Question about LG WM1814CW Front Load Washer
Flashes 13? the unit will run for about 15 minutes then stops and flashes 13
  • 1 more comment
  • sun_9969 Sep 28, 2008
    Yeah, sorry I am relaying the message for someone. It is "IE".
  • Anonymous Oct 03, 2008
    my machine flashes " OE " ?? what does this mean plz ?
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Are you sure it is flashing 13 ? I'd think it might be more like "IE" . Would you check that again?
  • 1,543 Answers
IE = Inlet Error. if the water level has not been reached in a certain amount of time, you will get an IE code. Most likely cause is clogged inlet water screen, inside the threaded end where the hose attaches to the machine. Other possiblities are valve shut off, kinked hose, open water inlet valve solenoid coil.
Posted on Sep 29, 2008
I have a Manitowoc J series and it will run three cycles and then shut off. I will start again and the same thing happens. everything else seems to be fine.
Chances are the unit is shutting down on an error code. It will shut down after three batches if either A: the unit takes too long to make ice, or B: a harvest cycle lasts too long. You can time a batch of ice with a timer or stopwatch... if you listen you should be able to tell when the "ice making" stops and the "harvesting" begins. Ice making should take about 13-15 minutes and harvesting 1.5 to 2.5 minutes. If I remember correctly the error codes are triggered if the ice making takes 60 minutes or longer and/or the harvest takes 3 minutes or longer. You can tell which error code is tripping by accessing the electronic control board. There is an LED indicator that will blink when you turn the unit on if there is an error present in the memory.
Oct 25, 2014 | Kitchen Appliances - Others
Unit stops rinning after 15 minutes ande a sign appears in the window saying c6. turn off unit at main switch and wait for 15 minutes and unit starts adain for a further 10 to 15 minutes and cuts off...
Compressor run current high. Check condenser coil dust blocked. Clean it. Check fan motor- if less rpm, replace capacitor.
Best solution:Do water Service and then check. If still amps gradually increase, replace capacitor.
Thanks and hope helpful.
Jan 28, 2011 | LG Heating & Cooling
How long does it take for the compressor to fill up during the first use? The motor has been running for 15 min and the pressure needles have not moved....
Make sure the tank drain on the bottom of the tank is shut off if there is one.
It should not take more than three or four minutes to fill a small pancake tank.
You hear any hissing noises while the pump is running? If so, there's an air leak, see if you can stop them somehow.
If the above does not answer, return unit for refund or exchange.
May 12, 2010 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
Sony TV flashes 13 times and stops
I, too have a KDL52 also less than 2 years since purchase and have the same problem this morning 2009 Oct 2
Aug 08, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Engine coughs and stops after about 15 min. of cutting
check the vacuum line from pump to crank case fo leaks
Apr 25, 2009 | Garden
Heater will not stay running
bigrench1843@aol.com. I just fix this same problem 15 min. ago after 2 days of headbanging
915 EST. lets talk
Jan 28, 2009 | Reddy R155D Utility Heater
Energizer 15 minute Ni-MH Battery charger
A flashing red light indicates that there's an error, or the batteries are defective.
No, the unit won't switch itself off once the batteries have been fully charged. The unit will start trickle charging instead.
Dec 24, 2008 | Energizer 15 Minute Battery Charger Combo...
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
LG WM1814CW Front Load Washer Logo
145 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
