Question about Canon PIXMA MP830 All-In-One InkJet Printer
Getting to answer phone before fax or message bank cuts in
My pixma mp830 will only ring once before the fax machine cuts in. I have tried everything, i think, in the manual to allow the phone to ring 6 or 7 times before either, the fax or message bank cuts in. Can someone please help me. I am happy with every other aspect that the machine can do, but it is frustrating that this problem occurs. Thankyou in anticipation
  • charles rutt Sep 28, 2008
    HELP
  • craw2daddy Sep 28, 2008
    My MP830 fax answers even after the phone is answered. The only way to use the phone is to disconnect the phone line from the printer.
  • 661 Answers
To stop the pixma from picking up even after the phone line has been picked up you need to ensure the telephone line is connected to the LINE port and not to the PHONE port on the back... the PHONE socket is if you wish to connect a phone line to the same socket Thru the pixma. (passthrough)
not sure how to stop the pixma picking up on the first ring though..... are you sure that you are SAVING the setting change.....?
Posted on Oct 01, 2008
WANT TO ATTACH A MESSAGE MACHINE
The message machine needs to be set to answer 1 ring before the fax is set to answer. When the phone rings the fax starts listening even when the answer machine picks up. If the fax hears fax tones it will receive the fax and if no tones the answer machine will take a message.
Jan 22, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP830 has stopped receiving faxes. When the fax phone number is called it rings but the fax does not pick up.
Can you still send fax? if sending and receiving are not working you can try to update or uninstall/reinstall the software for this unit..
Hope that helps.............
Aug 15, 2008 | Canon PIXMA MP830 All-In-One InkJet...
I HAVE A CANNON PIXMA MP830 IAM USING A ANSWER MACHINE ON MY PHONE I HAVE MY CANNON PIXMA ON "ANSWER MACHINE CONNECT" MODE SETTING BUT WHEN A FAX IS SENT TO ME THE PHONE RINGS THE ANWSER MACHINE...
the connection should be phone cord to the fax then to the answering machine. answering machine answers first (rings to answer must be lower than the fax).
Nov 21, 2008 | Cannon Office Equipment & Supplies
Message bank
Look through your fax machine instructions,. There should be some there regarding how many rings before pickup. Or maybe the unit does not have that feature and is designed to have its own separate line for faxes.
Sep 21, 2017 | Canon PIXMA MP830 All-In-One InkJet...
Fax network not working
Is your phone line plugged into the proper receptical on the fax? It should be plugged into the LINE slot, not the PHONE slot. The PHONE SLOT IS TO CONNECT A TELEPHONE TO THE FAX. IT IS NOT FOR THE INCOMING PHONE LINE. If your phone connection is correct, try calling your fax machine from a cell phone while you are at the fax machine. Listen on the cell to see if the fax machine picks up the line. If it does not, go into your fax machine's settings, either INITIAL SETUP FAX SETUP, or PHONE SETTINGS. You may have to try several settings to find one that works, depending on your fax machine. Try going to RECEIVE SETUP on your fax machines setup menu. Scroll through the settings, writing each down on paper. Try RING DELAY, RING TIME, NUMBER OF RINGS TO ANSWER , or any other settings relating to how your fax answers the phone line. Try changing each setting, one at a time, and try calling your fax to see if it answers. There may also be settings on your fax to set it up if an answering machine or telephone is on the same line.
Jul 17, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Faxing using voip phone service
We found out that the machine requires a dedicated analog line, so we won't be able to use it on a voip system.
Jun 16, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Phone line and fax line
If you actually have a 2 line setup with 2 #'s each with it's own separate line, it's wired backwards. Otherwise (distinctive ring, etc) the machine has to be capable of and set-up to recognize which ring pattern is a fax call.
Also, you have to enable auto-answer on the fax machine.
Feb 21, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Fax problem
unplug the fax from the phone line. call it from you cell.if you hear your phones ringing in the house, plug the fax machine back into the jack. [you should still be on your cell phone] if the line goes dead or stops ringing, there is a short with the fax machine or wire to the jack.if you hear a busy signal without the fax plugged in, unplug everything you have plugged into phone jacks thruout the house. call your # again.if you hear ringing on your cell phone, plug everything back in one at a time.[again while still on your cell phone] if it was one of the phones plugged into a jack, when you plug the shorted phone back into the jack, the line will go dead again. that phone or cord is the problem.
if still rings busy when everything is unplugged, then call your phone company. it can be an inside wire or jack problem, or the problem is outside your home.
hope this helps
wg
Feb 05, 2008 | HP Officejet 5610 All-In-One InkJet...
Cannot figure how to set up Canon MP830 All in One Fax machine with remote answering machine
Cannot figure how to hook up Canon MP830 all in one fax with remote answering machine. I can plug in phone line to send faxes fine but when hooked up in same hole and the phone rings it goes immediately to fax and can't receive phone calls. Maybe i have phone line hooked up in wrong place on my machine. The answering machine is in our master bedroom on the other side of the house. With my last a canon also i had it hooked up to go to fax after a certain amount of rings and it worked fine. That machine got fried by lightening and i replaced it with this machine. If anyone knows what i am doing wrong i really need this fax hooked up all the time for my business.
May 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
163 people viewed this question
old marine
old marine
