Question about GE Microwave Ovens
Microwave is making a humming when turned on - GE Microwave Ovens
  • 1 more comment
  • mdthrom Sep 28, 2008
    It makes a humming noise when you try to cook , I'd know if it is heating because I don't keep running it. I'm afraid it will get ruined. There is no code in the display when running it. My husband says it sounds like the motor is stuck. The model number is JVM187OWF001. The serial # is DG991721S. Hope this helps.Thanks
  • mdthrom Sep 29, 2008
    Thanks I'll call a service technician tomorrow. Will it hurt the microwave if I run it?
  • William Miller
    William Miller May 11, 2010
    Is it making this noise whenever it's plugged in, or just when you try to cook with it?
    Is it heating / cooking when it should not be?
    Is it heating / cooking when it should be?
    Is there any code in the display?
    What is your model number?
  • GE Master
  • 9,098 Answers
Most commonly, this is a shorted high voltage rectifier diode or a failed magnetron.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
GE Customer Service is here. They can help with the warranty info & help you find a local servicer.
If you or someone you know decide to look into it yourself, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Here are two links but read the safety warnings first: (if it is NOT shorted, it's probably fine)
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Sep 29, 2008
My microwaving is humming
just about all microwaves hum-----the fan,turntable motors make a hum if louder than normal check that turntable it not stuck or off track
Sep 07, 2015 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-530E microwave turns on when door opens
If it makes that hefty clunk and humming that microwaves make when working,that is NOT GOOD as it is the magnetron working producing radiation, so just needs chucking in the bin. It's not dangerous if it's just the fan (a much more gentle humming!
Sep 04, 2014 | Sharp R-530ES Microwave Oven
No heat in microwave. Makes loud humming sound when turn on. Model GE Spacemaker JVM166OWBC 04
The humming can be caused by a couple of bad parts. Usually it's the magnetron tube, the microwave source. They often fail by shorting out, and the loud hum from the power supply is what you hear. Another part called the HV diode may also have shorted, but the magnetron is more common.
A bad magnetron can be replaced, but it's a costly part. And microwave service should be left to a professional, because there are dangerous voltages under the cover and a chance of microwave leakage if repairs aren't done correctly. Between the part and labor costs, it might be more economical to replace the oven. Let a qualified servicer give you a repair estimate and then decide.
Jan 09, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Runs normally, but makes loud hum. not heating. in defrost mode, loud hum, then normal sounds, then loud hum, then normal...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
Aug 15, 2010 | KitchenAid KCMS1555RSS Stainless Steel...
The unit is 3 years old and when I turn it on there is a loud hum. Theunit also does not heat but turns the turntable?
From your description it sounds like the magnetron has failed in this oven. That's the part the makes the microwaves to heat the food. It typically fails by shorting out and making a loud hum noise. It not usually worth fixing since the price of a replacement magnetron is almost as much as a new oven.
Jul 01, 2010 | GE Profile Spacemaker JVM1871 Microwave...
Microwave makes a loud hum and won't heat. What
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Apr 09, 2010 | Electrolux Over-the-Range Microwave
Whirlpool builtin microwave humkming loudly
yes for sure magnetron or diode has gone bad.but usually it is the mag.magnetron when go bad they start making noise and stop heating.when chaging magnetron chg the diode with it.
Aug 18, 2009 | Whirlpool MH7140XF Microwave Oven
JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Aug 17, 2009 | Microwave Ovens
GE Microwave making loud humming noise
humming sound is your magneto going out Dont have any idea of the cost for replacement however it may be cheaper to purchase another microwave than to repair this one. Good Luck
Jul 16, 2009 | Microwave Ovens
Microwave problem
Is this a new or used unit, and is the humming sound new? Can you watch the fan blade go around or is it going too fast to watch a blade?
Feb 14, 2008 | Maytag MMV1153A Microwave Oven
Microwave Ovens Logo
181 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
