How can I take the cover off a Canon i9100 printer ( to clean the waste ink pads)
  • 781 Answers
This is the webpage where you can download a couple of manuals for your printer.
Quick Start for Canon i9100 is the manual you want to download registered free and download (try using a fake email address if you want.. and see if it lets you) http://www.retrevo.com/support/Canon-i9100-Printers-manual/id/259bh537/t/2/
it has maintenance instructions that should let you take care of your needs.
Posted on Sep 28, 2008
E8 Waste ink absorber full, or platen waste ink absorber full WHAT MUST DO?
I am told that this will reset your counter and eliminate the full absorber warning that you are getting.
Cleaning the pads is messy, sending the printer to Canon is expensive,
I used a simular reset code for my MP470 and haven't had any problems.
1. To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Jan 14, 2011 | Canon PIXMA MP190 All-In-One InkJet...
CANON WASTE TANK RESET CODES
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Sep 04, 2008 | Canon Office Equipment & Supplies
The waste ink absorber is full
Press OK.
Press Copy.
Press OK.
Press Stop/Reset.
Jan 04, 2011 | Canon PIXMA iP90 Mobile Printer
I have got error 5100 what does this mean
Hello
Error code 5100 describes a physical problem either with a paper jam or an incorrectly seated ink tank. Resolving the error is a quick process that only requires a few standard troubleshooting procedures.
Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
Check the paper feed tray on the front end of the Canon printer to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
But in some other canon printers,Error code 5100 indicates that the waste ink absorber has reached maximum capacity. The Canon i860 printer uses the waste ink absorber to keep ink residue off the printer heads and internal printer components. To resolve this error code, the waste ink absorber must be cleaned out and the error code message needs to be reset.
Open the top of the printer.
Locate the waste ink absorber pad on the right side of the inside of the printer. Grasp the pad and pull up to remove.
Take the waste ink absorber pad to a sink. Run warm water over the pad and wring it out to clean it. Wring the excess water out when done cleaning.
Clean the waste ink absorber compartment with a tissue or cloth.
Set the waste ink absorber pad on a dry paper towel or clean cloth to dry.
When the pad is dry, place it back into it's compartment in the printer.
Close the top of the printer.
Press and hold the "Resume" button on the printer. Press and hold the "Power" button while holding down "Resume."
Release the "Resume" button. Press "Resume" twice. The indicator light will turn amber followed by green.
Release the "Power" button.
Press the "Resume" button four times
Press the "Power" button. The error code is now reset.
Nov 13, 2010 | Canon Office Equipment & Supplies
Locate waste ink absorber pad
canon pixma ip1000 printer, how do you access and clean waste ink absorber pad
Apr 13, 2010 | Office Equipment & Supplies
The waste ink well is full
Reset Procedures for Canon i560 Printers
  1. Turn off i560 Printers
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
  9. Please remember at some time of other you will need to clean out the ink pads that are inside the printer.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 22, 2010 | Canon BubbleJet i560 InkJet Printer
Waste ink full?
GET YOUR PRINTER SERVICED AND CLEANED
VOTE AND GIVE ME ALL THUMBS
PROUD TO B AN INDIAN
AND PROUD TO BE A PUNJABI
Jan 28, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Waste ink absorber is full
Hi!
The printer counts every single droplet ejected by the print head due to waste ink absorber capacity. When the waste ink counter rise to about 90 % the printer shows message 'Waste Ink Absorber Near Full'; in this stage we can still continue printing by pressing Resume button until waste ink absorber capacity reach 100% and 'Waste Ink Absorber is Full' appears.
To fix this problem you have to reset waste ink counter to 0%. Even though we can just reset waste ink counter without resetting waste ink counter, it strongly recommended that you replace waste ink absorber to prevent ink flooding inside the printer.
To reset waste ink counter, perform the following steps:
  • Plug in power cable
  • While pressing Resume button press and hold Power button (do nor release the buttons)
  • Release Resume button (still hold Power button)
  • Press Resume button twice in a row (still hold Power button), after that release both Resume and Power button (then the printer standing bye)
  • Press Resume button 4 times then turn off the printer
In this stage your printer has operated as usual.
Regards,
Nov 19, 2008 | Canon S200X Ink-Jet InkJet Printer
Waste tank full
Inkjet pads are between the printer chassis and the bottom of the printer case. Typically a large felt pad.
My Canon i9100 has eight orange flashes and indicates on screen "waste ink tank is full". After opening up mine I found this to be false, only one third soiled. This then leads me to believe the i9100 has a timer to go off after a preset number of hours.
Anyone know how to reset the "full waste ink tank" error?
Dec 08, 2007 | Canon i9100D (Bundle) Photo Printer
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
