitator won't turn
you need to install new agitator dogs . very in expensive. remove cap on top of agitator reach in and remove opaque cover. you should see a 1/2 " bolt remove that and pull up on agitator. pull apart two halves. disassemble. install four dogs. reassemble in reverse order
Feb 06, 2008 | Roper RAX4232KQ Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
57 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
