Question about Panasonic DMRES15 DVD Recorder
U61 error won't go away
I can't use the device because I get an error code u61 which the manual says was ue to a power failure (there was one). It will not self recover even when unpluged for days.
  • 2 more comments
  • JROlfe2003 Sep 28, 2008
    U61 error msg - recorder wouldn't record due to a faulty disk - but now won't finish its 'recovery procedure'
  • jhm1 Jan 31, 2009
    Well actually my problem is U88 message but the rest is the same
  • dustinkharl Feb 26, 2009
    I HAVE A SAME PROBLEM IN MY panasonic DMR-ES35V HAVING A ERROR U61
  • jhm1 May 11, 2010
    Okay how are we suppose to reformat a disk when the remote is on the fritz?
I've solved my problem - thanks to a suggestion on another site. Apparently the machine is sensitive to the type of disc when it has a problem - I inserted an identical make and type of disc (RW in my case) and it then completed its 'restore to normal operation' and the error msg went away.
Also suggested but didn't work in my case was opening the flap on the front, and with the machine OFF, press and hold STOP and Channel UP.
Hope this helps
Judith
Posted on Sep 28, 2008
    Problem Solver:
  • 3 Answers
Just to clarify what JROlfe2003 had said to perform what was decribed you have to
The unit is carrying out the recovery process. Do the following to eject the disc.
(1) Press [O/I] on the main unit to switch the unit to standby. If the unit does not switch to standby,
press and hold [O/I] on the main unit for about 10 seconds. The unit is forcibly switched to
standby.
(2) While the unit is off, press and hold the stop button and [CH, up] on the main unit at the same time for about 5 seconds. Remove the disc.
Posted on Feb 10, 2009
U61 fault on an EZ28
Review the reference U61 in the user manual or maintenance, its posible that its needs format special or type of dvd-ram,
This failure apparently is very common in this brand Panasonic.
you will think twice when You will go to buy Panasonic.
Jun 22, 2012 | Panasonic Televison & Video
U61 ERROR ON DISPLAY
U-61 is a hardware error code. Usually means main board failure, however have found that a bad changer can also trigger that code since it connects directly to the main board.
Sep 21, 2009 | Panasonic DMR-ES35VS
ERROR U61
"U61" error message (there was a pwr failure or the AC cord is disconnected while powered on). Make sure all power connections are secure and your cord is in good condition. You might have to reset, maybe in manual
Feb 26, 2009 | Panasonic DMRES15 DVD Recorder
PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
U61 error problem
The manual refers to the U61 as being a recovery mode. Have you left it at U61 for a period of time while it tries to recover?
U61 ≥There was a power failure or the AC plug was disconnected while the unit was on. The unit is
You could always try to force it into standby mode and back out again:
Press [í/I, POWER] on the main unit to switch the unit to standby.
Now press [í/I, POWER] on the main unit again to turn the unit on.
If that doesn't take care of it, everything thing I've found points toward a replacement of components inside the system by a repair service. Hopefully you are still under warranty!
Sep 12, 2008 | Panasonic DMR-ES35VS
Error code U61 on a panasonic DMR-ES35v When I turn it on it says "Please Wait" end the code U61 occurs after som while.
Aug 30, 2008 | Panasonic DMR-ES35VS
Error code u61 will not clear, unable to reset the DMR-EZ45VEBS
Hi, there was no solution to my problem with the error code U61, having talked to a Panasonic repair center it would cost £180.00 to fix this unit as the board and DVD recorder have to be replaced as one unit. It would cost me around £160.00 to buy a new one so there was no point in having it repaired.
Aug 04, 2008 | Panasonic Televison & Video
U61 CODE WONT GO AWAY
I buy broken units reds repair 870-656-5139
Feb 10, 2008 | Panasonic DMR-ES35VS
U61 error code
UMM the DVD top lid uses FOUR screws. The entire DVD drive is bolted to the chassis with 3 screws.
Oct 14, 2007 | Televison & Video
Panasonic DMRES15 DVD Recorder Logo
638 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
