Question about Epson Stylus Photo R390 InkJet Printer
INK CATRIDGE CARRIER
I want to clean my Ink Absorber Pads but my cartridge case is stuck on the right hande side of the printer and it won't move in order for me to get into the catridges. How do I move them left?
  • 353 Answers
Turn the printer on and as soon as the print head moves, pull out the power cord, or switch the printer off at the mains. You should now be able to move the print head (gently) by hand over to the left side.
Posted on Jan 31, 2009
My Canon MP210 printer [ USB001 ] said the Ink absorber is Full contact the service center. Guess what, the service center just gave information. I need to know if will be able to fix or will...
There are two possible ways to remove the error from your printer. First is to actually clean the absorber pads that are full of waste ink. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads. There are actually two absorber pads located on the right side of the printer, under the
ink cartridges when the carrier is in the home position.
Accessing the pads and remove them for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezers and extra cloth for some ink spillage. Using the tweezers, lift up the pads sitting on the rubber retainer. The pads can be easily clean by placing them under running water. Use warm water to remove the ink from the pads. Dry the pads and reinstall them. Same procedure if you are installing new pads.
However, the problem will not be solve especially if you are currently facing the waste ink absorber full error or E-27.
Reset Waste Ink Counter Canon Pixma MP210 and Canon Pixma MP220
1. Start with printer off
2. Press and hold resume Button (triangle in the circle) and click "Power" button. green led should be on
3. hold the Power button, release Resume Button.
4. Without releasing the Power Button, double click "Resume" button and then release Both Buttons.
5. Click "Resume" for four times then click "Power" button, to confirm the selected action (reset counter absorber).
6. Turn off the printer and turn on again
7.
Please rate this solution. Let me know if you have any more questions. Thanks.
May 30, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Catridge is not recognize to te printer.. even i bought a new one..
This is actually a very easy fix. Two absorber pads are located on the right side of the printer, under the ink cartridges. With the printer on, lift the top to expose the cartridges. They will automatically move out of the way. You can move them to the left side by hand if the printer is not on. You will probably need a flashlight to see the pads. They each sit in a rubber retainer. The pads can be removed very easily and cleaned. Take the pads out of the retainers with tweezers. They clean up nicely with warm water but you can use something like Simple Green if they are stubborn. It is best to use a spray bottle (on stream) and blast it through the pad until it is white. Sometimes just putting it under a running faucet will do the trick. If there is ink in the rubber retainer after taking the pad out, it can be cleaned up with a paper towel. Put the pads back into the retainers and you have successfully cleaned the ink absorbers.
May 26, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Message Waste Ink Absorber is showing. Whatv is this
Two possible ways to remove this error from your printer. First, is to clean the absorber pads that are full of waste ink. Second, is to reset the printer to clear the error and let the printer print again.
Two absorber pads located on the right side of the printer, under the ink cartridges when it is resting.
1. Turn on the printer.
2. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill.
3. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads.
4. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error or E-27.
Use a reset procedure to clear the error in your printer
2. Press the MENU key
3.
Press SCAN button
4.
Press the COPY button
5. Press the SCAN button then wait until it enters the service mode.
6.
Select NVRAM ACCESS further OK
7.
Select SET ABS-M LEVEL and set value equal to zero
8.
Select SET ABS-R LEVEL (if any) and is set to zero.
9.
Do this as many times if the first attempt didn't work until it fully reset.
I hope that helps
Nov 01, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Ink absorber full
There are two possible reasons for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
. Its is actually two absorber pads located on the right side of the printer, under the ink cartridges when it is in home base position.
How to access the pads and remove it for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error.
Reset the Printer using an MP Tool
Mp Tools are utilities designed to clear errors that will appear in an MP160 printer. Download this MP Tools here.
while the printer is on Run this software
1. Click Reset Main (main) to reset the waste ink counter and
2.
Click Reset Platen button (E27).
If errors still persist.
Press and Hold down Reset button and wait until the printer restart.
Release the Reset button and wait until it fully initialize.
Happy printing.
Please comeback and rate this answer.
Thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Ink absorber if full, contact service provider? is there any other remedy?
There are two remedies for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
Reset the Printer using an iP Tool
iP Tools are utilities designed to clear errors that will appear in an iP1800 printer. Download this iP Tool here.
1. Click Reset Main to reset the waste ink counter and
2.
Happy printing.
Aug 18, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Ink absorber is full cannot print
Mp Tools are utilities designed to clear errors that will appear in an MP150 printer. Download this MP Tools here.
2.
Happy printing.
Aug 17, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber (sponge part)
2.
Happy printing.
Mp130 waste ink absorber almost full. how to fix?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error or E-27.
and start printing again
3.
Press SCAN button
4.
6.
7.
8.
9.
Aug 08, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Ink absorber almost full
Hi
This issue with Canon Printers occurs when the Waste Ink absorber becomes full or sometimes due to sensor error.
To clear this error you can first try to clean the waste ink collector pads. Before proceeding please turn off your printer and unplug it from power source.
To locate these pads open the cover of the printer, move the cartridges with your hand. Now you can use a absorbent paper towel to clean these pads. These pads are on the right side of the cartridges.
After this you'll need to restart your printer. This will resolve your issue.
Daniel Scott
Jun 08, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Older canon pixma mp130 printer says that its ink absorber is almost full and that the ink cartridge is jammed. The little shut it off and click stuff doesn't work.
3.
Press SCAN button
4.
6.
7.
8.
9.
I hope that helps
Apr 09, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Epson Stylus Photo R390 InkJet Printer Logo
134 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
