Question about GPS
Magellan maestro 4250
I have had this unit for five days and was in the process of setting up all of the options. It was working fine when I shut it off. When I restart it now it goes through the warning page, as it should, but when I touch the OK button, to proceed, it goes to system settings rather than the main menu. I can go through all of the settings and diagnostics, in settings, but I cannot get out of the this mode. I have tried the reset several. One other thing. When I use the touch screen test in diagnostics, I can touch the screen at any point to make it work rather than just the specific point requested. I also cannot exit this screen without turning the unit off.
Thank You yes, i just got my unit magellan maestro 4250 yesterday and a few hours later it locked up on the first screen where it has a magellan logo and a scroll bar, went to the website to see if there was a fix but saw it had no customer service support open to answer calls on weekends, so i tried maggie but that was no help, i tried and tried several times and nothing still stuck in first boot up screen that says magellan w/scroll bar and now this morning i went to take it out of the little black case and turn it on thinking perhaps needed a rest but no that was not the case either and also when powered up i noticed then that it had some little areas of black splotches on the screen area too so i know its got some issues!!!
  • azlazyleo Nov 26, 2008
    My tomtom Go 510 When I turned it on and tried to go "Home " the screen went blank and will not shut off
  • mcmoz76 Nov 26, 2008
    When I turn on the Magellan 3200, the first screen that comes up is a blue screen which says Magellan with a cylinder looking bar below it. it doesn't advance beyone this screen, even after a half hour of it powered on.
    Top Expert:
  • GPS Master
  • 24,726 Answers
I would take it back and ask them to replace/refund.
Posted on Mar 01, 2017
2 Suggested Answers
SOURCE: Magellan Maestro 4250 freeze up/lock up
Posted on Apr 12, 2009
Owned 3 Magellan 4250 Gps, was working, now no sound.
Make sure the font selected is a TTS ( text to speech)
Jun 05, 2010 | Magellan Maestro 4250 GPS
Just wondering how can i do the up date for my magellan maestro 4250 gps for free
new up date for magellan 4250 just go to and click on unit gps thann download the f/m version 4.86 it is free and simple juste follow the step by step body good luck
Mar 31, 2010 | Magellan Maestro 4250 GPS
Magellan Maestro 4250 GPS, the display seems to wash out on sunny days so that it is unreadable. That's without direct sunlight on the unit. Can anything be done or adjusted?
The Magellan 4250 LCD display brightness settings does not do much. I can understand how annoying it is to have the sun's glare on the display making it unreadable. You can improvise a simple sun shade like i did, cut and fit a card board strip on top of your GPS unit to block out the sun glare. It's just simple and cheap solution.
Mar 25, 2010 | Magellan Maestro 4250 GPS
Our Magellan Maestro 4250, came on by itself and will not turn off.
is it plugged to AC charge when it comes on?
If not seek out the RESET hole and place a fine pin or paper clip end in and reset the unit
Jun 20, 2009 | Magellan Maestro 4250 GPS
When i start the Magellan maestro 4250 , the screen turn to setting option. can't return to the menu and freeze to setting screen ! How to fix it !! THX !!
try the hard reset. the little hole the size of a paper clip on the side of the unit. if that doesnt work, id say the digitizer(touch screen) might be broke.
Jun 12, 2009 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4250 freezing up
I just purchased a referb from TigerDirect and the only issue I discovered was a lockup when the unit goes to sleep. Try holding down the power button for 15 seconds then release it to cycle the unit. Then hold the power button down again for 5 second to start it back up. I had to do this for my bluetooth to work and not freeze up. Now I just turn it on and off manually and avoid having it go to sleep. I also downloaded the firmware update to 4.86, you can download it from Magellan's website. My unit works great so if that doesn't work contact Magellan and I'm sure they will have a solution.
May 29, 2009 | Magellan Maestro 4250 GPS
Magellan Maestro 4250 needs a battery
There is a kit that includes battery, tools, and how-to video available here.
May 22, 2009 | Magellan Maestro 4250 GPS
Maestro 4250 frozen after incomplete 2009 map up date
I had same problem on 3/28/09.
According to Magellan and other people who have experienced the same problem, this is terminal to the unit. It can be caused by downloading the 08/09 Magellan map upgrade, which can cause the unit to permanently lock up. Magellan is well aware of the problem, and should offer to replace your unit if you have the problem. If you elect to have it repaired, Magellan can download the map upgrade for you in the repair process. Here is a site noting the same problem:
Questions for Magellan: 1) why would they sell, in 2009, gps units with old 2007 maps loaded in them, requiring the purchaser to buy a current map, and 2) if there is a problem with downloading the current maps, why is there not an advisement or warning to the installer.
Other than replacing the unit, there appears to be no "fix".
Mar 29, 2009 | Magellan Maestro 4250 GPS
International Maps for Magellan Maestro 4250 GPS
If I am correct you can put it on the sd card
There should be a slot for the card on the unit .
also you can check on their web page .
Jan 28, 2009 | Magellan Maestro 4250 GPS
Regarding going straight to settings page, there is a file in one of the folders called navigator.exe. This is the menu used to access the map and the system settings and enter an address. Possibly, this file became corrupt while you were setting up your options. I suggest that you download the latest firmware update online from and install it. If, for some reason, the update fails after multiple attempts, then do the following:
  1. In the .zip file of the latest firmware available, there are 2 files: Readme.pdf and Magellan_Maestro_4250_4_86_Rel1.exe
  2. Extract the Magellan_Maestro_4250_4_86_Rel1.exe and change the .exe to .zip
  3. Open with a .zip file reader such as Winzip.
  4. Copy the file Navigator.exe to the folder where the Navigator.exe file is placed in the GPS. Overwrite that file.
  5. This will at least give you access to the menu and the map.
Dec 28, 2007 | Magellan Maestro 4040 GPS Receiver
GPS Logo
362 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
