Question about Epson Aculaser C1100 Printer
Epsom C1100 The printer will not operate and states that "B Open" with red light. I have open and closed the cover but to no avail.
  • kiptower Feb 13, 2009
    same problem but cant clear it
  • Anonymous Mar 29, 2014
    back door not closing
  • 163 Answers
On the C1100 Cover B is the top cover, however B open error could be the Top, Front or Fuser cover as the microswitches are all interconnected. First check each cover for broken or missing actuators (these look like "fins" and operate the microswitches when the cover is closed). Next check the microswitches havent been dislodged and operate using a piece of stiff card. As a last resort the switches can be shorted out to fool the printer into thinking that the cover is closed (not recommended).
Posted on Feb 16, 2009
  • 64 Answers
Cover "B" should be on the back of the printer. when you open the main back door at the bottom there is a little flap that will fall down, this is a sliht design flaw as you have to make sure that this is in an upright position before closing the main back door. from past experience its usualy hit and miss at getting it to work unfortunatly
hope this hepls
Pete
Posted on Nov 25, 2008
Epson c1100 e door open
Just solved the same problem. It is a very slight misalignment of the two rollers behind door E. I closed door E holding the vertical bar below the handle and just 'jiggled' it slightly from side to side, and it latched closed. Paper jam fixed, yippee!!
Mar 23, 2013 | Epson Aculaser C1100 Printer
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Jul 26, 2011 | Dell 1110 Laser Printer
Om line error red light is on
Try this solution: Check for paper jams when the "Error" LED lights red. Open and close the front cover. The paper may automatically be ejected from the printer. Gently pull any remaining jammed paper straight out. Open the front cover. Pull the toner cartridge out. Pull out any internal paper jams.
Nov 21, 2010 | Samsung ML-2510 Laser Printer
Message 'Clean Sensor' has appeared. Followed advise to open Cover D and close it again but to no avail. Has anyone got any other suggestions, please?
Follow the steps below to clear the "Clean Sensor" error message.
  2. Slowly close the cover again. c2600_close_cover_d.jpg This action will move the lever shown below and clean the sensor.
  3. Open and close the cover several times. Once the front cover is left closed the printer will start to calibrate.
Once complete, the error should no longer appear and the printer should resume normal operation.
Note: If the error message is still apparent after following the steps above, contact Epson for further advice.
Nov 16, 2010 | Epson AcuLaser C2600N Printer
Epson c1100 B open
hi
the cover B is not closed correctly: open cover B and colse it again
covre B is Nuber 1 at the picture below
Oct 27, 2010 | Epson Aculaser C1100 Printer
HOW DO I ROTATE THE CARTRIGES TO GET THEM OUT
  1. Close all the covers, and then power the printer off.
  2. Open Cover B, and then remove the photoconductor unit (PCU).
  3. Turn the toner carousel by hand to line up a toner cartridge with the front of the printer.
  4. Open Cover A.
  5. If the toner cartridge is not in position to remove it, close Cover A and repeat the steps above.
  6. Remove the toner cartridge, and then close Cover A.
  7. Repeat all the steps above until you have removed all four toner cartridges.
Sep 25, 2009 | Epson Aculaser C1100 Printer
Epson Acculaser c1100 ink blead
First rule out that it is a paper issue by trying a different type of paper
If that dosnt work
check if the gradation setting is too small when printing graphics. On the Basic Setting menu in the printer driver, click More Settings, adjust the gradation setting by sliding the Contrast slider bar
If that dosnt work
Clean the print head .
see steps at the bottom
If that dosnt work
It is starting to look like drum/photoconductor problem, this may need to be replaced (the most expensive solution)
Follow the steps below to clean the printer head.
r_1.gif Open the cleaner cover on the right side of the printer. Then, open cover A. d580095.gif
r_space.gif r_note.gif Note: r_space.gif r_space.gif Move the cleaner completely in and out. Otherwise, the printer may not be cleaned effectively. r_4.gif Push back the blue lever on the right inside of the printer. d580098.gif
Sep 11, 2009 | Epson Aculaser C1100 Printer
Printer says cover is open and its completely shut. wont print
Maybe something wrong with sensor which displays the state of the cover.
Try to find it.
May 31, 2009 | Dell 926 All-In-One InkJet Printer
Replace Panel in Xerox 8550 Color Printer - Close Exit Cover
Open that cover and look in the frame of the machine for an opening. Then look on the upper cover. There is an interlock switch on the machine. The plastic tab on the upper cover often times breaks off and will not actuate the switch, giving you that message.
You can fix it by gluing a paper clip onto the cover. Or call 1-800-835-6100 and order a new cover.
May 14, 2009 | Xerox Phaser 8550DP Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Epson Aculaser C1100 Printer Logo
190 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
