Question about LG Electronic Window Air Conditioner
Window air conditioner
What does "dry" mean and how do I use air conditioner to draw outside air in
    Scholar:
  • 121 Answers
There should be a lever marked vent, fresh air or something like that to draw outside air in. I'm not sure what you by dry because 50% of a/c is dehumidification. This maybe a sales feature. Please call me at 504-722-3946 I own an a/c company and like to know more about this feature.
Thank You,
Ed Boukater
Edward Boukater Services
eboukater@gmail.com
Posted on Sep 28, 2008
There is a gray lever at the bottom right of the vents. Pull the lever to draw in outside air. Push it in to recycle inside air.
Posted on Apr 02, 2009
  • 958 Answers
Dry is a control to just dry the air inside the room, sometimes the temperature setting is fixed and you can not change it.
if you want to cool the room, you need to chose the cool mode or sometimes the snowflake icon. in this mode, you can change the temperature setting.
some models of window type airconditioners does not have the fresh air intake feature. verify your unit if it has this feature.
i have seen some manual models and not electronics that they have a level that you will adjust to choose fresh air and recycle air.
tnx 4 using fixya,
drcool
  • francis rivero Oct 02, 2008
    hello pat,
    how's the ac unit?...were you able to figure out if it has this recycle or fresh air mode?...keep me posted please.
    wish you all the best,
    drcool
Is the dry mode on the airconditioner a dehumidifier
Air conditioners and dehumidifiers both work on the same idea. A dehumidifier is a "air conditioner" that doesn't run so good as a air conditioner, plus, it sits on the floor in your basement (where ever) and not in the window.
The idea is to draw warmer air (which holds more moisture) into the machine where it is chilled (cooler air can not hold as much moisture). The moisture is deposited on the coils and it drips either to a drip pan (where it runs out the back to the outside (AC)) or a catch bucket (in a dehumidifier and you either dump it in the drain or you have connected a hose and led it to the drain). The air that is returned to the room contains less moisture than it did when it entered the device. The best relative humidity is about 50%, BTW. Not to wet and not to dry.
The goal in the case of a AC is cool air (which contains less moisture) and the goal in a dehumidifier is less humidity (moisture), but not necessarily cooler air.
I am not familiar with "dry mode" to which you refer. You have mentioned your device is a Goldstar Microwave Oven so it is impossible for me to gather any information on your particular model AC or dehumidifier.
I hope this information has helped you today. Thank you for your interst in FixYa.com. Please make a favorable evaluation of this response.
Jul 18, 2011 | Goldstar Microwave Ovens
What does the "dry mode" mean in a Hampton Bay air
"dry mode" normally means, to dehumidify only. this will not cool the air nor heat it consistently.
Jun 19, 2011 | Heating & Cooling
The "dry mode" dehumidifies the air. This is useful when you do not need to cool the air but the relative humidity is higher than you want to have inside. You get the advantage of bringing in the fresh air without increasing the indoor humidity.
I hope this helps.
(this applies to all air conditioners with a dry mode)
Jun 19, 2011 | Hampton Bay HBLG5004 Air Conditioner
Would like confirmation that this unit has the fan feature to draw in outside air for free cooling in cooler weather.
No. It can be done only with fresh air system, not in window a/c. But keep dry mode during winter, if you need cooler whether.
Jan 13, 2011 | Friedrich CP12C10 Wall/Window Air...
My window air conditioner is making very loud noises and it is not dripping water outside
No condensation means no freon flow in condensor which sounds like bad compressor which would account for the noise. Replacement would probably be most economical way to remedy.
Aug 12, 2010 | Goldstar KG6000R Window Air Conditioner
Do we need to use both hoses?
You could draw the air from inside however the system works much more effeciently with 2 hoses.
The air that is drawn into the unit and heated then exhausted back outside. If you don't use the second hose all the air that is exhausted will have to be drawn in around windows and doors or othe voids in the area. This would draw in warm moist air that would then have to be cooled and dehumidified.
Jul 19, 2010 | Danby DPAC120061 Portable Air Conditioner
Window too small
Not really, the condenser must be able to draw air from the outside and must stay outside, sideways the A/C will not function properly.
Jun 07, 2010 | Goldstar KG6000R Window Air Conditioner
Does this air conditioner draw fresh air form outside through the
i dont think you are drawing air from outside you are expeling the heat from indoor ...outdoor so for it to cool the room you must vent the hose outside
Apr 09, 2010 | Danby 7,000 BTU Portable Air Conditioner -...
E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Jun 13, 2009 | Haier Mechanical Air Conditioner HWF05XC7
Does this unit draw inside outside air in fan mode?
that's usually controled by a baffle inside or outside air
Jun 29, 2008 | Kenmore 72056 Air Conditioner
LG Electronic Window Air Conditioner Logo
527 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
