Question about Refrigerators
FAN NOT WORKING
HELLO THANK YOU FOR THAT INFO. IT 'S THE FAN BY THE COMPRESSOR THE ONE ON THE BOTTOM. I CAN SPIN THE FAN BY HAND IT DOESNT SEEM TO BE HAVING PROBLEM DOESNT FEEL LOOSE OR OUT OF SINC IT APPEARS TO BE IN GOOD SHAPE. IS THERE A WAY I CAN CHECK THE FAN BY JUMPING . I WANTED TO MAKE SURE THE FAN KICKS ON. IF IT DOES WOULD THAT MEAN WHAT IS WRONG. THANK YOU MARY
  • 958 Answers
Hi mary,
pull out the fan and check if it is an AC fan or a DC fan. they now uses DC fan in some models.
if it is an AC fan, check its voltage rating and test it directly to the voltage stated in the motor.
if it is a DC, find a power supply and test it with the correct voltage and polarity.
tnx,
drcool
Posted on Sep 28, 2008
Dose anyone have a owners manual for a true refidgerator GDM-12
The fan your referring to is the condensor fan. it should not be tight to turn. it should spin freely. if it is hard to turn, its probably stuck, which is why its not spinning. Remove grill, slide the nottom portiom out so you have access to fan, remove fan blade, and spraylubricant on fan motor (around the area that the screw that held blade). Remove hair, dirt, string, or anything else that might be prevrnting fan from spinning. sometimes its easier to burn it off. If fan still doesnt spin you may have to replace fan motor.r
Sep 26, 2012 | True GDM-12 Refrigerator Commercial
I moved my refrigerator to vacum (Frigidaire model PLHT217TAK 2002) and since then the warm air stopped coming out from the front bottom vent. It also stopped making noise, it seems to want to start but...
the condenser fan motor is what blows the air around down there,pull out the machine remove the back bottom panel and you'll see the fan,check it to see if something is stuck in the fan blade keeping it from spinning,do this right away,if the fan isn't blowing you can cook your compressor,if something is wrong with the fan motor you can leave the bottom panel off and stick a regular fan back there to keep the compressor cool until you fix the fan motor.hope this helps
Jun 23, 2011 | Frigidaire Refrigerators
Wont stay cool
does it cool and then stop when it does this is there frost in the fzr compartment or ice build up. Does the fans run at all do you hear the compressor and compressor fan running. Just need more info
Aug 17, 2010 | Kenmore 57029 Side by Side Refrigerator
Whirlpool side by side not cooling or freezing. Have already cleaned the condensor coils with no change. I did notice that the fan in the bottom back is not spinning.
that is most likely the problem. If this fan doesnt cool the condenser and compressor it will shut the compressor down. replace the fan and your problem will most likely be fixed.
Jul 11, 2010 | Whirlpool GS6NBEXR Side by Side...
The compressor fan not properly working.
You need to replace the fan. It doesn't use an external starter. Part 24 on this diagram is your motor. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=502485&diagram_id=124933#d124933
May 13, 2010 | Whirlpool Gold® GC5SHEXNQ
Compressor comes on, some cold air, no fan?
Try spinning fan by hand. If it spins freely, change capacitor. If fan is tight, change fan motor.
Apr 08, 2010 | Fedders AED24E7F Wall/Window Air...
I have a LG LHD45EL and the compressor works, fins chill but fan won't turn at all. I took it apart and cleaned the armature of the fan, Used a non-contact device to ensure electric is present in the...
let the unit cool down
with power on try sticking something in there to spin the fan blade
if it spins and continues to work it is a bad capacitor (little shiny metal can sometimes oval or round)
if it doesnt spin i would have to guess the motor is bad
hope this helps
Jul 29, 2009 | LG LHD45EL Dehumidifier
Nef B1432 (2000) not heating up properly
You possibly need to fit a new fan motor, as this will certainly cause temp variations, if it is not working properly.
If you remove the inner rear cover of bottom oven, you will see the element and the fan.Try spinning the fan by hand, it should revolve freely, and rotate on its own after spinning it by hand.
If it does not, then it needs replacing.
It is a fairly straight forward job to replace, just bear in mind that the fan is held on by a left handed nut, so to undo it , hold the fan blade, and unscrew the nut clockwise, as though you were tightening it up, and vice versa to tighten it.
You will have to remove the main rear cover of oven to access the the terminals and the fan motor.
Please rate my fixya soution.
Thanks.
Jan 31, 2009 | Neff B1432 Single circotherm plus Electric...
Refrigerator
the compressor might have had it
Dec 16, 2007 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
166 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
